[Plugin Library] LibFredo6 - v14.4c - 18 May 24
@mhackee said:
its not working on sketchup 2013.
it says, cannot load plugin Libfredo6 because the script cannot create DEFPARAM_Dir folder
pls create it manually, respecting the case
It cannot create the folder because you do not have FULL security permissions to your Plugins folder... FCS it has been covered in a dozen posts a hundred times...Since you decline to give us any information about your OS etc then I must therefore guess...
That you have Windows...
If you [with some Admin Rights] find your SketchUp/Plugins folder and select its icon and right-click > context-menu > Properties > Security...
You will find that you do NOT have FULL permissions.Therefore... Edit... and give everyone listed FULL permissions.
Now everything will work.I reiterate:
This will apply to most users.
IF YOU WANT TO INSTALL PLUGINS [EITHER MANUALLY OR AUTOMATICALLY] AND THEREAFTER HAVE THEM WORK WITHOUT ERROR YOU MUST DO SO INTO A FOLDER FOR WHICH YOU HAVE 'FULL' SECURITY PERMISSIONS.
On your own PC it is not beyond the wit of man to set your security-permissions appropriately.
Therefore fix the permissions to the main Sketchup/Plugins folder...
This is most prevalent on PCs... BUT MAC users need not feel so smug, because their 'plugins' folder in the 'HD' path [NOT the 'user' one] might also need resetting to have FULL Read/Write permissions...If you are on a business or academic network you might have restricted access-rights to the main Sketchup/Plugins folder. Therefore you must install plugins into a 'custom-plugins' folder to which you have FULL rights... If this is the case, then seek further advice on how to contrive this...
Or you might want to 'centralize' your plugins-folder on a personal network for use by several personal PCs... then again you might need to make special arrangements to allow for this setup... if so ask again...
@cosedimarco said:
@Fredo6
New Italian translation is ready.How can I set Italian Lang for this plug-in?
where I should to put this file? -
@don-quixote said:
@cosedimarco said:
@Fredo6
where I should to put this file?Go to menu Windows > LibFredo6 Settings... > Set language and just choose Italian.
The file is part of the package.
~~I don't have any "LibFredo6 Setting" folder and I don't understand where I should to search that folder ~~
I FOUD IT ahahaha, Thank you so much that will help me a lot
On MAc, with SU 2013, the HD///SketchUp 2013//Plugins folder does not exist.
So only the User/library/application support/SketchUp 2013/SketchUP/Plugins. -
Sketchup 2013 currently does not support the all latest LibFreso plugins....please consider in your next update.
Thanks!!
Thanks!!
With LibFredo6 4.9c, this should be OK.
Fredo6.
First of all, thank you very much this plug in is great, works perfectly, simple. Superb.
Question is, can I install it on V2013? I copied from my plugins folder from V8 and doesn't work and makes SU crash. Is there a way around it?
Many thanksAlex
@xandisc said:
Fredo6.
Many thanksAlex
You would find it useful to go back to the first post of this thread and read. It is clearly spelled out that there has been an updated version. You should download and install that instead of using the old version you had in your SU8 Plugins directory. In fact you should download current versions of all of Fredo's plugins instead of using the old ones.
Get the Sketchucation Plugin Store and you can download and auto install all of the plugins you need through it.
Hey Fredo- can't get any of your plugins running on win 8 64 with SU 2013 - here's the error message...
"Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in:
c:/Program Files (x86)/Sketchup/Sketchup 2013/PluginsPlease create it manually, respecting the case
Then this error continues for the rest of my Fredo6 plugins and it ends with this:
Error Loading File LibFredo6.rb
undefined method `average_load_time' for Traductor::Plugin:Classthoughts?
It sounds like you may not have full permission for your Plugins folder...and Windows won't create the necessary sub-folder. Make sure that all the user names in your Plugins folder's Properties/Security all have full edit permission.
If you shared your OS etc in your User-profile details it helps us to help you...
Sounds like Alan's is right.
The inability to make the folder suggests that you have limited security permissions to the Plugins folder.
[Re]Set them to FULL for every one listed.BUT the missing file in the next message suggests that you have not properly installed the Lib folder etc...
This might be a mistake in the way you have extracted/installed it, OR it might look like it looks like it's installed OK, but in fact the dread Windows 'Compatibility Files' VirtualStore has kicked in to save you from yourself [resetting permissions to full for the Plugins folder should stop it recurring but you need to sort out the mess it made before the fix!]... This has been discussed endlessly in many threads... -
Jeeze, thanks guys! I'm afraid I posted waaaayyy too fast before I read the most recent posts! I've been struggling with an upgrade to win 8 and will dive into the permissions issue (and reinstalling) to hopefully correct the issue. Thanks for the quick response and great plugins...
hi,
i cant instal fredo tools, on my mac, i use sketch up 2013.
i ve tried installing it through sketchucation plugin tool, and manually, its says installed successfully, but i cant find tools.
may be i m looking in wrong place? i m new to sketchup. -
Where are you looking?
It is in the tools menu and the right-click menu
oah...thank you
Hi Fredo6,
Just wanted to pass long a quick thanks for all your plugins.
I switched from sketchup v7pro to 2013pro this weekend, and manually installed your plugins (windows all work great. Had to change permissions on the plugins folder.
thanks again,
Glenn -
i ve seen, i cant find them..
What are you expecting to see?
hi,
