    How could i get realistic grass? Any suggestions?
    renderpluginsextensions
    34 Posts 9 Posters 5.3k Views 9 Watching
    • V
      valerostudio
      Fur plugin, but I would only use it in the foreground as good density grass will be very plo heavy.
      • Z
        Zylescozar19
        @rspierenburg said:
        To be honest I think that looks better than most non-post grass. There is a tutorial floating around these forums (check tutorial section) on how to place grass using photoshop as I think that would be your best bet for realism.
        Im not good with photoshop but if theres a tutorial step by step. I can do so. ๐Ÿ˜„
        Ok ill check it out. BTW Thanks.
        • Z
          Zylescozar19
          I did try Fur plugin - But still im not satisfy with the result. ๐Ÿ˜ž
          Here's the result with fur plug-in (see attached)
          Using fur plug-in the file becomes heavy and it takes more rendering time.
          Raw Render
          • V
            valerostudio
            Yeah, fur will dramatically make your file slower. Honestly, the floating car bothers me more than your grass. The best method for grass where you don't use fur or displacement is Photoshop as suggested.
            What component did you use for the grass in Fur? Use the crown feature paired with something like this http://sketchup.google.com/3dwarehouse/details?mid=dcd8fba2ac24d3b5bbb8a2bd32325576&prevstart=0
            or this one
            Error 404 (Not Found)!!1
            (sketchup.google.com)
            • HieruH
              Hieru
              davidh did a good mini-tutorial on this:
              viewtopic.php?f=351&t=42259&p=374885&hilit=+grass#p374885
              www.davidhier.co.uk
                Best and fastest is to make a mask out of the areas where the grass should be and just add it in post. Displacement won't look good - it just looks like spikes and eats lots of render time and memory. Fur isn't supported in VfS and it'd still be faster and better to do in post when you're not doing an animation.
                • andybotA
                  andybot
                  you can set up a material ID mask. Here is my tutorial for doing post-process grass in vray. Good luck.
                  http://charlottesvillearchitecturalrendering.com/?p=127
                  • Z
                    Zylescozar19
                    or this one
                    ๐Ÿ˜ฎ Hahaha! I didnt notice that the car was floating.
                    Uhh..I use this grass (edited)
                    grass patern.skp
                    • Z
                      Zylescozar19
                      Yeah! Your right Master Thomthom.
                      I'm having hard time with Photoshops as of now Fur will be the best option for me. ๐Ÿ’š
                      Thanks.
                      • Z
                        Zylescozar19
                        Hieru, Already see this tutorial but still i cant understand how to mask ๐Ÿ˜ณ
                        I guess really need to study this.
                        Anyways Thanks.
                        • Z
                          Zylescozar19
                          I guess a Video tutorial will do that would be the easiest way ๐Ÿคฃ
                          • Z
                            Zylescozar19
                            Andy, This will be great.
                            I'll try to study this method.
                            Thanks a lot.
                            • Z
                              Zylescozar19
                              Sir andy. I saw this grass of yours. Can i ask where did u get this? i mean is this a SU model? can i download it?
                              • V
                                valerostudio
                                If you're not using MatID channels and Photoshop then you are not taking advantage of the most powerful tool in a render artists kit. Learn as soon as you can!
                                • andybotA
                                  andybot
                                  Sorry - that's done in vray for blender โ˜€
                                  • broomstickB
                                    broomstick
                                    That's funny: an unofficial version of vray works better than the official version for Sketchup. Chaosgroup needs to address these problems..
                                    • andybotA
                                      andybot
                                      Well, when sketchup gets particle systems, modifiers, etc., maybe it'll get to the level of Blender... ๐Ÿคฃ
                                      oh yeah, and when SU goes to 64bit ๐Ÿ’š
                                      • HieruH
                                        Hieru
                                        In which case Pixel Flakes have a good one that includes the project files (so you can work along):
                                        www.pixelflakes.com/tutorial/5-concrete-cliff/
                                        For those of us who already know our way around PS, masks and material ID, this time lapse video is superb:
                                        www.pixelflakes.com/tutorial/8-1-hour-challenge/
                                        www.davidhier.co.uk
                                        • Z
                                          Zylescozar19
                                          ๐Ÿ˜Ž yea... thanks
                                          • Z
                                            Zylescozar19
                                            Thank you so much for the help!!!
