    [Plugin] Edge Tools
    211 Posts 74 Posters 283.5k Views 74 Watching
      What is the exact error message?
        As Dave said, without knowing the error it's impossible to determine what the problem is.
        If I'd hazard a guess, did you install the required TT_Lib2? Linked under Requirements right above the Download button?
        • onzkiO Offline
          onzki
          This is an amazing tool. Thanks so much it's very useful. I like the concept of curve simplification.. However, forgive my out of the world request, is it also possible to have a way to make curves smoother- meaning an option to add segments rather than reduce. I know it sounds crazy but there are times when most of my CAD import are roughly segmented like the one shown on screenshot.
          http://img837.imageshack.us/img837/3300/roughlysegmented.jpg
          [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
            Problem here is that they are part of complex geometry. Adding more segments to that isn't easy for a computer operation to do.
              rv1974
              Thomthom, would it be hard to refine 'divide face' to make it offset '0' from stray line laying on the face (AB in the attachment)?
              Another thing: Could there be 'magneto' or double click feature (like in standard move and offset) that'd glue to the last numeric input?
              Thank you.
                Offset zero? I'm afraid I don't understand the request. What is the expected result?
                Thank you.
                That would be nice indeed.
                  rv1974
                  Activate 'divide face' tool, put cursor above AB line segment and try to cut the face via AB. Currently you won't make it,- there's kind of bug.
                    Ah! Gotcha! So it's be an extend edge kindof feature?
                      rv1974
                      exactly
                        There are already plugins that extend lines.
                          Not sure I understand why it can't be done by hand...
                          Make a guide-line through the line AB.
                          Ensure nothing is selected.
                          Activate the Move tool.
                          Pick the start of the line AB and snap it to the guide's intersections with the face's edge.
                          Repeat for the end of the line AB.
                          Now line AB has extended to meet the two face-edges...
                          Erase the superfluous guide-line.
                          Alternatively draw a new line across the face from the intersections of the guide and the face's edges... erase the guide.
                            Because one click is nicer than many. 😉
                            When cleaning up plans there's often a lot of edges that need extending - and the less clicks the better.
                            I've been meaning to find the time to allow the Close Edge tool in Edge Tools to do this. So when it highlights an open end edge you can just click on it and have it extend - even though it would be outside the radius.
                              There's already my 2dTools Adjust ?
                              Works in any plane...
                              Wipe the two types of edges and - objects/targets and they adjust by extending or trimming...
                                rv1974
                                It should be a permanent headline in the ruby sub-forum.
                                • JQLJ Offline
                                  JQL
                                  Thomthom,
                                  Since Sketchup 2013 the inspect tool in Edgetools2 has been very unstable.
                                  Split faces is working fine, erase stray edges is perfect as ever and I can also use align vertices. However most of the time I try the inspect tool Sketchup crashes sometimes it's only when I press the circles, but it also happens just for executing the tool. The strange thing is that it actually inspects correctly but then SU stops responding.This is happening with both complex and simple models.
                                  I have the most recent version installed and also TT Library. I erased both folders and reinstalled from Sketchucation Plugin Store.
                                  As I don't see anyone saying the same thing I suppose it might be my problem, but would you have some kind of guidelines for figuring out what I can do?
                                  Thanks and best regards,
                                  EDIT: I just isolated both TTLib and Edgetools and removed every other plugin from plugins folder and it crashed again...
                                  JQL
                                  www.casca.pt
                                  Visit us on facebook!
                                  • halroachH Offline
                                    halroach
                                    I've got an idea for a nice feature that could make this plugin even more powerful.
                                    Having the option to limit the "edge gap closing" to points that are on the same Z. Any chance for that?
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                      calvin200001
                                      does this work for mac? I get an error:
                                      Error Loading File /Users/****/Library/Application Support/SketchUp 2013/SketchUp/Plugins/TT_EdgeTools/core.rb
                                      no such file to load -- TT_Lib2/core.rb
                                      Error Loading File tt_edgetools.rb
                                        Have you installed the latest version of the TT_Lib2 and restarted SketchUp ?
                                        http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                                          calvin200001
                                          SO sorry, I didnt see that. Works amazingly now.
                                          • halroachH Offline
                                            halroach
                                            Hi Thomthom,
                                            I've been using edge tools for a long time. It's great!
                                            A little idea that could be a great time saver.
                                            It would be nice if you could add to the 'Inspect & Close' function, an option of dragging the mouse over a bunch of edges to have them all fixed at once.
                                            (... Like when there is a long staircase imported from dwg where all of the steps aren't connecting... drag a selection all around them... and viola - all taken care of).
                                            • 11
                                            • 6 / 11
