    Texture Mapping Curtains
    28 Posts 8 Posters 4.9k Views 8 Watching
      I don't I just pretend πŸ˜‰
      • neetsN
        neets
        Yea, right...!! If I can work out how to get those stripes to appear as good vertically using Thrupaint I shall treat myself to ANOTHER glass of wine!!
        Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
        • Gus RG
          Gus R
          @rich o brien said:
          Are you using SketchUV Gus?
          Did you explode the model to remove it default axix position?
          Did you remove the mats applied to the group and not the geometry?
          Opened the skp. Removed the material from the group. One iteration of Artisan smoothing. Applied material. Exported UV with SketchUV within the group not moving or having rotated anything. Imported obj into Blender. Scaled it down. Right click and smooth. Tabbed into edit mode and click U and then UV unwrap. Then I switch over to texture mode and it's at 45 degrees. Tried it again with a fresh download of the skp in case I moved anything earlier.
          www.instagram.com/gusrobatto/
          www.facebook.com/gusrobatto
            @Gus
            In the UV editor hover over the unwrapped mesh and press L to select it
            R to rotate it
            If you can give me a link to that cloth as I can't find it now...so I can investigate it.
            I'm sure I'm missing something here
            • Gus RG
              Gus R
              @rich o brien said:
              @Gus
              R to rotate it
              Thanks, was practicing the rotation as well. Reset Blender to factory settings as well. Here's the link to the model.
                So, here's my result
                Exploded SU model
                removed texture
                sub'd
                applied mat to front face
                selected all export UVs
                imported into Blender
                scaled down
                tabbed into edit mode
                U to unwrap and here's the results
                  @Gus
                  Looking at this again there is some stray geometry getting unwrapped
                  http://sketchucation.com/forums/download/file.php?id=105623&mode=view/rokbox.jpg
                  you can see it in the bottom right corner
                  • Gus RG
                    Gus R
                    @rich o brien said:
                    @Gus
                    Rich, I found a fix by uninstalling Blender 2.63 and upgrading to 2.67. Works now. Thanks for your help.
                    • jo-keJ
                      jo-ke
                      ah, these decorated curtains a very difficult. If had the same problems too and they aren't solved yet.
                      Below I attach my file, for trying to texture with vertical stripes...
                      raffschal.skp
                      http://www.zz7.de
                        D'oh!
                        Never cross my mind you were on an old version. Happy mapping
                        • 2 / 2
