    1.3k Posts 299 Posters 2.7m Views 297 Watching
    • AlomphegaA Offline
      Alomphega
      Thank you very much for your try to help pbacot,
      here in attachment you will find a SKP file with the half kite wing a talk about to test it.
      HalfKiteWing (SkinningTest).skp
      Guy Capra, http://www.nauticaerium.com
      Non je ne suis pas un "Géo Trouvetou", juste un "Géo... Zéchercher" ! ;)
      • cottyC Offline
        cotty
        Something like this? I used TIGs Extrude Edges by Rails (EEbyR)...
        HalfKiteWing (SkinningTest)_2.skp
        my SketchUp gallery
        • jeff hammondJ Offline
          @alomphega said:
          Could you take a look and tell me were I'm wrong please ?
          Best Regards,
          Guy
          you have a tiny line in there at an angle too steep to be picked up by curviloft's autoselection.. (it's in between the red and purple selected lines of your screenshot)
          either a) zoom in real close and select that tiny line manually or b) fix the curve so it's continous..
          (option b being the best.)
          [EDIT] actually, you have more errors going on than just the one i mentioned.. i'm out the door..
          someone else can pinpoint them for you 😉
            Alomphega
            Just amazing and awesome ! Many thanks cotty ! 😄
            Jeff, I tought this, but very difficult to fix and CurviLoft auto-fix function does not seems to work on my so dirty design. I have to re-draw the stuff but I'm not able to do more fine within SU.
            Anyway, I have now some material to test and work on.
            Best Regards to all, and best wishes !
            Guy
            • jgbJ Offline
              jgb
              Trion
              I concur with Fredo.
              What you need to do is take a copy of the chord at the root and scale it to (at least) 1 other rib location near the tip, but just before the tip curve starts.
              Then CL skin individually the inner top and outer (tip) top airfoil, then do the bottom in 2 goes as well. Only explode the surfaces after all curves are satisfactory.
              Should take all of 5 minutes.
              If you have a problem, come back here with your SKP file and I will do a detailed explanation.
              jgb
                trion
                Hello,
                Well, it didnt work for me, so here is that file im trying.
                Hope you can find out why its not working.
                Trion
                wing.skp
                • cottyC Offline
                  cotty
                  I've welded some lines and Curviloft asked me if it should repair some issues ...
                  wing_2.skp
                  my SketchUp gallery
                    trion
                    Thank you for checking and fixing the wing.
                    would like to know what you did and where i need to look for the next time.
                      trion
                      Cotty:
                      Never mind my last question, i found out what i`m did wrong the whole time...
                      I installed curvizard and select all contours 1 by 1 and using the make curve weld option.
                      and your right.. the script was telling me also to fix some problems.
                      After that there was no problem selection those lines(curves) and make the wing.
                      this will keep me going for a while.
                      Thanx all.
                      • jgbJ Offline
                        jgb
                        Cotty & Trion
                        The reason I would split the wing into 2+ parts is to preserve the chord section along the inner span section.
                        Doing it in 1 go (per side) gives a nice looking result, but the chord tends to be flattening towards the outer section and wing tip.
                        That is NOT a fault of Curviloft; it's just the way it works going from a "shape" to a point. Intermediate proportional "shapes" result in a better overall curve.
                        This may not be relevant to a model for "show" but could be critical if accuracy is important. Such a case would be if drawing internal wing structure was part of the model, rather than just an outward appearing skin or mold line.
                        jgb
                          mikeypals23
                          I cant seem to get Curviloft to appear in SketchUp. As far as I can tell, I installed that and LibFredo6 correctly. Any help would be appreciated! Thank you for your time.
                            But you haven't installed Curviloft correctly. You've not maintained the file structure as described in the first post of this thread.
                            All of the files in the red box as well as the folder called IMAGES_Standard should be in a folder called CURVILOFT_Dir_12.
                              mikeypals23
                              Thank you for the help! Working now, sorry for the careless oversight!
                                Ralphxyz
                                I am getting this error when trying to run Curviloft.
                                http://gettheworkdone.net/3Dprinting/SketchUp/Curviloft.png
                                Ralph
                                  Where is the file called bootstrap_Curviloft.rb? It should be in a folder called CURVILOFT_Dir_12 but I'm guessing it isn't.
                                  In fact you should have all these files in that folder.
                                    Ralphxyz
                                    Yup, I have them:
                                    http://gettheworkdone.net/3Dprinting/SketchUp/curviloftbootstrap.png
                                    Ralph
                                      Have you also downloaded and correctly installed the required helper file-set LibFredo6 ?
                                      http://sketchucation.com/forums/viewtopic.php?p=144178#p144178
                                        Ralphxyz
                                        Yup!!
                                        I have the Curviloft toolbar and the Tools/Fredo6 Collection menu Curviloft menu item.
                                        They do "work" in my limited testing.
                                        Ralph
                                          Have you checked that you have FULL security permissions to the Plugins folder and its contents?
                                          Right-click context-menu on its icon, Properties > Security > Edit...
                                          It might be that your rights are limited ??
                                          Also is there a 'Compatibilities Files...' link button on the Explorer window for the Plugins folder, which might means some things are not installed as it appears... [Windows 😒 ]
                                            Ralphxyz
                                            TIG I can not follow what you are asking. "its icon"??
                                            Here is my Plugin menu.
                                            http://gettheworkdone.net/3Dprinting/SketchUp/Plugins.png
                                            There is no 'Compatibilities Files...' in the Plugins menu.
                                            Ralph
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 65
                                            • 66
                                            • 43 / 66
