    ? SU 2013 Custom Toolbars
    36 Posts 15 Posters 11.0k Views 15 Watching
    • sfto1S
      sfto1
      Thanks Krisidious,
      That worked.
      Do you see a customize dialog box anywhere?
      • Chris FullmerC
        Hey sfto1, the information from the Knowledge center there is slightly inaccurate. The "Customize Toolbar" window was renamed to simply "Toolbars". So it is the window that comes up when you select View > Toolbars.
        The "Command" tab that is listed does not actually exist, so the following steps it outlines are correct. I'll file this as a bug in our documentation. Thanks!
        • sfto1S
          sfto1
          Thanks Chris.
          • sfto1S
            sfto1
            @Chris and SU Team,
            The instructions above indicate there is some drop down list for locating the new toolbar. I do not see one anywhere. Please review.
            Since the Command Panel does not exist, do I just take buttons from established toolbars to create my new toolbar? and use the ctrl key to copy them over as Krisidious advised?
            • Chris FullmerC
              Hi sfto1, there is no Command panel either. It is not anywhere. Pretty much everything in that snippet that you posted in red is incorrect.
              What you do have is a View > Toolbars menu, that allows you to turn on and off toolbars, reset specific toolbars, reset all toolbars, or create a new custom toolbar. You also have an Options tab that allows you to toggel icon size and "Show Screen Tips on Toolbars".
              To customize toolbars, drag icons from existing toolbars. With the Toolbars window open, you can right click and drag any icon from toolbar to toolbar and this will MOVE the icon. If you hold down ctrl and drag it will copy it to another toolbar.
              You can also move/copy icons without having the Toolbars window open. Hold alt-right click and drag to MOVE and icon, and hold alt-ctrl to copy an icon.
              All of these move and copy icons only work on non-ruby toolbars - meaning all the toolbars that shipped with 2013, minus Sandbox, Dynamic Components, and Advanced Camera tools (I think that is all).
              Hopefully that helps clear it up a bit for now. Hopefully someone will correct me if I got some of this wrong as well πŸ˜„ Thanks,
              • KrisidiousK
                Krisidious
                and while we're at it... how do we put a native command that has no button into a custom toolbar? like a perspective button or a hide rest of model button?
                By: Kristoff Rand
                • Chris FullmerC
                  Hey Chris, that is not supported. What you would have to do is write a ruby script and create a toolbar that way for those tools.
                  • Dan RathbunD
                    Dan Rathbun
                    I asked that some of these commands would be given buttons and that a Commands panel be created similar to the one that SketchUp Viewer has.
                    It would be a Feature Request for the future I suppose.
                    I'm not here much anymore.
                    • KrisidiousK
                      Krisidious
                      thanks guys...
                      By: Kristoff Rand
                      • P
                        Panga
                        I also have a question about Toolbars : Is it still possible to make two columns large toolbars (I mean to columns of icons) ? This was very usefull to display the large toolset on the left side of the screen. I tried to replicate this in 2013 but each I'm docking the toolbar, it transforms in a one column toolbar. Any idea ?
                          Any idea ?
                          Even the first column overpass the screen's bottom?
                          • P
                            Panga
                            Yes Pilou,
                            The problem is that the one column toolbar does not show all icons !! Unless I'm using small icons. But it also depends on screen resolution...After more tests it seems impossible to have a two columns toolbar...what a pity !
                            • Dan RathbunD
                              Dan Rathbun
                              Yes .. no more multi-column toolbars. Only single column toolbars are compatible with the new toolbar framework.
                              It is in the Release Notes for v2013 (... did you read them ?)
                              • KrisidiousK
                                Krisidious
                                What do you mean no two column toolbars? I have them.
                                By: Kristoff Rand
                                • BoxB
                                  You can have them, but you can't dock them as two.
                                  Nope I lie, you can dock them.
                                  But I think the main complaint is they change to single column themselves when docked.
                                  • KrisidiousK
                                    Krisidious
                                    Ahhh... I see. Yeah. Annoying. I don't dock but top and bottom.
                                    By: Kristoff Rand
                                    • Alan FraserA
                                      Alan Fraser
                                      The fix, for the "can only dock in a single column" problem (it's not a bug...it's just that double-width columns are simply incompatible with the new toolbar flexibility)...is to create new toolbar called Large Toolset 2 (or whatever) and drag every second icon off the large toolset onto that one. Then you can dock them side by side looking exactly the same as before.
                                      I put in a Feature Request for your new icon/toolbar layout to be able to be saved to an external file that can survive a complete re-install of the program...'cos if I'm going to all this trouble, I only want to have to do it once.
                                      3D Figures
                                      • P
                                        Panga
                                        Thanks for the info, did not find the time to read it fully !
                                        • P
                                          Panga
                                          Thanks for the clever tip ! Will try that tomorrow !
                                          • john2J
                                            john2
                                            is there any way i can get old icons that used to be in earlier version of sketchup in the toolbars of 2013 version?
                                            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
