How could i get realistic grass? Any suggestions?
Could anyone help me out how can i achieve realistic grass? (Not displacement)
Here is the image that I've rendered using SU8 Pro.
To be honest I think that looks better than most non-post grass. There is a tutorial floating around these forums (check tutorial section) on how to place grass using photoshop as I think that would be your best bet for realism.
Fur plugin, but I would only use it in the foreground as good density grass will be very plo heavy.
Im not good with photoshop but if theres a tutorial step by step. I can do so.
Ok ill check it out. BTW Thanks. -
I did try Fur plugin - But still im not satisfy with the result.
Here's the result with fur plug-in (see attached)
Using fur plug-in the file becomes heavy and it takes more rendering time.
Yeah, fur will dramatically make your file slower. Honestly, the floating car bothers me more than your grass. The best method for grass where you don't use fur or displacement is Photoshop as suggested.
What component did you use for the grass in Fur? Use the crown feature paired with something like this http://sketchup.google.com/3dwarehouse/details?mid=dcd8fba2ac24d3b5bbb8a2bd32325576&prevstart=0
or this one
http://sketchup.google.com/3dwarehouse/details?mid=7e8b4af7f1f6f64a6a2979228046d9f9&prevstart=0
davidh did a good mini-tutorial on this:
Best and fastest is to make a mask out of the areas where the grass should be and just add it in post. Displacement won't look good - it just looks like spikes and eats lots of render time and memory. Fur isn't supported in VfS and it'd still be faster and better to do in post when you're not doing an animation.
you can set up a material ID mask. Here is my tutorial for doing post-process grass in vray. Good luck.
or this one
Hahaha! I didnt notice that the car was floating.
Uhh..I use this grass (edited)
Yeah! Your right Master Thomthom.
I'm having hard time with Photoshops as of now Fur will be the best option for me.
Thanks. -
Hieru, Already see this tutorial but still i cant understand how to mask
I guess really need to study this.Anyways Thanks.
I guess a Video tutorial will do that would be the easiest way
Andy, This will be great.
I'll try to study this method.
Thanks a lot. -
Sir andy. I saw this grass of yours. Can i ask where did u get this? i mean is this a SU model? can i download it?
If you're not using MatID channels and Photoshop then you are not taking advantage of the most powerful tool in a render artists kit. Learn as soon as you can!
ThanksSorry - that's done in vray for blender
That's funny: an unofficial version of vray works better than the official version for Sketchup. Chaosgroup needs to address these problems..
Well, when sketchup gets particle systems, modifiers, etc., maybe it'll get to the level of Blender...
oh yeah, and when SU goes to 64bit
In which case Pixel Flakes have a good one that includes the project files (so you can work along):
www.pixelflakes.com/tutorial/5-concrete-cliff/
For those of us who already know our way around PS, masks and material ID, this time lapse video is superb:
