    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
      davinchi
      Hello,
      it seems to be a very nice plugin!!!
      Is it possible to get an step by step installation manual of this plugin for Win7 x 64; SU Pro 8.0.3117???
      I try to install, but without success, please help!
      Thanks a lot!
        Anton_S
        Thanks a lot!
        Download it and extract it to plugins
        It should look like this:
        .../Google Sketchup [n/plugins/]
        %(#008040)[win32
        windows
        forwardable.rb
        Window Settings.rb]
        • charly2008C
          charly2008
          Thanks Anton for this, good useful tool. I've always been waiting for such a tool. I have no problem in Win 64-bit and Sketchup 8
          One reminder: The change in full-screen mode to another application is done with the Windows and Tab key.
          • F
            feodos
            After assigning a hotkey for the menu item "Thread Dialogs" problem. Menu crumbles
            before
            After
              Anton_S
              Thanks for report, I'll try to fix that.
              • T
                tulacong
                tha thank you
                  Not sure about earlier versions, nor windows 8
                  Seems no problem with SU 8 with Windows 8 (Integral x64) β˜€
                  (not tested by me but by an another French user πŸ˜‰
                    Anton_S
                    Good!!! Good!!! πŸ’š
                      Anton_S
                      New Release!!!
                      See 1st post πŸ˜‰
                      • BurkhardB
                        Burkhard
                        Great work here.
                        Something I noticed. When setting the menubar invisible, the Dialog settings pop up.
                        When closing, the menubar is visible again. No chance to hide the menubar like the statusbar?
                        You got a pm
                        http://www.ia-plus.de
                          Anton_S
                          Well, it shows up to give a way back to set-up the menubar again. If want to remove menubar, without dialog showing up then use commands, write in ruby console:
                          AMS::Sketchup::MenuBar.maintain(true or false)
                          For more commands, see first post πŸ’š
                            jorge2011
                            thanks for this update.
                            A small error.
                            In option: Owned Popups - "Show / Hide" does not work correctly.
                            When you hide and show, the windows can not be uncoupled and refitted.
                              Anton_S
                              A small error.
                              The issue was already reported, and I don't seem to have success in fixing it πŸ˜’
                              Working on it.. πŸ€“
                                jorge2011
                                sorry, but that option is the same option of the menu: Window> hide dialog boxes?
                                in your plugin is just adding an access to this function. no?
                                • renderizaR
                                  renderiza
                                  This is awesome! I am soon to be finishing another of my plugins called "Key Scene" and this will greatly enhance it...Thank you so much!
                                  Renderiza
                                  [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                                    matt.gordon320
                                    Anton, this is amazingly helpful! I teach Sketchup as well as being a heavy user in Architecture, and I do a lot of screencasts for my students. I got really tired of turning all my plugins off and moving my toolbars all over whenever I had to record. Now, I don't ever have to again!
                                    Just wanted to say a VERY sincere thanks, you've saved me hours and hours of tedious work that goes completely unnoticed to everyone but me πŸ˜„
                                    • P
                                      Pete
                                      I am really benefiting from using this plugin!! I really appreciate the work you are doing!! Thank you for sharing.
                                      Here is an idea for a feature: can the dialog height for the component options window be overridden to use the entire height of the screen above the windows task bar?
                                      Demonstration:
                                      http://www.youtube.com/watch?v=vtWd1cb2ee4
                                        Anton_S
                                        Hello Pete,
                                        Component Options is a tool, written by Google SketchUp. I honestly have no rights modifying the way its dialog interacts. Change it would probably end me in the SketchUp jail, well, unless I already violated enough dialogs. πŸ˜’ It would be great if you post your suggestion to the SU Wishes or somewhere in that category, they'd probably be convinced with it πŸ˜‰
                                        πŸ’š
                                        • CadFatherC
                                          CadFather
                                          on the other hand, i guess you could use winsize (it's a must for windows users anyway)
                                          http://winsize2.sourceforge.net/en/index.html
                                          the drawback is that it resizes a window by its name, so if you have the palette called 'components',
                                          and you set it to 900x500 pixels, that will also resize the window's folder by the same name when you are browsing in explorer.
                                          • P
                                            Pete
                                            CadFather, winsize is doing just what I want!! Thank you.
                                            In case someone has a native SketchUp way to do this I have moved this discussion to http://sketchucation.com/forums/viewtopic.php?f=289&t=52060
                                            • 14
                                            • 15
                                            • 4 / 15
