    Guitar String Bump Mapping Attempt
    renderpluginsextensions
    11 Posts 5 Posters 1.5k Views 5 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      Mak sure you keep a bitmap in the diffuse slot, otherwise you'll lose the UV mapping.
      A bitmap with the same gray color you want, but with the same size as your bump map.
        rspierenburg
        Here is my try at it.
        Rendered Jpg image
        Here is the SKP file
        Sketchup Model
        What I did was add a second diffused layer with a copy of the Bump map to allow you to see the direction/scale of the bumps. On that same diffused layer I added a TexAColor of pure white to the transparency slot so it would show up in sketchup but not be rendered. I then was able to use the UV Map that you had to map the string material properly. I then used the Sketchup texture editor to adjust the scale of the string texture to look better.
        Let me know what you think.
        Rob
        • V
          valerostudio
          Very nice use of SketchUV! I had a similar task with adding ribs to a hose and SketchUV did the trick.
          • Gus RG
            Gus R
            Thanks, was considering this might be a possible solution last night.
            www.instagram.com/gusrobatto/
            www.facebook.com/gusrobatto
            • Gus RG
              Gus R
              [attachment=1:13j7bmps]<!-- ia1 -->Low E Wound String.jpg<!-- ia1 -->[/attachment:13j7bmps]
              [attachment=0:13j7bmps]<!-- ia0 -->Low E Wound String.skp<!-- ia0 -->[/attachment:13j7bmps]
              Rob
              Thanks Rob. Tried what you described but I can't get the required results. Would it be possible for you to upload the vismat file for the material?
              • Gus RG
                Gus R
                [attachment=2:18jtul6j]<!-- ia2 -->Low E Wound String.jpg<!-- ia2 -->[/attachment:18jtul6j]
                [attachment=1:18jtul6j]<!-- ia1 -->Low E Wound String.skp<!-- ia1 -->[/attachment:18jtul6j]
                Rob
                OK, I got it now. The second diffuse layer goes over the original defuse layer. This I learned from Nomeradona's tutorial, Basic VRAY SketchUp Tutorial Series.
                [attachment=0:18jtul6j]<!-- ia0 -->Vray Low E String.jpg<!-- ia0 -->[/attachment:18jtul6j]
                Summarized:
                1. Imported silver_matte.vismat to the string.
                2. Attached the bump jpg to maps layer using TexBitmap.
                3. Created a second defuse layer and dragged it over the main defuse layer.
                4. Attached same bump jpg to second defuse layer using TexBitmap.
                5. Added white to TexAColor for the transparency.
                6. Adjust texture mapping.
                Thanks Rob.
                  rspierenburg
                  One thing I did notice on your original model is that you had your bump and displacement set to 1.5, keep in mind this is inches, I reduced mine down to .1 to avoid the black lines you see in yours. Just try it and see.
                  • Gus RG
                    Gus R
                    That seems to be the key. Wasn't happy with the black lines. I removed all white from the bump map and dropped the bump down to 0.1. Some of the other bump maps on this rendering are well below 1. The model I'm working on is 10x scale.
                    The new bump map I worked with.
                    • olisheaO
                      olishea
                      thats awesome πŸ‘
                      oli
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        Nice ! Can't wait to see the whole guitar πŸ˜„
