    Reasons why to go on SU 2013 ...
    34 Posts 19 Posters 2.9k Views 19 Watching
      d12dozr
      @rich o brien said:
      If you don't update you'll be paying full welly next year if it's something that floats your boat.
      Are you sure?
      On the 2013 FAQ page it says:
      What happens if I decide to skip a year in this program?
      SketchUp Pro commercial licenses never expire, so skipping a year of the program doesnโ€™t affect your use of SketchUp Pro at all. However, if you do decide to skip a year, you can expect a modest reinstatement fee should you choose to renew your upgrade, maintenance, and support program.
      So from that I infer that you'd pay $95 + some...it wouldn't make sense for them to charge more than 2x the annual fee ($95+95).
      http://goo.gl/f7ooYh
      • W Offline
        wyatt
        Thanks, Marcus. I know I've read that FAQ; not sure how I missed that part.
        • Gus RG Offline
          Gus R
          So basically Sketchup is now owned by Bain Capital. ๐Ÿคฃ
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
            The upgrade cost plus fee to me is full welly. Whereas 'all in' would mean total price.
            Sorry for the use of slang.
            Currently $50 is the moderate fee assigned to OS license change.
            Getting v2014 at $150 to $200 is certainly a good deal if you need it.
            Sent from my iPad
            • Mike LuceyM Offline
              Mike Lucey
              Reasons why to go on SU 2013 ... ?
              Well, its a case of Faith, Hope and Charity!
              Initially .... a leap of faith and then hope that 2013 (and a bit) will deliver more next Sept / October, possibly at a 3D Base Camp. The upgrade price can be looked on as charity ๐Ÿ˜‰
              Mike
              • pbacotP Offline
                If there are speed improvements for SU (Pete says so) but especially speed improvements for LO.
                I just produced a set in SU/LO in v.8 and kept finding the slow rendering every step of the way to be the worst part of the whole process. Every time you make a change. Well you could turn off "auto" but how can you move forward if you can't check the results of what you just did?
                • dereiD Offline
                  derei
                  Mike
                  Well, I think this is the best answer... I was expecting for it. I didn't wanted to say it by myself, but I was waiting to see when it will appear... as it's the obvious reason. Some speed improvements and small tweaks aren't features for a major release. It's like going with a flower and nothing else to your girlfriend's birthday ๐Ÿ˜„ .
                  So, I will take Mike's answer that the main reason to go pro with SU 2013 is to show some faith to Trimble... but (hello Trimble, this is for you ==> ) - Also, Trimble shall not disappoint the SU users community in the future.
                  DESIGNER AND ARTIST DEREI.UK
                  • R Do not disturb
                    rv1974
                    I had some nasty restriction on one of my PCs in v8: it could not open more than 4-5 files simultaneously. v2013 somehow solved it at last.
                    • pbacotP Offline
                      Depends on how much she likes what the flowers not hiding. ๐Ÿ˜ณ
                      • KrisidiousK Offline
                        Krisidious
                        5? I think the most I've ever needed was 3... have you tried that instance plugin?
                        By: Kristoff Rand
                        • charly2008C Offline
                          charly2008
                          As a private hobby user I see no reason at the moment to switch to SketchUp 2013.
                          Sketchup 8 meets my needs until now.
                          I would rather pay the full price when truly revolutionary innovations are introduced. One of which would be, for example, a high processing speed with high poly models. A better customizable menu structure would also be desirable.
                          • R Do not disturb
                            rv1974
                            What instance plug-in? Anyway I copy-pasted the whole v8 plugins folder to the new 2013 one.
                            • Alan FraserA Offline
                              Alan Fraser
                              Following on from that, Juan; it would seem that now...with a choice of TWO plugin stores and a revised GUI...would be a good time for everyone to do some overhauling of their plugins and the layout of their toolbars.
                              This might take quite some time to get right; and I wouldn't want to lose all that hard work by being presented with a new release and told I have to perform a clean install...and hence back to first base.
                              For this reason, I put in a Feature Request for some way of saving any custom configuration to an external file, so that it could survive any such re-install. I don't mind taking time out to Spring clean...I'd just prefer to do it the once.
