    Drawing a centrifugal pump volute
    32 Posts 10 Posters 6.6k Views 10 Watching
      2 tangent arcs-circle ?
      • gillesG
        gilles
        Two tangent arcs.
        Edit: did you open the file?
        part 2
        centrifugal pump_V6.skp
        • gillesG
          gilles
          mais je me doutais que le "bleu des mers du sud" avait encore dû frapper! 😉
          J'avoue ne pas comprendre. ❓
            @ Gilles : Non même pas, j'avais même pas vu qu'il y a avait un fichier à charger! 🤓
            car d'habitude les fichiers à charger sont en fin de post!
            Et merci pour les V6! Ah si tout le monde en faisait autant! ☀
              C'était pourtant évident! 💚
              • gillesG
                gilles
                Pourquoi faire compliqué quand on peut faire simple...
                • jacbk612J
                  jacbk612
                  Gilles, thank you that is excellent and simple.
                  I will use English to include all our other friends.
                  I did open the file but I don't think you can tell in sketchup what type of line it is, are all curved lines arcs or circles probably not.
                  Jacques
                  • jacbk612J
                    jacbk612
                    I plan to build up this pump completely with an impeller and everything and then run the Khamsin CFD plugin to see if I can get a nice real time simulation.
                    Gilles, is this something you are familiar with? Does this sound feasible?
                    Jacques
                    • gillesG
                      gilles
                      Entity info tells you what a selected thing is.
                      Building the pump is feasible with SU, hope you got better blueprints or a model.
                      I don't have knowledge about Khamsin CFD .
                      • F
                        Futurepast
                        I have been thinking about this all week! Giles your approach follows the KISS formula. All the newbies (myself included) want a "plugin" to do everything fast and easy but sometimes you have to step back and look at what you got... and what you know. You reshaped my thinking.....thank you.
                          mac1
                          Jacques
                          Gilles did a supper job of showing the approach. However, if you are going to spend the model effort and then simulation I would to suggest for your consideration:
                          Draw metal plugin will draw a volute for you vs using vs the two arcs. I used the radius shown in the drawing and 4turns to get a close fit then cut that to 1 turn.I think this approach will allow you to set the impeller differential spacing side to side more accurately. I spent some time trying to get better edge detection vs the raster dwg but no joy so far. TIF format would probably be better;
                          Khamsin has a YouTube video showing the simulation of a 250 cc kart. I was not able to find any definition for the system requirements but it was mentioned dual cores are required for some functions. In addition it has some 700,000 faces( as best as could tell) and appears to require 10+ hours to run. The point, make sure you look at your system, memory requirements etc so you know you have the hardware to run it.
                          Good Luck here is a link that may have data of interest to you http://www.hindawi.com/journals/ijrm/2011/137860/
                            sbastos
                            Jacques
                            Hello Jacques,
                            Could you get it done?
                            I am planning to design a pump and use Khamsin CFD, but I am just begining to work with Sketchup.
                            • 2 / 2
