    • Log Masuk
    Scheduled Pinned Kunci Moved Plugins
    1.3k Kiriman 299 Posters 2.5m Lihat 297 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • T Luar talian
      trion
      Hello Fredo6
      I made a small donation to your account, because of the great scripts and support.
      Thank you so much.
      Trion
      1 Reply Last reply Balas Petikan 0
      • AlomphegaA Luar talian
        Alomphega
        Hello Fredo,
        I have almost the same thing to do : a wing - but this time curved like a kitesurf wing.
        I have yet done this with a triangular half wing and CurviLoft worked fine for this with 3 edges, but since I have added some right tips to do a trapezoidal half wing, I'm not able to re-do the miracle.
        The problem : I would like to make a skin on the upper face following the tailing and the leading edges as rails, with the upper half of a foil as upper skin shape, then end flat to the tip.
        In attachment you will find the half of the wing I talk about :
        The purple is the upper half foil shape, the dark red is the tailing edge, the dark green is the leading edge and the green is the tip.
        This happen after I select Tailing and leading edges as 1 & 2, then clic, then select upper foil shape and tip as 3 & 4, then "skinning" : nothing happens.
        The same trying almost all other selecting orders.
        Could you take a look and tell me were I'm wrong please ?
        Best Regards,
        Guy
        Test CurviLoft 'skin'
        Guy Capra, http://www.nauticaerium.com
        Non je ne suis pas un "Géo Trouvetou", juste un "Géo... Zéchercher" ! ;)
        • pbacotP Luar talian
          I mocked-up something similar to your picture and can't get it to fail. Seeing as I can make a number of things fail, perhaps you should post your SU file, to see what it is exactly. But the way I am doing it is: I just select all of it and pick the skinning tool.
            Alomphega
            Thank you very much for your try to help pbacot,
            here in attachment you will find a SKP file with the half kite wing a talk about to test it.
            HalfKiteWing (SkinningTest).skp
            • cottyC Luar talian
              cotty
              Something like this? I used TIGs Extrude Edges by Rails (EEbyR)...
              HalfKiteWing (SkinningTest)_2.skp
              my SketchUp gallery
              • jeff hammondJ Luar talian
                Best Regards,
                Guy
                you have a tiny line in there at an angle too steep to be picked up by curviloft's autoselection.. (it's in between the red and purple selected lines of your screenshot)
                either a) zoom in real close and select that tiny line manually or b) fix the curve so it's continous..
                (option b being the best.)
                [EDIT] actually, you have more errors going on than just the one i mentioned.. i'm out the door..
                someone else can pinpoint them for you 😉
                  Alomphega
                  Just amazing and awesome ! Many thanks cotty ! 😄
                  Jeff, I tought this, but very difficult to fix and CurviLoft auto-fix function does not seems to work on my so dirty design. I have to re-draw the stuff but I'm not able to do more fine within SU.
                  Anyway, I have now some material to test and work on.
                  Best Regards to all, and best wishes !
                  Guy
                  • jgbJ Luar talian
                    jgb
                    Trion
                    I concur with Fredo.
                    What you need to do is take a copy of the chord at the root and scale it to (at least) 1 other rib location near the tip, but just before the tip curve starts.
                    Then CL skin individually the inner top and outer (tip) top airfoil, then do the bottom in 2 goes as well. Only explode the surfaces after all curves are satisfactory.
                    Should take all of 5 minutes.
                    If you have a problem, come back here with your SKP file and I will do a detailed explanation.
                    jgb
                    • T Luar talian
                      trion
                      Hello,
                      Well, it didnt work for me, so here is that file im trying.
                      Hope you can find out why its not working.
                      Trion
                      wing.skp
                        cotty
                        I've welded some lines and Curviloft asked me if it should repair some issues ...
                        wing_2.skp
                        my SketchUp gallery
                        • T Luar talian
                          trion
                          Thank you for checking and fixing the wing.
                          would like to know what you did and where i need to look for the next time.
                          • T Luar talian
                            trion
                            Cotty:
                            Never mind my last question, i found out what i`m did wrong the whole time...
                            I installed curvizard and select all contours 1 by 1 and using the make curve weld option.
                            and your right.. the script was telling me also to fix some problems.
                            After that there was no problem selection those lines(curves) and make the wing.
                            this will keep me going for a while.
                            Thanx all.
                            • jgbJ Luar talian
                              jgb
                              Cotty & Trion
                              The reason I would split the wing into 2+ parts is to preserve the chord section along the inner span section.
                              Doing it in 1 go (per side) gives a nice looking result, but the chord tends to be flattening towards the outer section and wing tip.
                              That is NOT a fault of Curviloft; it's just the way it works going from a "shape" to a point. Intermediate proportional "shapes" result in a better overall curve.
                              This may not be relevant to a model for "show" but could be critical if accuracy is important. Such a case would be if drawing internal wing structure was part of the model, rather than just an outward appearing skin or mold line.
                              jgb
                              • M Luar talian
                                mikeypals23
                                I cant seem to get Curviloft to appear in SketchUp. As far as I can tell, I installed that and LibFredo6 correctly. Any help would be appreciated! Thank you for your time.
                                • Dave RD Luar talian
                                  But you haven't installed Curviloft correctly. You've not maintained the file structure as described in the first post of this thread.
                                  All of the files in the red box as well as the folder called IMAGES_Standard should be in a folder called CURVILOFT_Dir_12.
                                  • M Luar talian
                                    mikeypals23
                                    Thank you for the help! Working now, sorry for the careless oversight!
                                    • R Luar talian
                                      Ralphxyz
                                      I am getting this error when trying to run Curviloft.
                                      http://gettheworkdone.net/3Dprinting/SketchUp/Curviloft.png
                                      Ralph
                                        Where is the file called bootstrap_Curviloft.rb? It should be in a folder called CURVILOFT_Dir_12 but I'm guessing it isn't.
                                        In fact you should have all these files in that folder.
                                        • R Luar talian
                                          Ralphxyz
                                          Yup, I have them:
                                          http://gettheworkdone.net/3Dprinting/SketchUp/curviloftbootstrap.png
                                          Ralph
                                          • TIGT Luar talian
                                            Have you also downloaded and correctly installed the required helper file-set LibFredo6 ?
                                            http://sketchucation.com/forums/viewtopic.php?p=144178#p144178
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 65
                                            • 66
                                            • 41 / 66