                              John Bacus got quite excited about this idea and took it one stage further, suggesting that users would then be able to save a whole collection of UIs, depending on what they were doing. For instance, instead of having a gazillion icons crowding your screen, you could have an 'organic modeling' setup with just the toolbars like Artisan, Round Corners, TIG's Extrude Tools etc. Or you could have a Housbuilder UI with all the parametric roof and walls plugins. Then, having finished that part of the job, you could seamlessly load a landscaping UI with all the topographical stuff and Ivy Maker, Tree Maker etc.
                              Sounds like a plan to me. ๐Ÿ˜„
                              3D Figures
                              • jason_marantoJ Offline
                                jason_maranto
                                Wow, so "darling" had the awesome inspiration to have user defined custom workspaces -- what a brilliant idea, so far ahead of it's time!
                                Oh, except for the fact I've already been using custom workspaces in most of my other software for the better part of a decade.
                                I'm always amazed at how the expectations are so low here that old commonplace ideas are treated as great innovations by the user base...
                                Of course we should have custom workspaces -- but we should have had them when they were a new idea. Now it's just another example of SketchUp trying to catch up to the rest of the software world.
                                Wake me when they get there.
                                Best,
                                Jason.
                                  Mike Lucey
                                  Best,
                                  Jason.
                                  I will, I will, I promise ๐Ÿ˜„ Are you going for a little sleep now? .........
                                  %(#0000BF)[Hush, little baby, don't say a word.
                                  Papa's gonna buy you a mockingbird
                                  And if that mockingbird won't sing,
                                  Papa's gonna buy you a diamond ring
                                  And if that diamond ring turns brass,
                                  Papa's gonna buy you a looking glass
                                  And if that looking glass gets broke,
                                  Papa's gonna buy you a billy goat
                                  And if that billy goat won't pull,
                                  Papa's gonna buy you a cart and bull
                                  And if that cart and bull turn over,
                                  Papa's gonna buy you a dog named Rover
                                  And if that dog named Rover won't bark
                                  Papa's gonna buy you a horse and cart
                                  And if that horse and cart fall down,
                                  You'll still be the sweetest little baby in town.]
                                    jason_maranto
                                    That would be a Rip Van Winkle level sleep. ๐Ÿ˜‰
                                    The other companies aren't going to stand still while SketchUp tries to catch up -- they will be busy with the next round of innovations we can't have.
                                    Best,
                                    Jason.
                                    • GarethG Offline
                                      Gareth
                                      Jason, I'll set the alarm for you
                                      ..do you prefer to be woken by music, or one of those annoying 'Beep Beep' sounds...??!!
                                        Alan Fraser
                                        One of the first things I learnt...way back in the day, during my teacher training...was that you don't continually whine and nag. Your whining just becomes like wallpaper. People become inured to it and simply ignore you.
                                        What would you have expected his response to that particular point to have been, Jason? That he'd shoot off at a complete tangent and start talking about Advanced UV mapping or NURBS surfaces? Late in the day or not, it's an improvement on what we have now.
                                        3D Figures
                                          jason_maranto
                                          First off -- it isn't an improvement because you haven't seen it... and you may very well never see it. It would not be the first time he's shown alot of interest in an idea that never materializes.
                                          Secondly, my point was really about the low bar users have set for the software -- the level of accountability this team is being held to is shamefully low. If that appears as whining to you then you have misread my position.
                                          My expectations are that SketchUp fairly compete for my money... yours seem to be alot lower than that. If my position is unrealistic, then yours is the position of a victim of Stockholm syndrome.
                                          But I have realized I wandered into the wrong thread, so I'll take my leave.
                                          Best,
                                          Jason.
                                            Mike Lucey
                                            Well, there is a constructive way to 'go' with 2013 and at the same time express any doubts one may feel about the caliber of the new release ....... simply UPGRADE ...... to show SUPPORT and WRITE AN EMAIL to one of the TSU Dev Team expressing your concerns.
                                            I would imagine any reasonable company would return with answers directly to you, even stock answers!
                                            Stockholm syndrome
                                            I saw mention of the syndrome last night in a TV doc about the Ariel Castro case. Makes one wonder! But again we are not captive in any way as the door is wide open to walk through if the desire is there.
                                            • 2 / 2
