    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.8m Views 589 Watching
      Missy_X
      OK nevermind, somehow rebooting my pc fixed the problem lol (yes yes, first thing everyone should try when a pc acts weird, i know ! lol)
      • fredo6F
        Glad you recover the situation.
        However the problem you encountered is puzzling.
          Missy_X
          Yes i know, i never had it happen before and it doesn't make any sense. Anyway, thank you Fredo and TIG for trying to help. 😄 All this made me realize how addicted i am to Sketchup and all the plugins you guys make. Half a day with Sketchup not working and i was going completely nuts. 😆
          • fredo6F
            NEW RELEASE: LibFredo6 v4.8a - 25 Apr 13
            LibFredo6 4.8a is a major release dedicated to TopoShaper 1.0 (a script to generate terrain from contours).
            • W
              Woody Longspike
              @antuan said:
              I had Tools on surface, Fredo Scale and other Fredo plugins installed in SU 7.1 and all was working OK. Today I installed SU 8, downloaded last versions of same plugins and everything worked OK until I tried to open Default Parameters dialog. It simply didn't open for any of the plugins... I reinstall plugins, even reinstall SU... nothing, the Default Parameters doesn't open. Any idea to solve that?
              Thank you in advance.
              I seem to be experiencing the same mysterious problem. Did clean reinstall of latest SU, and only additional plugin folder plugin. Then installed LibFredo6-v4.8, & TOSv1.8 in newly made additional folder everything seems to work except Default Parameter window still doesn't open. Made new isolated additional folder on drive E:\ (an SD card) then installed LibFredo6-v4.8, & Latest Round Corner plugin there. It works but still no Default Parameter Dialog window. Will post all kinds of screenshots if need be, let me know what you need from me. O.S. = Windows XP 32 home version, Thanks in advance.
                This sounds like a case of insufficient administrative rights to the Plugins folder. Have you made sure that you have, under your login, all permissions granted for the Plugins folder?
                This has been covered repeatedly in this thread.
                • W
                  Woody Longspike
                  Yes to the best of my ability and knowledge it appears the rights are set correctly. I do wonder if my comptuer retains these settings though.
                    You ought to be able to check by looking at the security settings. Post a screen shot of that and we'll take a look.
                    • W
                      Woody Longspike
                      When I open properties of plugin folder I see this.I click read only green box , then click apply, then select tick box to apply to all subfolders and files, then click ok.
                      When ever I've gone back to check, the green box is back, but its not a checkmark.
                      • W
                        Woody Longspike
                        and here it is checked
                        I had to manually click to show the check mark.
                          Those settings are NOT what was meant.
                          You must have admin rights - given them to yourself in the Users Control Panel.
                          Then there is tab under Properties > Security...
                          Click the Edit button and give everyone on the list FULL rights...
                          • W
                            Woody Longspike
                            Hey TIG thanks for your reply I'm on Windows XP home 32 bit SP3. There`s no properties/security settings tab, thats a windows vista or 7 & up thing. I do have computer admin settings which I always log in as admin.
                              XP !
                              Then you need to do it another way...
                              http://support.microsoft.com/kb/308419
                              http://www.ehow.com/how_2383435_set-permissions-windows-xp.html
                              • W
                                Woody Longspike
                                If simple file sharing is enabled, the simple file sharing user interface is displayed instead of the Security and Sharing tabs. By default, this new user interface is implemented in both Windows XP Home Edition and Windows XP Professional if you are working in a workgroup. If you disable simple file sharing, the classic Security and Sharing tabs appear, and you can specify which users and groups have access to shared folders on your computer.
                                Note You cannot disable simple file sharing in Windows XP Home Edition.
                                Aha...Thanks Fredo6, TIG, & Dave R. I was under the impression Additional Plugin Folder plugin was a work around this problem. Apparently after reading many support articles and threads here, there, and everywhere else, Windows XP Home has failed me 😠 http://support.microsoft.com/kb/307874 no fix or work around available from my understanding. Thanks again for your help.
                                  Can you not fix permission in the command-console?
                                  I think that was explained in the first link I gave ??
                                  • LanaL
                                    Lana
                                    Very, very thanks TIG, you are big. Congratulations.
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v4.9a - 18 May 13
                                      LibFredo6 4.9a is dedicated to Curvizard 1.2 (to improve the management of bigger amount of contours and edges).
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v4.9b - 19 May 13
                                        LibFredo6 4.9b is a technical release mainly dedicated to some issues on Mac platforms.
                                        • W
                                          watkins
                                          Dear Fredo6,
                                          There is a small problem with your plugin checker
                                          404 Not Found
                                          (sketchucation.com)
                                          Kind regards,
                                          Bob
                                          • mitcorbM
                                            mitcorb
                                            At this time, LibFredo6 version 4.9b 19 May 13 is not listed as such in the Plugins Index yet, and the Plugin Store does not list it yet, either. I realize that the database keepers will update this soon, just wanted to report.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 113
                                            • 114
                                            • 30 / 114
