    Drawing a centrifugal pump volute
    32 Posts 10 Posters 5.9k Views 10 Watching
    • F Offline
      Futurepast
      @mac1 said:
      @futurepast said:
      Is this what you want? I use d Cris Fulmers bending tool to bend a flat impeller around the spiral from the vid above, and just rotated a few times. Oh I see you want the tube. Should bend the same way?
      Just checked yes it works but you have to "explode" the spiral for Cris's tool to work
      Have you looked at the link provided above? The draw metal plugin lets you draw it no time or does it not work as shown
      You create just the spiral and then you have to ungroup it for cris's tool to work. The part gets bent around the spiral
        mac1
        Sorry I did not make myself very clear or did not understand your post.
        The link I was referring was the one I posted early in the thread. It is a youtube video showing how to draw the 3d involoute using the draw metal plugin and does not use the shape bender. The plugin gives you the specific path profile and you can use the FAK to draw the profile you want. Here is the link for it http://www.drawmetal.com/download
        • jacbk612J Offline
          jacbk612
          Right, here's a better version of this,I am just using curviloft and arcs. I will get the proper representation of a volute curve and raw that loft properly, then it just needs to be intersected at the top, and a cylinder punched through.
          Jacques
            mac1
            Jacques
            This is what you can get using the draw metal plugin. The plugin also has a taper maker but have not tried that yet.
            Need for you to define the dimensions as well as the desired extruded cross section profiles
            • jeff hammondJ Offline
              right.. curviloft is the correct tool to use.. but do it like this instead..
              [edit].. well.. what p just said before me.. lol..
              sorry.. i'll leave this up for the visuals..
              • BoxB Offline
                Here's a five minute version done with Curve Maker and Taper Maker and all else standard tools. I think that's the sort of general shape you want.
                Took longer to animate than to draw.
                  mac1
                  Update, 6 dia, no eye, taper round .5 to .25". 1 turn h=3"
                  Waiting on dimensions and taper cross section ( selection limited to round, rect, diamond,>.....
                  • pbacotP Offline
                    If the taper is geometric along the length, I found using Curviloft "create loft junctions along a given path" worked in one process.
                    I used BZ Toolbar curves uniform B- spline (though other ways should work), Chris Fullmer Perpendicular Face tools to put a circle on each end, and curviloft- using just a beginning and ending circle. Just an idea if it works for you.
                    • gillesG Offline
                      gilles
                      Native tools.
                      centrifugal pump_V6.skp
                      • jacbk612J Offline
                        jacbk612
                        Gilles, this approach seems like the most promising. The loft path seems like a single curve, how was it achieved? Is it a bezier curve?
                        Thanks,
                        Jacques
                          2 tangent arcs-circle ?
                          • gillesG Offline
                            gilles
                            Two tangent arcs.
                            Edit: did you open the file?
                            part 2
                            • gillesG Offline
                              gilles
                              mais je me doutais que le "bleu des mers du sud" avait encore dû frapper! 😉
                              J'avoue ne pas comprendre. ❓
                                @ Gilles : Non même pas, j'avais même pas vu qu'il y a avait un fichier à charger! 🤓
                                car d'habitude les fichiers à charger sont en fin de post!
                                Et merci pour les V6! Ah si tout le monde en faisait autant! ☀
                                  C'était pourtant évident! 💚
                                  • gillesG Offline
                                    gilles
                                    Pourquoi faire compliqué quand on peut faire simple...
                                    • jacbk612J Offline
                                      jacbk612
                                      Gilles, thank you that is excellent and simple.
                                      I will use English to include all our other friends.
                                      I did open the file but I don't think you can tell in sketchup what type of line it is, are all curved lines arcs or circles probably not.
                                      Jacques
                                      • jacbk612J Offline
                                        jacbk612
                                        I plan to build up this pump completely with an impeller and everything and then run the Khamsin CFD plugin to see if I can get a nice real time simulation.
                                        Gilles, is this something you are familiar with? Does this sound feasible?
                                        Jacques
                                        • gillesG Offline
                                          gilles
                                          Entity info tells you what a selected thing is.
                                          Building the pump is feasible with SU, hope you got better blueprints or a model.
                                          I don't have knowledge about Khamsin CFD .
                                          • F Offline
                                            Futurepast
                                            I have been thinking about this all week! Giles your approach follows the KISS formula. All the newbies (myself included) want a "plugin" to do everything fast and easy but sometimes you have to step back and look at what you got... and what you know. You reshaped my thinking.....thank you.
