    [Layout Tip] - improving workflow
    layout
    25 Posts 13 Posters 3.0k Views 13 Watching
    • RichardR Offline
      Richard
      Nice stuff Andrew!!
      This certainly does highlight some of the issues with scrapbook and layout in general. I'm not sure if you have ever used indesign? But the ability to handle styles is one of it's strengths. I'd be loving that sort of functionality to be introduced to Layout, so anything assigned a "style" can be updated globally! EG all text in a document can be changed to another font!
      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
        tim
        Just for fun and maybe for the benefit of those of use that live in non-metricland, I reworked utiler's template for 36x24" sheet with 1:12/24/48 scales, imperial dimension stuff etc.
        With your permission, may upload it here?
        • utilerU Offline
          utiler
          Sure Tim, go for your life!
          Never use InDesign, Rich although I know you have referred to its strengths in the past; just wish I had time to go surfing and trialing new stuff...
          πŸ‘
          Just Curious...
          • RichardR Offline
            Richard
            Beers NEXT WEEK mate! Really looking forward to it!
            • utilerU Offline
              utiler
              You bet! I was just thinking about that last night.... πŸŽ‰
              Just Curious...
              • emerald15E Offline
                emerald15
                I've not thought of working this way before - definitely going to try it. Many thanks for sharing the template.
                • dcauldwellD Offline
                  dcauldwell
                  I have been using a similar Layout set-up, including copying sheet one once I've added job title etc to avoid having to keep copying it. However your is so neat, comprehensive and organised, I just had to download it and give it a try.
                  Thanks for generously sharing. Cheers.
                  Sketchup 2017
                  (vray 2.00)
                  • zx10r_GazZ Offline
                    zx10r_Gaz
                    @utiler said:
                    πŸ‘
                    Nice work around, I can see the benefits immediately.
                    Thanks for sharing.
                    Gaz...
                    • utilerU Offline
                      utiler
                      No problem, guys, happy you find it helpful.... πŸ‘
                      Just Curious...
                        compostbrainius
                        what are the little red arrows in the template for and how do you get rid of them? Thanks for the template!
                        • utilerU Offline
                          utiler
                          Hi Joel, if you're referring to red arrows around text it will be because I use a custom typeface that you won't have on your computer. What happens if you open a file that contains a typeface you don't have it loads a default which will no doubt have different size, scale, etc properties..
                          You'll need to select the text where you see a red arrow, go to your text editor and click unbounded....
                          Just Curious...
                            tim
                            Whoops, forgot to upload;
                            Tim's version of utiler's template; 36x24" etc
                            • 2 / 2
