    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
    • W
      Woody Longspike
      @antuan said:
      I had Tools on surface, Fredo Scale and other Fredo plugins installed in SU 7.1 and all was working OK. Today I installed SU 8, downloaded last versions of same plugins and everything worked OK until I tried to open Default Parameters dialog. It simply didn't open for any of the plugins... I reinstall plugins, even reinstall SU... nothing, the Default Parameters doesn't open. Any idea to solve that?
      Thank you in advance.
      I seem to be experiencing the same mysterious problem. Did clean reinstall of latest SU, and only additional plugin folder plugin. Then installed LibFredo6-v4.8, & TOSv1.8 in newly made additional folder everything seems to work except Default Parameter window still doesn't open. Made new isolated additional folder on drive E:\ (an SD card) then installed LibFredo6-v4.8, & Latest Round Corner plugin there. It works but still no Default Parameter Dialog window. Will post all kinds of screenshots if need be, let me know what you need from me. O.S. = Windows XP 32 home version, Thanks in advance.
        This sounds like a case of insufficient administrative rights to the Plugins folder. Have you made sure that you have, under your login, all permissions granted for the Plugins folder?
        This has been covered repeatedly in this thread.
        • W
          Woody Longspike
          Yes to the best of my ability and knowledge it appears the rights are set correctly. I do wonder if my comptuer retains these settings though.
            You ought to be able to check by looking at the security settings. Post a screen shot of that and we'll take a look.
            • W
              Woody Longspike
              When I open properties of plugin folder I see this.I click read only green box , then click apply, then select tick box to apply to all subfolders and files, then click ok.
              When ever I've gone back to check, the green box is back, but its not a checkmark.
              • W
                Woody Longspike
                and here it is checked
                I had to manually click to show the check mark.
                  Those settings are NOT what was meant.
                  You must have admin rights - given them to yourself in the Users Control Panel.
                  Then there is tab under Properties > Security...
                  Click the Edit button and give everyone on the list FULL rights...
                  • W
                    Woody Longspike
                    Hey TIG thanks for your reply I'm on Windows XP home 32 bit SP3. There`s no properties/security settings tab, thats a windows vista or 7 & up thing. I do have computer admin settings which I always log in as admin.
                      XP !
                      Then you need to do it another way...
                      http://support.microsoft.com/kb/308419
                      http://www.ehow.com/how_2383435_set-permissions-windows-xp.html
                      • W
                        Woody Longspike
                        If simple file sharing is enabled, the simple file sharing user interface is displayed instead of the Security and Sharing tabs. By default, this new user interface is implemented in both Windows XP Home Edition and Windows XP Professional if you are working in a workgroup. If you disable simple file sharing, the classic Security and Sharing tabs appear, and you can specify which users and groups have access to shared folders on your computer.
                        Note You cannot disable simple file sharing in Windows XP Home Edition.
                        Aha...Thanks Fredo6, TIG, & Dave R. I was under the impression Additional Plugin Folder plugin was a work around this problem. Apparently after reading many support articles and threads here, there, and everywhere else, Windows XP Home has failed me 😠 http://support.microsoft.com/kb/307874 no fix or work around available from my understanding. Thanks again for your help.
                          Can you not fix permission in the command-console?
                          I think that was explained in the first link I gave ??
                          • LanaL
                            Lana
                            Very, very thanks TIG, you are big. Congratulations.
                            • fredo6F
                              NEW RELEASE: LibFredo6 v4.9a - 18 May 13
                              LibFredo6 4.9a is dedicated to Curvizard 1.2 (to improve the management of bigger amount of contours and edges).
                              • fredo6F
                                NEW RELEASE: LibFredo6 v4.9b - 19 May 13
                                LibFredo6 4.9b is a technical release mainly dedicated to some issues on Mac platforms.
                                • W
                                  watkins
                                  Dear Fredo6,
                                  There is a small problem with your plugin checker
                                  404 Not Found
                                  (sketchucation.com)
                                  Kind regards,
                                  Bob
                                  • mitcorbM
                                    mitcorb
                                    At this time, LibFredo6 version 4.9b 19 May 13 is not listed as such in the Plugins Index yet, and the Plugin Store does not list it yet, either. I realize that the database keepers will update this soon, just wanted to report.
                                      Yes, we know - Fredo is changing versions frequently at the moment 😒 - once the dust settles be assured that it'll get into both the Index and the Store [the updating is not 'automatic' - it needs human intervention to ensure it's kosher...]
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v4.9c - 20 May 13
                                        LibFredo6 4.9b is a technical release still dedicated to some issues on Mac platforms.
                                        • fredo6F
                                          @watkins said:
                                          Dear Fredo6,
                                          404 Not Found
                                          (sketchucation.com)
                                          Kind regards,
                                          Bob
                                          This should be fixed with 4.9c
                                            mhackee
                                            its not working on sketchup 2013.
                                            it says, cannot load plugin Libfredo6 because the script cannot create DEFPARAM_Dir folder
                                            pls create it manually, respecting the case
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 112
                                            • 113
                                            • 30 / 113
