    [Layout Tip] - improving workflow
    layout
    25 Posts 13 Posters 4.4k Views 13 Watching
      tim
      Just for fun and maybe for the benefit of those of use that live in non-metricland, I reworked utiler's template for 36x24" sheet with 1:12/24/48 scales, imperial dimension stuff etc.
      With your permission, may upload it here?
      • utilerU Offline
        utiler
        Sure Tim, go for your life!
        Never use InDesign, Rich although I know you have referred to its strengths in the past; just wish I had time to go surfing and trialing new stuff...
        πŸ‘
        Just Curious...
        • RichardR Offline
          Richard
          Beers NEXT WEEK mate! Really looking forward to it!
          BUILTBRAND.COM.AU
          • utilerU Offline
            utiler
            You bet! I was just thinking about that last night.... πŸŽ‰
            Just Curious...
            • emerald15E Offline
              emerald15
              I've not thought of working this way before - definitely going to try it. Many thanks for sharing the template.
              • dcauldwellD Offline
                dcauldwell
                I have been using a similar Layout set-up, including copying sheet one once I've added job title etc to avoid having to keep copying it. However your is so neat, comprehensive and organised, I just had to download it and give it a try.
                Thanks for generously sharing. Cheers.
                Sketchup 2017
                (vray 2.00)
                • zx10r_GazZ Offline
                  zx10r_Gaz
                  @utiler said:
                  πŸ‘
                  Nice work around, I can see the benefits immediately.
                  Thanks for sharing.
                  Gaz...
                  • utilerU Offline
                    utiler
                    No problem, guys, happy you find it helpful.... πŸ‘
                    Just Curious...
                      compostbrainius
                      what are the little red arrows in the template for and how do you get rid of them? Thanks for the template!
                      • utilerU Offline
                        utiler
                        Hi Joel, if you're referring to red arrows around text it will be because I use a custom typeface that you won't have on your computer. What happens if you open a file that contains a typeface you don't have it loads a default which will no doubt have different size, scale, etc properties..
                        You'll need to select the text where you see a red arrow, go to your text editor and click unbounded....
                        Just Curious...
                          tim
                          Whoops, forgot to upload;
                          Tim's version of utiler's template; 36x24" etc
                          • 2 / 2
