πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin]Extend Trim Faces.rb(Mar27,2013.)
28 Posts 19 Posters 49.8k Views
    tak2hata
    I upload Sketchup Plugin"Extend Trim Faces" to here.
    Extend/Trim 2 Faces each other.
    General disclaimer
    I MAKES NO GUARANTEE OF VALIDITY about this script.
    Please use this script at your own risk.
    DONWLOAD:
    Get the latest version from the PluginStore:
    http://sketchucation.com/resources/pluginstore?pln=Extend_Trim_Faces
    or AutoInstall from within SketchUp using the SketchUcation Tools
    Enjoy!
    by TAK2HATA
      Seems a cool one! β˜€
        First bug? πŸ˜‰
        Seems there is more and not the good trimed face πŸ˜‰
        testtak.skp
          srx
          πŸ‘ This is very useful. Deserves shortcut! I'd like to assign the same shortcut to this function and to 2d adjust (from 2d tools) which is doing the same for lines. So, by selecting lines it is adjusting lines, by selecting edges and faces it is adjusting faces...Please!
          www.saurus.rs
            Pixero
            Thanks! πŸ‘
              srx
              Working great! Very SU-like concept. Thank you very much!
              www.saurus.rs
                @srx said:
                :thumb: This is very useful. Deserves shortcut! I'd like to assign the same shortcut to this function and to 2d adjust (from 2d tools) which is doing the same for lines. So, by selecting lines it is adjusting lines, by selecting edges and faces it is adjusting faces...Please!
                You can set your own shortcuts to any native OR loaded tool. Open Preferences > Shortcuts and filter the list to help you find the entry. Select it and set a key-combo... Provided that a tool has a menu entry it is shortcut-able...
                Some tools only appear in the list if a 'context' is met.
                So for example, if you want to shortcut the 'Reverse' tool that flips a face over [available in the context-menu if you have selected at least one face] you must have a face selected when you open Preferences > Shortcuts... then 'Reverse' is on the list... This is a very useful shortcut, as is 'Orient'...
                  rv1974
                  great tool, tak2hata! It deserves shortcut πŸ‘
                  Thank you.
                  P.S. Humble request: 'extend to the edge' feature
                    srx
                    TIG, thank you for this. I guess I was misunderstood because of my not so good English. I know how to set shortcut, already done it...but what I'd had in mind was to make 2dadjust from your 2dtools πŸ˜„ integrated with this 3d adjustment as one plugin. For now I have ALT+X for 2Dadjust, and SHIFT+X for this, say "3Dadjust". But it would be more effective to have it under one shortcut, and the action would smartly depend on what is selected - 2D adjust for selected 2D elements (lines), 3D adjust for selected 3D elements (faces). Now when I think they are 1D and 2D elements, what we are missing is 3D adjust (maybe from Didiers Projections plugin) for adjusting solids. πŸ˜„
                    www.saurus.rs
                    • sumasterS Offline
                      sumaster
                      HI tak2hata sir,
                      again great tool you build NICE work . . . .
                      THANK YOU,
                      Thank you,
                      SUmaster
                      • ElibjrE Offline
                        Elibjr
                        Wow Thanks! it's like doing 2D CAD in 3d. This should be in the base commands! Extremely useful!
                        • simon le bonS Offline
                          simon le bon
                          Simple and useful.
                          "Very SU-like concept" -> +1
                          another nice one.
                          downloaded.
                          thank you a lot Tak2Hata
                          ++simon
                            jpalm32
                            Nice. This should help will fix my screw ups.
                              Kiey
                              Great tool, it's useful.
                                Trogluddite
                                Very nice plugin πŸ˜„
                                I think, this will save me much time messing around with construction lines and the protactor tools.
                                Many Thanks.
                                  designforgood
                                  This looks to be a very helpful plugin. Thank you tak2hata!
                                  • demD Offline
                                    dem
                                    Thanks! Great plugin! But one nuance. Does not always get on the right plane when I click near the edge. Is it difficult to make the backlight of planes when cursor is on the small distance near the edge?)
                                    • topic:timeago-later,25 days
                                      tak2hata
                                      Hi,dem.
                                      I think it difficult.
                                      But I want it, too.
                                      I will consider it well.
                                      Thanks All!
                                      by TAK2HATA
                                      • topic:timeago-later,9 months
                                      • I Offline
                                        ishining
                                        very easy to use, thks
                                        • topic:timeago-later,2 months
                                          rv1974
                                          tak2hata, is it possible to add those standard SU\Acad selection options:
                                          with Shift- select additional areas to be stretched
                                          with Alt- DEselect affected areas
                                          with Cnrl- precisely select or deselect (Cnrl+Alt) separate points.
                                          Thanks.
                                          1 / 2
