    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 217.3k Views 65 Watching
      rubits
      I will not claim that the FBI is extracting ideas from inside my mind. But I had infact developed a similar push pull tool some years back, but with a more native feel to it. Actually I also called it Smart Push Pull. It does not leave traces and it is completely fluid in operation. However it has some problems with antiprismatic prismatoids (OK, it sounds really scientific, but we make these shapes really often), and so I decided not to upload it to rubits. I have however looked at the script again recently, and I also have a few extra tricks up the sleeve that I think could improve the Push Pull tool, so I might release a version of it soon. I will tell you if I do get around to it.
      alex // info@rubits.com
        πŸ‘
        • Bob JamesB
          Bob James
          Any hope for this?
          • X
            xsnovi
            Thank you.
              reccoon
              Thank you!
                sags
                excellent tool, thank you very much for sharing.. πŸ‘
                • K
                  Kato07
                  Thanks for the plugin, works great!
                    stevo tyelaap
                    I always TT's comment and decide to download or not πŸ˜„
                      rilian
                      As a bit of a primitive learning experience, I tossed together a simple toolbar for this tool. I've tested under su8 on win7 though I can't see much reason it would fail on other setups.
                      I used a magnet icon 24x24 which seems to work well when snapped next to other toolbars but it looks off kilter if the toolbar is floating.
                      I have a decent amount of programming experience but zero w/ ruby and this is the first Sketchup ruby work I've done so please don't crush me if this toolbar doesn't work to expectations.
                      Other than the toolbar code added in, the plugin is exactly the same as the most recent version of the plugin listed by the author. I stole the code from Frank Wiesner and Tig's mirror.rb script and modified it for this tool and supplied an icon that I grabbed off the internet.
                      The attached .zip contains the modified .rb script and the .png icon file. Both go loose in the Sketchup plugins folder. Please feel free to modify the icon and use your own. Name it spp.png and you won't even have to change the .rb. Also please feel free to modify the code...
                      Hope this helps somebody...
                      a4_spp_tb_0.1.zip
                        aldokali78
                        thanx .... really smart
                          Ralphxyz
                          Which version is the latest?
                          The top one would be logical but the bottom one has version that is much higher than the second one.
                          I am going to guess at the bottom one.
                          But a big Thanks,
                          Ralph
                            right! πŸ˜‰
                            • sfto1S
                              sfto1
                              This is a cool plugin. Can someone advise if there is a version where native SU inferencing works with this tool?
                              I downloaded the one from the original post from a4chitect and the inferencing does not work.
                              • xiombargX
                                xiombarg
                                To make this plugin useful there needs to be a way to choose the axes inference lines before doing the operation. As it is, it seems useful on simpler shapes where there is only one inference line per vertex, but otherwise it usually doesn't get the result I would hope for.
                                • T
                                  TheMurderArt
                                  nice plugin... you should try to put a restriction for the points of intersection
                                    rowaz
                                    thank you!
                                      JΓΆrg
                                      thank you, a4chitect!!!!
                                      this plugin safed me hours of work today!
                                      j.
                                        adamj0112
                                        Is there a SmartPushPull that works with SU2016?
                                          shri
                                          thank you for this great plugin..
                                          • eneroth3E
                                            eneroth3
                                            Haha, I've also been working on this but I've been calling mine pressdrag instead of pushpull πŸ˜› . My intention is a tool that looks and feels almost identical to native pushpull, i.e. live preview and an option for moving/creating new faces. Should I continue working on it?
                                            My website: http://julia-christina-eneroth.se/
                                            • 4 / 5
