    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      Missy_X
      Ok, uninstalled and reinstalled Sketchup
      Installed Libfredo 4.7c : seemed fine at first
      Then went on with installing the sketchucation plugin store : bugsplat
      Removed plugin store : still bugsplat
      Removed libfredo 4.7c : sketchup works again
      Installed all my plugins except libfredo 4.7c : works
      Installed libfredo 4.7c again : bugsplat
      Uninstalled libfredo 4.7c and installed 4.7a : works
      I think something is wrong with 4.7c checking for updates of other plugins or something like that ?
        Missy_X
        Nevermind, same thing is happening with 4.7a now too all the sudden .. and sketchup works again when i remove it. I don't get it .. fresh install of sketchup with just libfredo works, anything else i add : bugsplat until i delete libfredo.
        • fredo6F Offline
          @Missy_X
          Do you run SU on a Mac or on Windows?
            Missy_X
            Windows 7, administrator rights
            • TIGT Online
              Select the Plugins folder icon: right-click > context-menu > Properties > Security > Edit.
              Ensure everyone in the list has FULL rights...
              OK to apply and close...
              Being an 'admin' doesn't guarantee that the Plugins folder is [fully] writable for you - this can cause subtle issues...
                Missy_X
                Checked and everyone has full rights
                  Missy_X
                  OK nevermind, somehow rebooting my pc fixed the problem lol (yes yes, first thing everyone should try when a pc acts weird, i know ! lol)
                  • fredo6F Offline
                    Glad you recover the situation.
                    However the problem you encountered is puzzling.
                      Missy_X
                      Yes i know, i never had it happen before and it doesn't make any sense. Anyway, thank you Fredo and TIG for trying to help. πŸ˜„ All this made me realize how addicted i am to Sketchup and all the plugins you guys make. Half a day with Sketchup not working and i was going completely nuts. πŸ˜†
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v4.8a - 25 Apr 13
                        LibFredo6 4.8a is a major release dedicated to TopoShaper 1.0 (a script to generate terrain from contours).
                        • W Offline
                          Woody Longspike
                          @antuan said:
                          I had Tools on surface, Fredo Scale and other Fredo plugins installed in SU 7.1 and all was working OK. Today I installed SU 8, downloaded last versions of same plugins and everything worked OK until I tried to open Default Parameters dialog. It simply didn't open for any of the plugins... I reinstall plugins, even reinstall SU... nothing, the Default Parameters doesn't open. Any idea to solve that?
                          Thank you in advance.
                          I seem to be experiencing the same mysterious problem. Did clean reinstall of latest SU, and only additional plugin folder plugin. Then installed LibFredo6-v4.8, & TOSv1.8 in newly made additional folder everything seems to work except Default Parameter window still doesn't open. Made new isolated additional folder on drive E:\ (an SD card) then installed LibFredo6-v4.8, & Latest Round Corner plugin there. It works but still no Default Parameter Dialog window. Will post all kinds of screenshots if need be, let me know what you need from me. O.S. = Windows XP 32 home version, Thanks in advance.
                            This sounds like a case of insufficient administrative rights to the Plugins folder. Have you made sure that you have, under your login, all permissions granted for the Plugins folder?
                            This has been covered repeatedly in this thread.
                            • W Offline
                              Woody Longspike
                              Yes to the best of my ability and knowledge it appears the rights are set correctly. I do wonder if my comptuer retains these settings though.
                                You ought to be able to check by looking at the security settings. Post a screen shot of that and we'll take a look.
                                • W Offline
                                  Woody Longspike
                                  When I open properties of plugin folder I see this.I click read only green box , then click apply, then select tick box to apply to all subfolders and files, then click ok.
                                  When ever I've gone back to check, the green box is back, but its not a checkmark.
                                  • W Offline
                                    Woody Longspike
                                    and here it is checked
                                    I had to manually click to show the check mark.
                                    • TIGT Online
                                      Those settings are NOT what was meant.
                                      You must have admin rights - given them to yourself in the Users Control Panel.
                                      Then there is tab under Properties > Security...
                                      Click the Edit button and give everyone on the list FULL rights...
                                      • W Offline
                                        Woody Longspike
                                        Hey TIG thanks for your reply I'm on Windows XP home 32 bit SP3. There`s no properties/security settings tab, thats a windows vista or 7 & up thing. I do have computer admin settings which I always log in as admin.
                                        • TIGT Online
                                          XP !
                                          Then you need to do it another way...
                                          http://support.microsoft.com/kb/308419
                                          http://www.ehow.com/how_2383435_set-permissions-windows-xp.html
                                          • W Offline
                                            Woody Longspike
                                            If simple file sharing is enabled, the simple file sharing user interface is displayed instead of the Security and Sharing tabs. By default, this new user interface is implemented in both Windows XP Home Edition and Windows XP Professional if you are working in a workgroup. If you disable simple file sharing, the classic Security and Sharing tabs appear, and you can specify which users and groups have access to shared folders on your computer.
                                            Note You cannot disable simple file sharing in Windows XP Home Edition.
                                            Aha...Thanks Fredo6, TIG, & Dave R. I was under the impression Additional Plugin Folder plugin was a work around this problem. Apparently after reading many support articles and threads here, there, and everywhere else, Windows XP Home has failed me 😠 http://support.microsoft.com/kb/307874 no fix or work around available from my understanding. Thanks again for your help.
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 109
                                            • 110
                                            • 33 / 110
