    Vray 1.6 open beta
    renderpluginsextensions
    94 Posts 28 Posters 27.9k Views 28 Watching
    • dkendigD Offline
      dkendig
      It was a SU observer bug. The Maxwell guys actually reported it before I was able to, but I did give them a high five for reporting it.
      Devin Kendig
      Developer
      • H Offline
        hussy
        Vray 1.6 is good..
        but whenever i start sketchup it produce bug splat .. 😞
        without vray 1.6 it works fine
        .. please some one help
        • dkendigD Offline
          dkendig
          sounds like a faulty install. Be sure that SketchUp and XMLDRSpawner processes are not running when you try to install the 1.6 beta. Also be sure that the license server isn't running. DO NOT UNCHECK ANYTHING when installing the 1.6 beta, and if you are prompted to restart at any point during the installation, do so immediately, do not click "No" and continue the installation. After the restart you will need to run the installer again most likely, because Windows had to remove some files that were locked during the attempted uninstall process.
          Devin Kendig
          Developer
            petrusyap
            @andybot said:
            @anteolic said:
            I really dont know where to ask this question than i ask here.
            Does vrayforsu 1.6 beta has some limitation or what cause i cant get more prepass in IRRADIANCE MAP than just one.
            There's an option for "multi-pass" (under "advanced options") If it's unchecked, you will only see one pass even though it is doing all the calculations. See if that is the case.
            Correct me if I am wrong. So you mean we have to uncheck the Multipass option when doing render to ensure multi prepass in IR?
            • andybotA Offline
              andybot
              No, AFAIK that button only affects what you see in the render window, not what is going on "behind the scenes"
                petrusyap
                I found out, if we previously render using RT, after we back to the usual common render processing, the multi prepass won't process more than 1 prepass. If wanna have prepass rendering processing again, we have to reset the rendering option.
                • kaluK Offline
                  kalu
                  So Vray 1.6 doesen't work in Sketchup Pro 2013. Do I may have to wait? What I should do?
                  Thanks.
                  THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                  • dkendigD Offline
                    dkendig
                    Thanks.
                    We developed this beta, using the SketchUp 2013 Beta on one development machine, and SketchUp 8 on another. We should be 100% compatible with both versions.
                    Devin Kendig
                    Developer
                    • kaluK Offline
                      kalu
                      For all the people that work in 1.6.0.23 I have an issue with the install of the new version, is some related to the beta and it shows a 30 days demo with a code and you cannot work in vray because it run as a demo with watermarks.
                      Only if you have an issue with a error message and a code number please contact support at:
                      vrayforsketchup@chaosgroup.com
                      They fix the problem I spend a couple hours try almost all in Mac OSX and after I give up. the customer service fix the problem ASAP.
                      Thanks again to the customer service of Chaosgroup, Corey, and also Andy, valero for your help.
                      Gonzalo. 😎
                      • halroachH Offline
                        halroach
                        Any chance for animation working in version 1.60.23?
                        FlexTools - Super Quick Windows, Doors, Slats...
                          thegreek87
                          I am using Sketchup 2013 & vray 1.6.023 beta. As of last night I have started getting vray watermarks over my render. I have had this version since its release, with no watermarks.
                          Can anyone explain why I have suddenly started getting them?
                          Thank you in advance
                          http://www.nicholasvaisey.co.uk/.
                          • dkendigD Offline
                            dkendig
                            The beta period is over, your demo license has expired. When you upgrade to 2.0 you will receive a dongle that plugs in via USB and your watermark issue should disappear.
                            Devin Kendig
                            Developer
                              jwrathall
                              Hi dkendig,
                              I also have a beta 1.60.22 VR4SU on SU2013 and have just noticed I'm getting the watermark/600x400 res output treatment as well. I have to produce some renders in the next week, and I fear that registering for 2.0 and waiting for a dongle could take some time that I don't have... I live in Australia.
                              If I download the 2.0 demo/trial version, will I have 30 days of no watermarks, or will watermarks remain for that as well?
                              Otherwise, I might have to revert to a 1.49 trial on SU8 Pro to avoid the watermark.
                              Can you please assist?
                              • dkendigD Offline
                                dkendig
                                You will need to contact a local reseller. I would imagine that it would not take long for a local reseller to ship it to you. Here is our list of resellers in that country: http://www.chaosgroup.com/en/2/purchase.html?g=5&pID=10
                                I believe that the 2.0 demo has a watermark from the start. Our 1.6 beta gave you some time before the watermark kicked in, but this is no longer the case.
                                Devin Kendig
                                Developer
                                • 5 / 5
