    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 71.9k Views 40 Watching
    • guanjinG Offline
      guanjin
      @rich o brien said:
      added to autoinstall
      Have tried, useless, depressed.
      You have the wrong?
        You have the wrong?
        Considering I installed it using autoinstall and it worked for me I think the problem maybe be at your end
        • CadFatherC Offline
          CadFather
          Guanjin, all works fine on my machine (win7 64 - english) - you need to find out whether it is the language settings (virtualbox in english?)
            lionk
            great work! 👍
            here is the Chinese language file, translated by 麦兜(miduee)&双鱼(shuangyu)
            Chinese lang file
            • guanjinG Offline
              guanjin
              @aerilius said:
              Oh, that could be difficult to find out 😉 The plugin sends all information about all your plugins into the dialog, and I don't have the same plugins as you. The error could be caused by something unknown.
              Hello:Aerilius
              Reinstall SketchUp successful trial, the conflicted file can not be found.
                danb
                Thankyou, I am on a mac and am sick of the toolbars floating all over the place and have been envious of Windows, this has instantly improved my workflow.
                best
                Dan
                Sketchup Pro 2019/20
                OSX 10.15.3
                Macbook Pro
                  I haven't seen that. I maybe haven't looked very hard, though. I got the tools I wanted onto a toolbar without any problems.
                    RickW
                    Has anyone else had problems with not all commands being available? I'm also missing a lot of icons that exist on other toolbars.
                    RickW
                    [www.smustard.com](http://www.smustard.com)
                    • zieiosZ Offline
                      zieios
                      Nice one
                      • ArisA Offline
                        Aris
                        Great plugin! very nice interface and very useful!
                        I would suggest (don't know if it is doable) giving the option to create dialog boxes as well.
                        Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                          kct3937
                          I followed Dave's instructions and the toolbars are showing up fine in my Mac version. However they are vertical toolbars only. Can I get them to set out horizontally?
                            It's a feature! 😄
                            Move the toolbar up to the top or down to the bottom temporarily and it'll swing around to horizontal. Then you can place it wherever you want.
                              kct3937
                              Thanks Dave…two thumbs up! 👍 👍 😆
                              Have you met a new friend each morning in the mirror, yet? ❓
                              Ken T
                                lionk
                                hi Aerilius,
                                some bugs:
                                1.there is a mismatch between toolbar name in the Editor and the real name.
                                2.when renaming the toolbar, ENTER will delete it instead of confirm the name...
                                3.i can't rename toolbars in double-byte characters.it will show like this.
                                the same problem happened to LaunchUp when i search DBCS strings.
                                4.if i close the toolbar and restart sketchup, i have to click 3 times in View menu to reopen it.
                                5.the position of the toolbar can't be saved.it troubled me so much...
                                  Aerilius
                                  Hi, thanks for the reports!
                                  As for 2. it looks like the "-" button has focus and accepts enter. I think I can make sure that this doesn't happen.
                                  4., 5. I have no control about that, I wished it worked in SketchUp as it should.
                                    Aerilius
                                    I could solve 1., 2. and 3., but I don't get an error when searching in LaunchUp for 面 or 测. Do you use the latest version of LaunchUp? Which version if Internet Explorer do you use?
                                      lionk
                                      yes,the version of LaunchUp is 1.0.11. and IE10.
                                        Aerilius
                                        Hi lionk,
                                        can you try ToolbarEditor 1.0.4? It should now remember toolbar names and display Chinese correctly.
                                          CadFather
                                          Thanks Aerilius - just in case this means something to you i get this quite often when i press apply.
                                          after this error, the toolbars i was in the process of creating are lost.
                                            Aerilius
                                            I don't get this and I can't see anything obvious around line 243. Also I don't use a any system calls.
                                            It could be related to SketchUp's skp protocol [1,2,3].
                                            Does this still occur with version 1.0.4, and if so, does it now show a different line?
                                            • 2 / 7
