    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 117.0k Views 42 Watching
      Compression should only apply to JPEG.
      If you export a similar 2D image from File > Export 2D?
      • FrederikF Offline
        Frederik
        @frederik said:
        ...but I also set the compression to 0...
        Looking for a smiley banging the head into the wall...
        Seem that this was causing the issue... 😳
        If I leave the compression at 0.9, I'm able to open the file in res. 4400x2250px in Photoshop and the file size is 2.76Mb, which seem reasonable...
        Perhaps you should lock the compresion to a specific value or make sure that it can't be set to 0 (read: zero)... πŸ’­
        Cheers
        Kim Frederik
        • FrederikF Offline
          Frederik
          Then it should - by default - be "in-active" when saving to png IMO...
          No problem, but then I can't get the transparency I need... πŸ˜‰
          Cheers
          Kim Frederik
            I had no idea it would cause oddities for PNG files... :s
            The documentation (roll eyes) says:
            (optional) Float compression factor for JPEG images, between 0.0 and 1.0
            http://www.sketchup.com/intl/en/developer/docs/ourdoc/view#write_image
            So I figured there was no need to disable/enable depending on filetype - which I have no means of obtaining either as the filedialog comes after the options (SketchUp API limitation). And 0.0 is a valid value for JPEG - at least according to the API... though I've never tried to set it that low.
            This sounds like a SketchUp bug - or very poor API documentation.
            Unfortunately there isn't a whole lot I can do to address this.
              hm... looking at the docs again, 1.0 is best quality - 0.0 is worst. Compression is probably incorrect label (I just inherited the API argument name) - Quality is probably a better label.
              • FrederikF Offline
                Frederik
                No worries, Thomas...
                You have my deepest respect regardless of this... πŸ˜„
                At least I found the reason and know what to do to avoid this in the future... πŸ‘
                Cheers
                Kim Frederik
                • FrederikF Offline
                  Frederik
                  Getting slightly confused...
                  Are you going to update the plugin then...? πŸ˜•
                  Question:
                  Why are the user not able to select the file-type from the drop down list...?
                  If the user had to select the file-type (i.e. JPG or PNG) the compression could be inactive when png is selected and transparency can be inactive (obviously) when the user have selected jpg... πŸ€“
                  Cheers
                  Kim Frederik
                    That could possibly be an option. Might do that ... some time. But currently my priorities are Bezier Surface and Vertex Tools.
                    • FrederikF Offline
                      Frederik
                      Take your time, Thomas... πŸ˜‰
                      Cheers
                      Kim Frederik
                      • Q Offline
                        quentinbuilder
                        I have installed the plug-in and also the required TT_lib2. The export option exists in views pulldown. I select and get the window where I select resolution, transparency- then I get a file browser window and the file option is blank and it does not seem to save a file- I must be doing something wrong. Does this work with SU8 free version?
                        Quentin
                          Works with free version yes, but due to a bug in the API you must manally type the file extension of the file.
                          • V Offline
                            vojo
                            Export 2D works great!!! Only issue is having to do it multiple times to make sure it fits in window
                            Any thought to either a preview panel to let use check it fits....or....zoom to fit and, once exported, return to original zoom level (maybe key off selection of shapes to be exported)
                            just a thought
                              I recommend that people use V-Ray Tools instead. You don't need V-Ray to use it, but it has a better interface for setting the safe frame and exporting.
                              http://sketchucation.com/forums/viewtopic.php?t=15491
                              • FrederikF Offline
                                Frederik
                                Why is this plugin not in the SketchUcation plugin store...?
                                Is there another plugin, which is better for making a png with alpha/transparency background...?
                                Cheers
                                Kim Frederik
                                • V Offline
                                  vojo
                                  supposedly the VRAY plugin is suppose to be better. However, my experience is that VRAY doesnt do a single thing....just sits there. So I use this plugin extensively (even modified it to get defaults the way I want them).
                                  Like I said earlier....this pluging works well....would recommend it....VRAY not on my recommended list (there are other plugins from various authors that I would not recommend at all).
                                  • FrederikF Offline
                                    Frederik
                                    I can highly recommend the [SU]Ch v1.0.1 plugin by renderiza, which also enables the user to make a png-file with alpha/transparency... 😍
                                    Cheers
                                    Kim Frederik
                                      It is
                                        It has been superseded by V-Ray Tools. I know it's a bit confusing that it says V-*Ray, but there's an export 2d function there that works better than this plugin.
                                        • V Offline
                                          vojo
                                          oh you guys are going to love this one
                                          export 2d stopped working....it would post menus...but no image written
                                          (VRAY just never worked for me at all in any way on any day)
                                          Tried to reload sketchup couple of times....no avail..still got menus but no actual image write
                                          Went into the plugin and changed 1 text string by 1 character
                                          (added a space in save file panel title)
                                          Reloaded sketchup...works again
                                          I suspect its the whole plugin mgmt infrastructure....not so much the actual plugin
                                          Just got to love all this "free" stuff
                                            It works just fine for me as it comes "out of the box". I would have to conclude that it is a problem on your end and not the plugin.
                                            This was created a few moments ago using Export 2D.
                                            • 5 / 8
