    [REQ] weird effect in vray
    renderpluginsextensions
    13 Posts 5 Posters 1.0k Views 5 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Renders fine for me... Weird
      • tibetT Offline
        tibet
        i can´t believe my eyes man!
        when i repeate it with a different computer (+ better graphic card) everything is fine
        that´s very strange, because i´ve done so many times with my laptop, and every time
        accompanied by the same weird effect.
        i´d be grateful for any tips or experiences with the similar anomalies.
        thanks!
        SU 2015 Pro on Win10 x64
        • V Offline
          valerostudio
          What version of V-Ray?
          I've never seen this one before. Very odd.
          • andybotA Offline
            andybot
            It's what I figured. It looks like crazy displacement. You have a displacement map selected that is saved locally to your laptop. Uncheck the displacement in your material and you should be good to go.
            • tibetT Offline
              tibet
              hi andybot,
              thanks a lot for your valuable reply, it think you´re on the right track.
              best of luck!
              ...wondering why it shows 100% , when some part are still waiting to be finished.
              is there any info about the state of rendering process ( in proggress/finished/error )
              i´ve been waiting for over 20minutes without any change. 😮
              http://img.sceper.eu/images/rpWAM.jpg
              2.skp
                jiminy-billy-bob
                The "100%" is just the zoom in the FrameBuffer. If you scroll it'll change.
                • andybotA Offline
                  andybot
                  make sure you've unchecked displacement in your material. Why would you need displacement on that piece? Is there some effect you are trying to produce?
                  • tibetT Offline
                    tibet
                    hi andybot,
                    i´ve repeat it today, and get the same weird result , even dispacement setting is
                    unchecked.
                    i never use displacement for this rendering.
                    i´ve even updated graphic card driver with no results, maybe some gremlins are playing in
                    my wet laptop.
                    (model - test.skp)
                    http://img.sceper.eu/images/CozFV.jpg
                    • chonC Offline
                      chon
                      Really strange ???
                      I rendered a vew with your settings and :
                      Which version of VRay do you use ?
                        jiminy-billy-bob
                        You have a displacement map in your material. Uncheck it in the material options, not in the general options.
                        • tibetT Offline
                          tibet
                          yes, you´re 100% right.
                          displacement was checked by default, not by me...
                          I swear I didn't do it!
                          http://img.sceper.eu/images/hH3sI.jpg
                          • tibetT Offline
                            tibet
                            hi chon,
                            i´t s great, at the end i´ve found it!
                            man, i´m glad that was a trivial problem 😍
                            thank you all you guys !
                            http://img.sceper.eu/images/SkvJI.jpg
