[Plugin] Layer manager
Dear Dider,
Your layer manager is really great.
I could't imagine sketching without it.The first time when I used your plugin I realized that some layers are not managed. After experencing with different versions of the plugin (V5, V6, V21) everything worked perfect for me. Though I was wondering why some symbols on the toolbar were twice available.
Now when I set up Sketchup on a new machine I installed only the newest version (V21 isn't it?). On the virgin installation the troubles with some layers were back.
After some new experencing I found out:
Layers containing German letters (probably UNICODE?) in their name are not saved or restored.
If "display layer config" is pressed the plugin shows that there are layers in the model which are not in the config. The same layers (but for each special character one caracter shorter) are listed in the saved layer config but not in model. (see attached screenshot)Now I've tested this on several different machines (2GHz Dualcore WinXP Pro, 2,2GHz Core2Duo WinXP Emb MU, 2,8GHz Core I-7 Win 7 Pro 32bit, 3,3GHz Xeon Win7 Pro 64). Everywere the same behavior.
When I compared what was different to my very first setup I found out that the additional symbols came from the layer_manager_extension_v5.rb. In this combination the names of "German" layers are displayed shortened by the number of special characters too but saving and restoring commands (from version 21) work perfectly.
Dear Dider. Please find this little annoying (German) bug and fix it.
Best regards
Yes this is a "unicode" bug. I've got the same behaviour with french letters like é,è,à,ü,ê, and so on.
I'll have a look at it when time permits.
Regards, -
Hello all,
I have a question...
Am I looking for a plugin to turn one major layer group or component with different layers and groups inside to one layer!?!?! I don't know if I did right the question...
Like everything inside this major group or component (including sub-groups, lines, faces with different layers) will turn to one layer (major layer)
I'm using the old version of LM_v6 and looks like don't have a way to do it. I don't know if this new version LM_v21 allow me to do that...
Thanks -
Can I save more than one layer state. I am asked what layer state I want to over right when I try to save a new layer state. I do not get an option not to over right a layer state.
Nice tools.
Walter -
@seasdes:
Yes, you can save as many layer states as you want.
Try to overwrite any of your previously saved layer state and see if it is still there.
I guess this is a bug but the layer state you overwrite will not be overwritten.
Regards, -
Ken,
I'm not sure if this has been answered, I didn't read the entire thread, but have you gone to View> Toolbars> Save Toolbar Positions before you install? I used to have a similar problem, but once I save a toolbar position set up all I have to do is run through the process of View> Toolbars> Restore Toolbar Positions, and I'm good to go. Have you tried that? Or does this particular plugin just kill any saved toolbar locations when its installed?
Just curious, and I hope that helps!
Mr. Bur
Thanks for you very useful script.
Just a side note, installation of your script has re-arranged all my toolbars. This is nothing new, it happens with every script installation that adds a new toolbar. So I have to re-arrange the menus, and usually they are not in the same order, and another learning curve is required.
But this time, I have outwitted this darn re-organizational mess. I took a JPG screen snap shot of the toolbars before installation. Imported this JPG into a Sketchup model and saved the model as SketchupToolbars. So now I just load this program and re-arrange all the tools bars as the JPG indicates. Now no new learning curve.
Mr. Bur again thanks for the script.
Ken
Thanks, Didier Bur...!!!
Is it also possible to group layers into groups/folders? Just like in Photoshop?
@Maxvector9
No, AFAIK -
Hi Didier, this is one of my most used plugins, many thanks!
I'm wondering if you could add a dialogue box pop up option for the second icon,'Set Layer of clicked object current and isolated' to turn off all layers 'EXCEPT LAYER 0'?
I almost never change current layer from Layer 0 as I have been courtout before drawing geometry on another layer rather than 0.Is this possible?
Many thanks,
Hi utiler,
Attached RBS will do it. Unzip and overwrite your layer_manager.rbs file in your Layer Manager folder. That's it, enjoy !
Thank you Didier, very much appreciated!
Hi, Does anyone know of a tutorial video for this plugin. I have downloaded the pdf manual but cant work out how to use this plugin. I want to transfer all the layer states currently in the default sketchup layer dialogue box to this new layer manager. can anyone help me get started?
Luke
Is this plugin compatible with 2014? It's one of my favorites!
It should be.
Try it...Are you on MAC ?
I think the MAC version is more 'beta-like' ? -
Tooltips for toolbar icons on hover ?!
I am new to this plugin and am having trouble remembering what each icon is supposed to represent.
Does this plugin show tooltips on hover? and if so I am wondering why I can't see any.Great plugin and thanks for sharing
