    Reasons why to go on SU 2013 ...
    34 Posts 19 Posters 3.2k Views 19 Watching
      ArCAD-UK
      I use it commercially. The improvements in SU may not be immediately obvious but the cost of the upgrade for the improvements to LO make sense. A form of hatch has been desperately needed, now we have it, although the range of patterns needs expanding but you can do that with most graphics packages.
        matt.gordon320
        I've been fiddling with it since it came out, and while I understand there's not really new features, I'm excited about some of the UI and core program changes. It's been discussed in the developer forums more, but I think it's really commendable that they're turned attention to setting up a full C SDK, and that they've taken the time to make the UI work as it should. True, they're not new features, but I think they're important infrastructural changes that signify the degree of polish and usability to which Trimble intends to release with SketchUp in the future.
        It may not have any new features, but in both starting up, quitting, and heavy modeling, it's stupidly fast and stable for me. As I said before, the UI changes are really starting to feel as if the whole package is beginning the transition to a much more tightly put together package.
        Just my $0.02.
        • Alan FraserA
          Alan Fraser
          Matt +1.
          2013 is way faster and more stable. A cold start of V8 on my laptop takes 15 seconds to load all the plugins. V2013, loading exactly the same scripts takes 4 secs.
          It may not have lots of shiny new toys, but the way in which it handles scripts (which are shiny toys in themselves) is hugely improved.
          3D Figures
          • EscapeArtistE
            EscapeArtist
            I use 8 Pro and never use LO. Is there any reason I should switch? Personally, none of the wish list items I would have deemed most useful made it into this version, so I'm not inclined to swap...
            However, if it is discernibly faster I might be convinced to try it out so long as it and 8 can happily coexist l.
              If you don't update you'll be paying full welly next year if it's something that floats your boat.
              Try the trial it co-exists with v8 fine
              • soloS
                Faster and more stable, so far that is enough for me.
                • W
                  wyatt
                  It sounds like you're saying if you miss an annual update cycle, that you'll have to buy a whole new license. Rich, has this been confirmed? I haven't seen anything "official" from Trimble on skipping a release.
                  • GarethG
                    Gareth
                    Speed and stability are deal breakers for me too (as well as Plugin reliability).....so for that reason alone I'll most likely take it on.
                    After all, there is a limit to how many cups of coffee I can drink each time the program hangs when I'm working on a complex model....!! ๐Ÿ˜†
                      d12dozr
                      Are you sure?
                      On the 2013 FAQ page it says:
                      What happens if I decide to skip a year in this program?
                      SketchUp Pro commercial licenses never expire, so skipping a year of the program doesnโ€™t affect your use of SketchUp Pro at all. However, if you do decide to skip a year, you can expect a modest reinstatement fee should you choose to renew your upgrade, maintenance, and support program.
                      So from that I infer that you'd pay $95 + some...it wouldn't make sense for them to charge more than 2x the annual fee ($95+95).
                      http://goo.gl/f7ooYh
                      • W
                        wyatt
                        Thanks, Marcus. I know I've read that FAQ; not sure how I missed that part.
                        • Gus RG
                          Gus R
                          So basically Sketchup is now owned by Bain Capital. ๐Ÿคฃ
                          www.instagram.com/gusrobatto/
                          www.facebook.com/gusrobatto
                            The upgrade cost plus fee to me is full welly. Whereas 'all in' would mean total price.
                            Sorry for the use of slang.
                            Currently $50 is the moderate fee assigned to OS license change.
                            Getting v2014 at $150 to $200 is certainly a good deal if you need it.
                            Sent from my iPad
                            • Mike LuceyM
                              Mike Lucey
                              Reasons why to go on SU 2013 ... ?
                              Well, its a case of Faith, Hope and Charity!
                              Initially .... a leap of faith and then hope that 2013 (and a bit) will deliver more next Sept / October, possibly at a 3D Base Camp. The upgrade price can be looked on as charity ๐Ÿ˜‰
                              Mike
                              • pbacotP
                                If there are speed improvements for SU (Pete says so) but especially speed improvements for LO.
                                I just produced a set in SU/LO in v.8 and kept finding the slow rendering every step of the way to be the worst part of the whole process. Every time you make a change. Well you could turn off "auto" but how can you move forward if you can't check the results of what you just did?
                                • dereiD
                                  derei
                                  Mike
                                  Well, I think this is the best answer... I was expecting for it. I didn't wanted to say it by myself, but I was waiting to see when it will appear... as it's the obvious reason. Some speed improvements and small tweaks aren't features for a major release. It's like going with a flower and nothing else to your girlfriend's birthday ๐Ÿ˜„ .
                                  So, I will take Mike's answer that the main reason to go pro with SU 2013 is to show some faith to Trimble... but (hello Trimble, this is for you ==> ) - Also, Trimble shall not disappoint the SU users community in the future.
                                  DESIGNER AND ARTIST DEREI.UK
                                    rv1974
                                    I had some nasty restriction on one of my PCs in v8: it could not open more than 4-5 files simultaneously. v2013 somehow solved it at last.
                                    • pbacotP
                                      Depends on how much she likes what the flowers not hiding. ๐Ÿ˜ณ
                                      • KrisidiousK
                                        Krisidious
                                        5? I think the most I've ever needed was 3... have you tried that instance plugin?
                                        By: Kristoff Rand
                                        • charly2008C
                                          charly2008
                                          As a private hobby user I see no reason at the moment to switch to SketchUp 2013.
                                          Sketchup 8 meets my needs until now.
                                          I would rather pay the full price when truly revolutionary innovations are introduced. One of which would be, for example, a high processing speed with high poly models. A better customizable menu structure would also be desirable.
                                            rv1974
                                            What instance plug-in? Anyway I copy-pasted the whole v8 plugins folder to the new 2013 one.
