    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 143.9k Views 42 Watching
    • FrederikF
      Frederik
      @thomthom said:
      Does it happen to all models?
      Do you have another computer nearby where you can try?
      Just did and it's the same... 😞
      If I save in resolution 800x600px it works fine and I can open it in Photoshop...
      The file size is 1.83Mb in this resolution, but I also set the compression to 0...
      Cheers
      Kim Frederik
        Compression should only apply to JPEG.
        If you export a similar 2D image from File > Export 2D?
        • FrederikF
          Frederik
          @frederik said:
          ...but I also set the compression to 0...
          Looking for a smiley banging the head into the wall...
          Seem that this was causing the issue... 😳
          If I leave the compression at 0.9, I'm able to open the file in res. 4400x2250px in Photoshop and the file size is 2.76Mb, which seem reasonable...
          Perhaps you should lock the compresion to a specific value or make sure that it can't be set to 0 (read: zero)... πŸ’­
          Cheers
          Kim Frederik
          • FrederikF
            Frederik
            Then it should - by default - be "in-active" when saving to png IMO...
            No problem, but then I can't get the transparency I need... πŸ˜‰
            Cheers
            Kim Frederik
              I had no idea it would cause oddities for PNG files... :s
              The documentation (roll eyes) says:
              (optional) Float compression factor for JPEG images, between 0.0 and 1.0
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/view#write_image
              So I figured there was no need to disable/enable depending on filetype - which I have no means of obtaining either as the filedialog comes after the options (SketchUp API limitation). And 0.0 is a valid value for JPEG - at least according to the API... though I've never tried to set it that low.
              This sounds like a SketchUp bug - or very poor API documentation.
              Unfortunately there isn't a whole lot I can do to address this.
                hm... looking at the docs again, 1.0 is best quality - 0.0 is worst. Compression is probably incorrect label (I just inherited the API argument name) - Quality is probably a better label.
                • FrederikF
                  Frederik
                  No worries, Thomas...
                  You have my deepest respect regardless of this... πŸ˜„
                  At least I found the reason and know what to do to avoid this in the future... πŸ‘
                  Cheers
                  Kim Frederik
                  • FrederikF
                    Frederik
                    Getting slightly confused...
                    Are you going to update the plugin then...? πŸ˜•
                    Question:
                    Why are the user not able to select the file-type from the drop down list...?
                    If the user had to select the file-type (i.e. JPG or PNG) the compression could be inactive when png is selected and transparency can be inactive (obviously) when the user have selected jpg... πŸ€“
                    Cheers
                    Kim Frederik
                      That could possibly be an option. Might do that ... some time. But currently my priorities are Bezier Surface and Vertex Tools.
                      • FrederikF
                        Frederik
                        Take your time, Thomas... πŸ˜‰
                        Cheers
                        Kim Frederik
                        • Q
                          quentinbuilder
                          I have installed the plug-in and also the required TT_lib2. The export option exists in views pulldown. I select and get the window where I select resolution, transparency- then I get a file browser window and the file option is blank and it does not seem to save a file- I must be doing something wrong. Does this work with SU8 free version?
                          Quentin
                            Works with free version yes, but due to a bug in the API you must manally type the file extension of the file.
                            • V
                              vojo
                              Export 2D works great!!! Only issue is having to do it multiple times to make sure it fits in window
                              Any thought to either a preview panel to let use check it fits....or....zoom to fit and, once exported, return to original zoom level (maybe key off selection of shapes to be exported)
                              just a thought
                                I recommend that people use V-Ray Tools instead. You don't need V-Ray to use it, but it has a better interface for setting the safe frame and exporting.
                                404 Not Found
                                (sketchucation.com)
                                • FrederikF
                                  Frederik
                                  Why is this plugin not in the SketchUcation plugin store...?
                                  Is there another plugin, which is better for making a png with alpha/transparency background...?
                                  Cheers
                                  Kim Frederik
                                  • V
                                    vojo
                                    supposedly the VRAY plugin is suppose to be better. However, my experience is that VRAY doesnt do a single thing....just sits there. So I use this plugin extensively (even modified it to get defaults the way I want them).
                                    Like I said earlier....this pluging works well....would recommend it....VRAY not on my recommended list (there are other plugins from various authors that I would not recommend at all).
                                    • FrederikF
                                      Frederik
                                      I can highly recommend the [SU]Ch v1.0.1 plugin by renderiza, which also enables the user to make a png-file with alpha/transparency... 😍
                                      Cheers
                                      Kim Frederik
                                        It is
                                          It has been superseded by V-Ray Tools. I know it's a bit confusing that it says V-*Ray, but there's an export 2d function there that works better than this plugin.
                                          • V
                                            vojo
                                            oh you guys are going to love this one
                                            export 2d stopped working....it would post menus...but no image written
                                            (VRAY just never worked for me at all in any way on any day)
                                            Tried to reload sketchup couple of times....no avail..still got menus but no actual image write
                                            Went into the plugin and changed 1 text string by 1 character
                                            (added a space in save file panel title)
                                            Reloaded sketchup...works again
                                            I suspect its the whole plugin mgmt infrastructure....not so much the actual plugin
                                            Just got to love all this "free" stuff
                                            • 6 / 8
