    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 215.9k Views 65 Watching
      liveevil
      i like it....
        romain210
        that's realy cool
        thanks a lot
          donpter
          thank you for your application!
            Use it and it's very brilliant 😎
            but a little remark πŸ˜’
            you call it "Smart Push Pull" but seems it's only "Smart Pull" or I miss something? ❓
            • plot-parisP Offline
              plot-paris
              well spottet, Pilou πŸ˜„
              • X Offline
                xrok1
                is it possible to not leave internal faces with this plug??
                  I finally got around to use this plugin. Very nice.
                  Are you still developing it?
                  I noticed a couple of things:
                  1. It does not draw the input points
                  2. It does not invalidate the view when the tool is activated
                    caleb_barclay
                    I love this script. It is perfect for roofs. I was wondering if there was anyway to enable it to "Snap" to a reference point. I have CAD drawings that I would like the extrusion to snap to.
                      plot-paris
                      @thomthom said:
                      Are you still developing it?d
                      indeed, a4chitect. do you intend to do some further work on this plugin?
                      • majidM Offline
                        majid
                        woww. thanx mate.... really smart (you and the plugin, both πŸ˜‰ ) πŸ‘
                          pitrak
                          This is just what I needed for a project where almost nothing is orthogonal.
                          Just like anyone else, I am wondering if this plugin will be developed any further? I am also convinced that this could become the standard pushpull for plugin people, but it still needs a lot of work.
                          1. It leaves lines at the original position, which you have to delete manually.
                          2. I would prefer the inferencing should to be the same as SU default PP behaviour
                          3. integration with JPP would be great (and be perfectly in line with the concept of this plugin)
                          a4chitect has not been active here for half a year.. Maybe Fredo6 can incorporate SmartPushpull in JPP? Or are there other options for collaboration?
                          This plugin to me is one of the most promising and SU like plugins around. It makes a common problem a lot simpler to solve without adding complexity on another level. It's just a shame that the implementation is not up to the promises...
                            rubits
                            I will not claim that the FBI is extracting ideas from inside my mind. But I had infact developed a similar push pull tool some years back, but with a more native feel to it. Actually I also called it Smart Push Pull. It does not leave traces and it is completely fluid in operation. However it has some problems with antiprismatic prismatoids (OK, it sounds really scientific, but we make these shapes really often), and so I decided not to upload it to rubits. I have however looked at the script again recently, and I also have a few extra tricks up the sleeve that I think could improve the Push Pull tool, so I might release a version of it soon. I will tell you if I do get around to it.
                            alex // info@rubits.com
                              πŸ‘
                              • Bob JamesB Offline
                                Bob James
                                Any hope for this?
                                • X Offline
                                  xsnovi
                                  Thank you.
                                    reccoon
                                    Thank you!
                                      sags
                                      excellent tool, thank you very much for sharing.. πŸ‘
                                        Kato07
                                        Thanks for the plugin, works great!
                                          stevo tyelaap
                                          I always TT's comment and decide to download or not πŸ˜„
                                            rilian
                                            As a bit of a primitive learning experience, I tossed together a simple toolbar for this tool. I've tested under su8 on win7 though I can't see much reason it would fail on other setups.
                                            I used a magnet icon 24x24 which seems to work well when snapped next to other toolbars but it looks off kilter if the toolbar is floating.
                                            I have a decent amount of programming experience but zero w/ ruby and this is the first Sketchup ruby work I've done so please don't crush me if this toolbar doesn't work to expectations.
                                            Other than the toolbar code added in, the plugin is exactly the same as the most recent version of the plugin listed by the author. I stole the code from Frank Wiesner and Tig's mirror.rb script and modified it for this tool and supplied an icon that I grabbed off the internet.
                                            The attached .zip contains the modified .rb script and the .png icon file. Both go loose in the Sketchup plugins folder. Please feel free to modify the icon and use your own. Name it spp.png and you won't even have to change the .rb. Also please feel free to modify the code...
                                            Hope this helps somebody...
                                            a4_spp_tb_0.1.zip
                                            • 4 / 5
