    [Plugin]Extend Trim Faces.rb(Mar27,2013.)
    28 Posts 19 Posters 54.0k Views 19 Watching
      First bug? 😉
      Seems there is more and not the good trimed face 😉
      testtak.skp
      • srxS Offline
        srx
        👍 This is very useful. Deserves shortcut! I'd like to assign the same shortcut to this function and to 2d adjust (from 2d tools) which is doing the same for lines. So, by selecting lines it is adjusting lines, by selecting edges and faces it is adjusting faces...Please!
        www.saurus.rs
        • PixeroP Offline
          Pixero
          Thanks! 👍
          • srxS Offline
            srx
            Working great! Very SU-like concept. Thank you very much!
            www.saurus.rs
              @srx said:
              :thumb: This is very useful. Deserves shortcut! I'd like to assign the same shortcut to this function and to 2d adjust (from 2d tools) which is doing the same for lines. So, by selecting lines it is adjusting lines, by selecting edges and faces it is adjusting faces...Please!
              You can set your own shortcuts to any native OR loaded tool. Open Preferences > Shortcuts and filter the list to help you find the entry. Select it and set a key-combo... Provided that a tool has a menu entry it is shortcut-able...
              Some tools only appear in the list if a 'context' is met.
              So for example, if you want to shortcut the 'Reverse' tool that flips a face over [available in the context-menu if you have selected at least one face] you must have a face selected when you open Preferences > Shortcuts... then 'Reverse' is on the list... This is a very useful shortcut, as is 'Orient'...
                rv1974
                great tool, tak2hata! It deserves shortcut 👍
                Thank you.
                P.S. Humble request: 'extend to the edge' feature
                • srxS Offline
                  srx
                  TIG, thank you for this. I guess I was misunderstood because of my not so good English. I know how to set shortcut, already done it...but what I'd had in mind was to make 2dadjust from your 2dtools 😄 integrated with this 3d adjustment as one plugin. For now I have ALT+X for 2Dadjust, and SHIFT+X for this, say "3Dadjust". But it would be more effective to have it under one shortcut, and the action would smartly depend on what is selected - 2D adjust for selected 2D elements (lines), 3D adjust for selected 3D elements (faces). Now when I think they are 1D and 2D elements, what we are missing is 3D adjust (maybe from Didiers Projections plugin) for adjusting solids. 😄
                  www.saurus.rs
                  • sumasterS Offline
                    sumaster
                    HI tak2hata sir,
                    again great tool you build NICE work . . . .
                    THANK YOU,
                    Thank you,
                    SUmaster
                    • ElibjrE Offline
                      Elibjr
                      Wow Thanks! it's like doing 2D CAD in 3d. This should be in the base commands! Extremely useful!
                      • simon le bonS Offline
                        simon le bon
                        Simple and useful.
                        "Very SU-like concept" -> +1
                        another nice one.
                        downloaded.
                        thank you a lot Tak2Hata
                        ++simon
                          jpalm32
                          Nice. This should help will fix my screw ups.
                            Kiey
                            Great tool, it's useful.
                              Trogluddite
                              Very nice plugin 😄
                              I think, this will save me much time messing around with construction lines and the protactor tools.
                              Many Thanks.
                                designforgood
                                This looks to be a very helpful plugin. Thank you tak2hata!
                                • demD Offline
                                  dem
                                  Thanks! Great plugin! But one nuance. Does not always get on the right plane when I click near the edge. Is it difficult to make the backlight of planes when cursor is on the small distance near the edge?)
                                    tak2hata
                                    Hi,dem.
                                    I think it difficult.
                                    But I want it, too.
                                    I will consider it well.
                                    Thanks All!
                                    by TAK2HATA
                                    • I Offline
                                      ishining
                                      very easy to use, thks
                                        rv1974
                                        tak2hata, is it possible to add those standard SU\Acad selection options:
                                        with Shift- select additional areas to be stretched
                                        with Alt- DEselect affected areas
                                        with Cnrl- precisely select or deselect (Cnrl+Alt) separate points.
                                        Thanks.
                                          Ben Ritter
                                          Awesome. Thank you again for sharing the fruits of your talent.
                                          • sumasterS Offline
                                            sumaster
                                            I am using this plugin every day and I have some difficulty in a single selection. Each edge select and click one surface, it's wasting modeling time can you change single click to multiple edges selection or viewport selections. . . .
                                            Selection
                                            Thank you,
                                            SUmaster
