    [Plugin] Export 2d with Alpha
    148 Posts 42 Posters 131.7k Views 42 Watching
    • FrederikF Offline
      Frederik
      OK...
      I found a way to make it work...
      Open the file with Microsoft Office Picture Manager and export it to a new png-file...
      The size will reduce from 37.8Mb to 1.58Mb and I can't see any quality loss... πŸ˜’
      Check this https://dl.dropbox.com/u/9887081/Test4Thomthom2.png
      I'm able to open the new file in PhotoShop...
      Edit: Well... It seem that I need to do something before it works, like use the crop tool and then export it...
      The result is that the file size reduces significantly and then I'm able to open it in PhotoShop without any quality loss...
      https://dl.dropbox.com/u/9887081/Test4Thomthom3.png
      Strange... πŸ˜•
      Cheers
      Kim Frederik
        37.8MB for a 4400x2250px PNG image??? That ain't right.
        Inspecting your file in a hex editor and it's full of NULL bytes. :s
        The plugin leaves the writing for the image to SketchUp. And I've never seen this before.
        My first thoughts are that this is a issue local to your machine. Are you for instance saving to a network drive etc?
          I don't know what it is to be honest.
          Does it happen to all models?
          Do you have another computer nearby where you can try?
          • FrederikF Offline
            Frederik
            Well... In case it's something with my 'puter I wonder what's causing this, cause I've never experienced this before...
            I'm just saving the image on my desktop, not on any network drive or another strange location...
            Like I said... Very strange... πŸ˜•
            Edit: I've now tried to save the png-file to some other locations (eg. a folder on the C-drive, on the desktop, on a network drive), but the result remain identical... 😞
            Cheers
            Kim Frederik
            • FrederikF Offline
              Frederik
              Just did and it's the same... 😞
              If I save in resolution 800x600px it works fine and I can open it in Photoshop...
              The file size is 1.83Mb in this resolution, but I also set the compression to 0...
              Cheers
              Kim Frederik
                Compression should only apply to JPEG.
                If you export a similar 2D image from File > Export 2D?
                • FrederikF Offline
                  Frederik
                  @frederik said:
                  ...but I also set the compression to 0...
                  Looking for a smiley banging the head into the wall...
                  Seem that this was causing the issue... 😳
                  If I leave the compression at 0.9, I'm able to open the file in res. 4400x2250px in Photoshop and the file size is 2.76Mb, which seem reasonable...
                  Perhaps you should lock the compresion to a specific value or make sure that it can't be set to 0 (read: zero)... πŸ’­
                  Cheers
                  Kim Frederik
                  • FrederikF Offline
                    Frederik
                    Then it should - by default - be "in-active" when saving to png IMO...
                    No problem, but then I can't get the transparency I need... πŸ˜‰
                    Cheers
                    Kim Frederik
                      I had no idea it would cause oddities for PNG files... :s
                      The documentation (roll eyes) says:
                      (optional) Float compression factor for JPEG images, between 0.0 and 1.0
                      http://www.sketchup.com/intl/en/developer/docs/ourdoc/view#write_image
                      So I figured there was no need to disable/enable depending on filetype - which I have no means of obtaining either as the filedialog comes after the options (SketchUp API limitation). And 0.0 is a valid value for JPEG - at least according to the API... though I've never tried to set it that low.
                      This sounds like a SketchUp bug - or very poor API documentation.
                      Unfortunately there isn't a whole lot I can do to address this.
                        hm... looking at the docs again, 1.0 is best quality - 0.0 is worst. Compression is probably incorrect label (I just inherited the API argument name) - Quality is probably a better label.
                        • FrederikF Offline
                          Frederik
                          No worries, Thomas...
                          You have my deepest respect regardless of this... πŸ˜„
                          At least I found the reason and know what to do to avoid this in the future... πŸ‘
                          Cheers
                          Kim Frederik
                          • FrederikF Offline
                            Frederik
                            Getting slightly confused...
                            Are you going to update the plugin then...? πŸ˜•
                            Question:
                            Why are the user not able to select the file-type from the drop down list...?
                            If the user had to select the file-type (i.e. JPG or PNG) the compression could be inactive when png is selected and transparency can be inactive (obviously) when the user have selected jpg... πŸ€“
                            Cheers
                            Kim Frederik
                              That could possibly be an option. Might do that ... some time. But currently my priorities are Bezier Surface and Vertex Tools.
                              • FrederikF Offline
                                Frederik
                                Take your time, Thomas... πŸ˜‰
                                Cheers
                                Kim Frederik
                                • Q Offline
                                  quentinbuilder
                                  I have installed the plug-in and also the required TT_lib2. The export option exists in views pulldown. I select and get the window where I select resolution, transparency- then I get a file browser window and the file option is blank and it does not seem to save a file- I must be doing something wrong. Does this work with SU8 free version?
                                  Quentin
                                    Works with free version yes, but due to a bug in the API you must manally type the file extension of the file.
                                    • V Offline
                                      vojo
                                      Export 2D works great!!! Only issue is having to do it multiple times to make sure it fits in window
                                      Any thought to either a preview panel to let use check it fits....or....zoom to fit and, once exported, return to original zoom level (maybe key off selection of shapes to be exported)
                                      just a thought
                                        I recommend that people use V-Ray Tools instead. You don't need V-Ray to use it, but it has a better interface for setting the safe frame and exporting.
                                        http://sketchucation.com/forums/viewtopic.php?t=15491
                                        • FrederikF Offline
                                          Frederik
                                          Why is this plugin not in the SketchUcation plugin store...?
                                          Is there another plugin, which is better for making a png with alpha/transparency background...?
                                          Cheers
                                          Kim Frederik
                                          • V Offline
                                            vojo
                                            supposedly the VRAY plugin is suppose to be better. However, my experience is that VRAY doesnt do a single thing....just sits there. So I use this plugin extensively (even modified it to get defaults the way I want them).
                                            Like I said earlier....this pluging works well....would recommend it....VRAY not on my recommended list (there are other plugins from various authors that I would not recommend at all).
                                            • 6 / 8
