    [REQ] weird effect in vray
    renderpluginsextensions
    13 Posts 5 Posters 835 Views 5 Watching
    • tibetT Offline
      tibet
      hi,
      i´ve encountered a weird effect during v-ray rendering
      and have no idea of it´s origin.
      i´d be very grateful for any tips or suggestions how to fix it.
      thanks!
      (sketchup is okey)
      http://img.sceper.eu/images/ntzU.jpg
      (v-ray isn´t okey)
      http://img.sceper.eu/images/kOgmr.jpg
      test.skp
      SU 2015 Pro on Win10 x64
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Renders fine for me... Weird
        • tibetT Offline
          tibet
          i can´t believe my eyes man!
          when i repeate it with a different computer (+ better graphic card) everything is fine
          that´s very strange, because i´ve done so many times with my laptop, and every time
          accompanied by the same weird effect.
          i´d be grateful for any tips or experiences with the similar anomalies.
          thanks!
          • V Offline
            valerostudio
            What version of V-Ray?
            I've never seen this one before. Very odd.
            • andybotA Offline
              andybot
              It's what I figured. It looks like crazy displacement. You have a displacement map selected that is saved locally to your laptop. Uncheck the displacement in your material and you should be good to go.
              • tibetT Offline
                tibet
                hi andybot,
                thanks a lot for your valuable reply, it think you´re on the right track.
                best of luck!
                ...wondering why it shows 100% , when some part are still waiting to be finished.
                is there any info about the state of rendering process ( in proggress/finished/error )
                i´ve been waiting for over 20minutes without any change. 😮
                http://img.sceper.eu/images/rpWAM.jpg
                2.skp
                  jiminy-billy-bob
                  The "100%" is just the zoom in the FrameBuffer. If you scroll it'll change.
                  • andybotA Offline
                    andybot
                    make sure you've unchecked displacement in your material. Why would you need displacement on that piece? Is there some effect you are trying to produce?
                    • tibetT Offline
                      tibet
                      hi andybot,
                      i´ve repeat it today, and get the same weird result , even dispacement setting is
                      unchecked.
                      i never use displacement for this rendering.
                      i´ve even updated graphic card driver with no results, maybe some gremlins are playing in
                      my wet laptop.
                      (model - test.skp)
                      http://img.sceper.eu/images/CozFV.jpg
                      • chonC Offline
                        chon
                        Really strange ???
                        I rendered a vew with your settings and :
                        Which version of VRay do you use ?
                          jiminy-billy-bob
                          You have a displacement map in your material. Uncheck it in the material options, not in the general options.
                          • tibetT Offline
                            tibet
                            yes, you´re 100% right.
                            displacement was checked by default, not by me...
                            I swear I didn't do it!
                            http://img.sceper.eu/images/hH3sI.jpg
                            • tibetT Offline
                              tibet
                              hi chon,
                              i´t s great, at the end i´ve found it!
                              man, i´m glad that was a trivial problem 😍
                              thank you all you guys !
                              http://img.sceper.eu/images/SkvJI.jpg
