    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [REQ] weird effect in vray
    renderpluginsextensions
    13 Posts 5 Posters 836 Views 5 Watching
    • tibetT Offline
      tibet
      hi,
      i“ve encountered a weird effect during v-ray rendering
      and have no idea of it“s origin.
      i“d be very grateful for any tips or suggestions how to fix it.
      thanks!
      (sketchup is okey)
      http://img.sceper.eu/images/ntzU.jpg
      (v-ray isn“t okey)
      http://img.sceper.eu/images/kOgmr.jpg
      test.skp
      SU 2015 Pro on Win10 x64
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Renders fine for me... Weird
        • tibetT Offline
          tibet
          i can“t believe my eyes man!
          when i repeate it with a different computer (+ better graphic card) everything is fine
          that“s very strange, because i“ve done so many times with my laptop, and every time
          accompanied by the same weird effect.
          i“d be grateful for any tips or experiences with the similar anomalies.
          thanks!
          • V Offline
            valerostudio
            What version of V-Ray?
            I've never seen this one before. Very odd.
            • andybotA Offline
              andybot
              It's what I figured. It looks like crazy displacement. You have a displacement map selected that is saved locally to your laptop. Uncheck the displacement in your material and you should be good to go.
              • tibetT Offline
                tibet
                hi andybot,
                thanks a lot for your valuable reply, it think you“re on the right track.
                best of luck!
                ...wondering why it shows 100% , when some part are still waiting to be finished.
                is there any info about the state of rendering process ( in proggress/finished/error )
                i“ve been waiting for over 20minutes without any change. 😮
                http://img.sceper.eu/images/rpWAM.jpg
                2.skp
                  jiminy-billy-bob
                  The "100%" is just the zoom in the FrameBuffer. If you scroll it'll change.
                  • andybotA Offline
                    andybot
                    make sure you've unchecked displacement in your material. Why would you need displacement on that piece? Is there some effect you are trying to produce?
                    • tibetT Offline
                      tibet
                      hi andybot,
                      i“ve repeat it today, and get the same weird result , even dispacement setting is
                      unchecked.
                      i never use displacement for this rendering.
                      i“ve even updated graphic card driver with no results, maybe some gremlins are playing in
                      my wet laptop.
                      (model - test.skp)
                      http://img.sceper.eu/images/CozFV.jpg
                      • chonC Offline
                        chon
                        Really strange ???
                        I rendered a vew with your settings and :
                        Which version of VRay do you use ?
                          jiminy-billy-bob
                          You have a displacement map in your material. Uncheck it in the material options, not in the general options.
                          • tibetT Offline
                            tibet
                            yes, you“re 100% right.
                            displacement was checked by default, not by me...
                            I swear I didn't do it!
                            http://img.sceper.eu/images/hH3sI.jpg
                            • tibetT Offline
                              tibet
                              hi chon,
                              i“t s great, at the end i“ve found it!
                              man, iĀ“m glad that was a trivial problem šŸ˜
                              thank you all you guys !
                              http://img.sceper.eu/images/SkvJI.jpg
