    [Plugin] Layer manager
    54 Posts 32 Posters 69.1k Views 32 Watching
    • Didier BurD Offline
      Didier Bur
      @seasdes:
      Yes, you can save as many layer states as you want.
      Try to overwrite any of your previously saved layer state and see if it is still there.
      I guess this is a bug but the layer state you overwrite will not be overwritten.
      Regards,
      DB
        tedvitale
        Ken,
        I'm not sure if this has been answered, I didn't read the entire thread, but have you gone to View> Toolbars> Save Toolbar Positions before you install? I used to have a similar problem, but once I save a toolbar position set up all I have to do is run through the process of View> Toolbars> Restore Toolbar Positions, and I'm good to go. Have you tried that? Or does this particular plugin just kill any saved toolbar locations when its installed?
        Just curious, and I hope that helps!
        Mr. Bur
        Thanks for you very useful script.
        Just a side note, installation of your script has re-arranged all my toolbars. This is nothing new, it happens with every script installation that adds a new toolbar. So I have to re-arrange the menus, and usually they are not in the same order, and another learning curve is required.
        But this time, I have outwitted this darn re-organizational mess. I took a JPG screen snap shot of the toolbars before installation. Imported this JPG into a Sketchup model and saved the model as SketchupToolbars. So now I just load this program and re-arrange all the tools bars as the JPG indicates. Now no new learning curve.
        Mr. Bur again thanks for the script.
        Ken
        Ted Vitale
        3D Artist and designer
        Sketchup 2013 Pro
        • N Offline
          nitav
          Thanks, Didier Bur...!!!
            maxvector9
            Is it also possible to group layers into groups/folders? Just like in Photoshop?
              Didier Bur
              @Maxvector9
              No, AFAIK 😞
              DB
              • utilerU Offline
                utiler
                Hi Didier, this is one of my most used plugins, many thanks!
                I'm wondering if you could add a dialogue box pop up option for the second icon,'Set Layer of clicked object current and isolated' to turn off all layers 'EXCEPT LAYER 0'?
                I almost never change current layer from Layer 0 as I have been courtout before drawing geometry on another layer rather than 0.
                Is this possible? πŸ‘
                Many thanks,
                Just Curious...
                  Didier Bur
                  Hi utiler,
                  Attached RBS will do it. Unzip and overwrite your layer_manager.rbs file in your Layer Manager folder. That's it, enjoy !
                  layer_manager_mod.zip
                  DB
                  • utilerU Offline
                    utiler
                    Thank you Didier, very much appreciated!
                    Just Curious...
                    • W Offline
                      whitelock
                      Hi, Does anyone know of a tutorial video for this plugin. I have downloaded the pdf manual but cant work out how to use this plugin. I want to transfer all the layer states currently in the default sketchup layer dialogue box to this new layer manager. can anyone help me get started?
                      Luke
                        Phil Rader AIA
                        Is this plugin compatible with 2014? It's one of my favorites!
                        http://www.philrader.com
                        • TIGT Online
                          It should be.
                          Try it... πŸ˜„
                          Are you on MAC ?
                          I think the MAC version is more 'beta-like' ?
                            jwhida
                            Tooltips for toolbar icons on hover ?!
                            I am new to this plugin and am having trouble remembering what each icon is supposed to represent.
                            Does this plugin show tooltips on hover? and if so I am wondering why I can't see any.
                            Great plugin and thanks for sharing
                              TimInAZ60
                              Extremely useful extension, THANK YOU.
                              For the next update, please have a look at the Show/Isolate/Hide... layer-by-Filter. I have "Existing filters:' from prior actions but when selection one of them from the drop-down box, it doesn't populate the "Filter string to * layers" entry at the bottom of the window. I have to re-type the filter string each time. Can't use the prior Existing filters.
                              I'm using SketchUp Make 2016 for compatibility with my PCs.
                              Thanks.
                              • 3 / 3
