    Drawing a centrifugal pump volute
    32 Posts 10 Posters 5.4k Views 10 Watching
    • jacbk612J Offline
      jacbk612
      So I think there is a possibility by using fredo's curviloft using arcs as the loft path. I have included a sequence of skp images, hopefully everyone can see these.
      The idea is that the start and stop part of the loft could be made to intersect and then I could run a cylinder through the center of the whole thing and have my volute.
      Right now the top part is being done with the last part of the loft line as a bezier and it looks a bit squished, don't know if I am doing something wrong.
      Jacques
      volute-test1.skp
      volute-test2.skp
      volute-test3.skp
      • jacbk612J Offline
        jacbk612
        this doesn't look like the best way to display an image maybe I should of made a jpg?
        • jacbk612J Offline
          jacbk612
          jpg files atached
          • F Offline
            Futurepast
            Is this what you want? I use d Cris Fulmers bending tool to bend a flat impeller around the spiral from the vid above, and just rotated a few times. Oh I see you want the tube. Should bend the same way?
            Just checked yes it works but you have to "explode" the spiral for Cris's tool to work
            Untitled.skp
              mac1
              Have you looked at the link provided above? The draw metal plugin lets you draw it no time or does it not work as shown
              • F Offline
                Futurepast
                I guess you are right lol I didn't play with any paramaters but I think it can do what he wants by changing the diamiters at each end
                Untitled.skp
                • F Offline
                  Futurepast
                  You create just the spiral and then you have to ungroup it for cris's tool to work. The part gets bent around the spiral
                    mac1
                    Sorry I did not make myself very clear or did not understand your post.
                    The link I was referring was the one I posted early in the thread. It is a youtube video showing how to draw the 3d involoute using the draw metal plugin and does not use the shape bender. The plugin gives you the specific path profile and you can use the FAK to draw the profile you want. Here is the link for it http://www.drawmetal.com/download
                    • jacbk612J Offline
                      jacbk612
                      Right, here's a better version of this,I am just using curviloft and arcs. I will get the proper representation of a volute curve and raw that loft properly, then it just needs to be intersected at the top, and a cylinder punched through.
                      Jacques
                        mac1
                        Jacques
                        This is what you can get using the draw metal plugin. The plugin also has a taper maker but have not tried that yet.
                        Need for you to define the dimensions as well as the desired extruded cross section profiles
                        • jeff hammondJ Offline
                          right.. curviloft is the correct tool to use.. but do it like this instead..
                          [edit].. well.. what p just said before me.. lol..
                          sorry.. i'll leave this up for the visuals..
                          • BoxB Offline
                            Here's a five minute version done with Curve Maker and Taper Maker and all else standard tools. I think that's the sort of general shape you want.
                            Took longer to animate than to draw.
                              mac1
                              Update, 6 dia, no eye, taper round .5 to .25". 1 turn h=3"
                              Waiting on dimensions and taper cross section ( selection limited to round, rect, diamond,>.....
                              • pbacotP Offline
                                If the taper is geometric along the length, I found using Curviloft "create loft junctions along a given path" worked in one process.
                                I used BZ Toolbar curves uniform B- spline (though other ways should work), Chris Fullmer Perpendicular Face tools to put a circle on each end, and curviloft- using just a beginning and ending circle. Just an idea if it works for you.
                                • gillesG Offline
                                  gilles
                                  Native tools.
                                  centrifugal pump_V6.skp
                                  • jacbk612J Offline
                                    jacbk612
                                    Gilles, this approach seems like the most promising. The loft path seems like a single curve, how was it achieved? Is it a bezier curve?
                                    Thanks,
                                    Jacques
                                      2 tangent arcs-circle ?
                                      • gillesG Offline
                                        gilles
                                        Two tangent arcs.
                                        Edit: did you open the file?
                                        part 2
                                        • gillesG Offline
                                          gilles
                                          mais je me doutais que le "bleu des mers du sud" avait encore dû frapper! 😉
                                          J'avoue ne pas comprendre. ❓
                                            @ Gilles : Non même pas, j'avais même pas vu qu'il y a avait un fichier à charger! 🤓
                                            car d'habitude les fichiers à charger sont en fin de post!
                                            Et merci pour les V6! Ah si tout le monde en faisait autant! ☀
