    [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
    122 Posts 40 Posters 79.2k Views 40 Watching
    • L
      lionk
      @aerilius said:
      I could solve 1., 2. and 3., but I don't get an error when searching in LaunchUp for 面 or 测. Do you use the latest version of LaunchUp? Which version if Internet Explorer do you use?
      yes,the version of LaunchUp is 1.0.11. and IE10.
        Aerilius
        Hi lionk,
        can you try ToolbarEditor 1.0.4? It should now remember toolbar names and display Chinese correctly.
        • CadFatherC
          CadFather
          Thanks Aerilius - just in case this means something to you i get this quite often when i press apply.
          after this error, the toolbars i was in the process of creating are lost.
            Aerilius
            I don't get this and I can't see anything obvious around line 243. Also I don't use a any system calls.
            It could be related to SketchUp's skp protocol [1,2,3].
            Does this still occur with version 1.0.4, and if so, does it now show a different line?
              line250
              var message = messageQueue.shift();
                  if (!message) { ready = true; return; }
                  // Lock the status variable before sending the message.
                  // (because window.location is synchronous in IE and finishes before this
                  // function finishes.)
                  ready = false;
                  var id = message[0],
                      url = message[1],
                      data = message[2];
                  fillMessageField(id, data);
              line260
              IF 'id' OR more likely 'data' is somehow 'wrong' you get the error ? NULL ?
                Aerilius
                If data or id could be wrong, no Ruby callback would happen. If url were wrong, IE would navigate to a not existing site. Nothing that gives such an error.
                • CadFatherC
                  CadFather
                  only thing is i can't find any underlying pattern - unpredictable so far but i'll keep an eye on it (i'll have a go tonight with the new version. thanks!
                  also - i made a batch file to import export the registry settings but also i'm getting strange behaviour (when exporting) - will report more on this as it's great if one can save and share the same toolbar layout. overall it's getting better with each version, and the positions are kept more consistently.. great stuff!
                    Aerilius
                    By the way, how many toolbars did you have roughly?
                    The information that I found says that there could be another url length limit around 500 (officially urls in IE can be 2083 characters long). This should not anymore an issue in ToolbarEditor 1.0.4.
                    With this test in the Ruby Console we could confirm whether this caused the error:
                    count=0;w=UI;;WebDialog.new;w.set_html("<html></html>");w.add_action_callback("a"){|d,p| count=p.length if p.length>count};w.show{ w.execute_script("var s='';for(var i=0;i<3000;i++){ s+='b';window.location.href='skp;a@'+s;}") }
                    It then envokes an Internet Explorer error (I get "Could not complete the operation due to error 800700a").
                    When I then enter " count" into the Ruby console, I get 2077.
                    Do you get the same error that you got previously ("The data area passed to a system call is too small")?
                    • CadFatherC
                      CadFather
                      only had two - will run the check later on though just in case
                      • L
                        lionk
                        @aerilius said:
                        Hi lionk,
                        yes, toolbar names are remembered correctly!
                        but Chinese display not so well, still some encoding error if restart sketchup. 😞
                        e.g.
                        工具栏
                        正常
                        if input"具" and restart SU,ToolbarEditor will never open again.
                        btw, i think it need to limit toolbar name if someone input nothing(the toolbar wont show), too many words or punctuation.
                        • L
                          lionk
                          the toolbar icon can't remove sometimes. i don't know how it happen...
                          do duplicated icons permit to add?
                          • L
                            lionk
                            unicode characters in the registry is right all the time.
                            ruby can parse it but html or js not.is the value UTF8?
                              Aerilius
                              I could not reproduce the problem with the same toolbar names (工具栏, 正常, 具) after restarting SketchUp and opening the toolbar editor. I will continue try.
                              I updated the webdialog with improvements for higher dpi settings.
                              • cmeedC
                                cmeed
                                This looks great but I'm missing icons? any ideas.....
                                @rickw said:
                                Has anyone else had problems with not all commands being available? I'm also missing a lot of icons that exist on other toolbars.
                                cheers
                                c
                                  Do you have those icons on the existing original toolbars?
                                  • cmeedC
                                    cmeed
                                    Yes I do, they are all there.
                                      Aerilius
                                      Can you right-click on the missing icons and get the image file path? Maybe some commands return an unusual file path?
                                      Or it is a timing issue, maybe Fredo uses layz-loading techniques, or his tools take longer to load?
                                      • cmeedC
                                        cmeed
                                        im not sure how to do what you asked. right clicking the icons - in the toolbar? (nothing)
                                        right clicking in toolbarEditor? (nothing in the menu that come up that looked familiar)
                                        some of fredos icons work. is it possible to compare and find the answer?
                                        • L
                                          lionk
                                          hi Aerilius,
                                          maybe fredo6's methord can solve the UTF8 issue. fredo6's plugins show Chinese very well.
                                          • ely862meE
                                            ely862me
                                            What about these ones ?
                                            After choosing yes I get this :
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 2 / 7
