    [Plugin] ToolbarEditor (1.1.2) โ€“ updated 08.06.2014
    122 Posts 40 Posters 62.3k Views 40 Watching
      Aerilius
      A drag&drop editor for creating custom toolbars from plugin's buttons.
      PayPalButton
      http://sketchucation.com/plugin/942-ae_toolbareditor
      Version: 1.1.2
      Date: 08.06.2014
      Requirements: SketchUp 8 M1+, IE8+
      Usage:
      • Menu 'Window' โ†’ 'Toolbar Editor'
      • Click the "+" button on the left to create a new toolbar. You can rename toolbars or remove them ("-" button).
      • Click the "+" button on the right to create a new button. You can then write your own Ruby commands or paste a piece of Ruby code that you found on the forums.
      • Drag items from the list of available buttons to the left into a toolbar panel. You can rearrange the buttons, move them into other toolbars or remove them by dropping them out to the right.
      • The list can be filtered.
      • Don't forget to click the "Apply" button to save once you are happy with the changes. Not all changes can be applied immediately, some only on next start of SketchUp.
        This looks like a pretty cool plugin. Unfortunately on my MacBook, some of the icons won't stay on the left when I drag them. One in particular is the Fillet tool from TIG's 2D Tools. Is there something about some tools that will make this not work?
        Edit: After inserting a tool from the BZ_Spline tools, I tried the 2D Fillet again and it went. Weird.
        • renderizaR Offline
          renderiza
          Thanks for sharing this for free! Hope you get lots of donations...you deserve it! ๐Ÿ‘
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          • panixiaP Offline
            panixia
            i don't know if i'm doing it right, but it refuses to add any tools i tried (i also tried with bezier toolbar tools ๐Ÿ˜‰ ) but unfortunately when i drag the icon from right to left and relase it, it comes back to the right and nothing happens.. am i missing something? ๐Ÿ˜•
            edit. it looks to work now.. maybe i was relasing the items the wrong way!
              Aerilius
              The droppable area is only on the top.
              Other weird behavior can be because it is not native drag&drop (but JavaScript/jQuery). Sometimes it's necessary to hover between two icons until jQuery finds the insertion point and opens a gap.
              I'll add more visual feedback.
              • panixiaP Offline
                panixia
                ๐Ÿ‘ once used to it the dragging and dropping is OK!!
                the major downside is that everytime you open/close sketchup the toolbars mess up!! ๐Ÿ˜ฒ
                • panixiaP Offline
                  panixia
                  great tool anyway, thank you! i will try to make only a couple of big toolbars so it's faster to rearrange them.. do you think this can be fixed in the future? or it's a sketchup limitation?
                  • CadFatherC Offline
                    CadFather
                    woooo... ..simply too stunned to comment.... ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ˜
                    PS
                    ..Aerilius for President (of Italy please)!
                    • panixiaP Offline
                      panixia
                      ๐Ÿคฃ
                        renderiza
                        PS
                        CadFather you deserve some credit as well since you started this revolution of toolbar plugins...So you can be President of a country as well ๐Ÿ˜†
                          CadFather
                          well.. that's true... ok, i'll do the brain and Aerilius the arms.. ๐Ÿ˜‰ ๐Ÿ˜†
                          actually this plugin has got to be the best of 2013....just too good...i can imagine a whole planet is going to redesign their toolbars layout in the next few days...incredible......
                          makes you wonder...if it takes Aerilius a week to create this beauty...what are Su developers doing in boulder colorado...skiing no doubt..! ๐Ÿ˜‰
                          [removing by dropping the icon to the right doesn't seem to work on my machine - edit: working now that i restarted and re-edited the toolbar]
                          • guanjinG Offline
                            guanjin
                            Aprire lo strumento il seguente errore.
                              Aerilius
                              Oh, that could be difficult to find out ๐Ÿ˜‰ The plugin sends all information about all your plugins into the dialog, and I don't have the same plugins as you. The error could be caused by something unknown.
                              • Rich O BrienR Online
                                added to autoinstall
                                • guanjinG Offline
                                  guanjin
                                  Have tried, useless, depressed.
                                  You have the wrong?
                                    You have the wrong?
                                    Considering I installed it using autoinstall and it worked for me I think the problem maybe be at your end
                                      CadFather
                                      Guanjin, all works fine on my machine (win7 64 - english) - you need to find out whether it is the language settings (virtualbox in english?)
                                        lionk
                                        great work! ๐Ÿ‘
                                        here is the Chinese language file, translated by ้บฆๅ…œ(miduee)&ๅŒ้ฑผ(shuangyu)
                                        Chinese lang file
                                        • guanjinG Offline
                                          guanjin
                                          Hello๏ผšAerilius
                                          Reinstall SketchUp successful trial, the conflicted file can not be found.
                                            danb
                                            Thankyou, I am on a mac and am sick of the toolbars floating all over the place and have been envious of Windows, this has instantly improved my workflow.
                                            best
                                            Dan
                                            Sketchup Pro 2019/20
                                            OSX 10.15.3
                                            Macbook Pro
                                            • 4 / 7
