    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 217.3k Views 65 Watching
      I finally got around to use this plugin. Very nice.
      Are you still developing it?
      I noticed a couple of things:
      1. It does not draw the input points
      2. It does not invalidate the view when the tool is activated
      • C
        caleb_barclay
        I love this script. It is perfect for roofs. I was wondering if there was anyway to enable it to "Snap" to a reference point. I have CAD drawings that I would like the extrusion to snap to.
        • plot-parisP
          plot-paris
          @thomthom said:
          Are you still developing it?d
          indeed, a4chitect. do you intend to do some further work on this plugin?
          • majidM
            majid
            woww. thanx mate.... really smart (you and the plugin, both πŸ˜‰ ) πŸ‘
            • P
              pitrak
              This is just what I needed for a project where almost nothing is orthogonal.
              Just like anyone else, I am wondering if this plugin will be developed any further? I am also convinced that this could become the standard pushpull for plugin people, but it still needs a lot of work.
              1. It leaves lines at the original position, which you have to delete manually.
              2. I would prefer the inferencing should to be the same as SU default PP behaviour
              3. integration with JPP would be great (and be perfectly in line with the concept of this plugin)
              a4chitect has not been active here for half a year.. Maybe Fredo6 can incorporate SmartPushpull in JPP? Or are there other options for collaboration?
              This plugin to me is one of the most promising and SU like plugins around. It makes a common problem a lot simpler to solve without adding complexity on another level. It's just a shame that the implementation is not up to the promises...
                rubits
                I will not claim that the FBI is extracting ideas from inside my mind. But I had infact developed a similar push pull tool some years back, but with a more native feel to it. Actually I also called it Smart Push Pull. It does not leave traces and it is completely fluid in operation. However it has some problems with antiprismatic prismatoids (OK, it sounds really scientific, but we make these shapes really often), and so I decided not to upload it to rubits. I have however looked at the script again recently, and I also have a few extra tricks up the sleeve that I think could improve the Push Pull tool, so I might release a version of it soon. I will tell you if I do get around to it.
                alex // info@rubits.com
                  πŸ‘
                  • Bob JamesB
                    Bob James
                    Any hope for this?
                    • X
                      xsnovi
                      Thank you.
                        reccoon
                        Thank you!
                          sags
                          excellent tool, thank you very much for sharing.. πŸ‘
                          • K
                            Kato07
                            Thanks for the plugin, works great!
                              stevo tyelaap
                              I always TT's comment and decide to download or not πŸ˜„
                                rilian
                                As a bit of a primitive learning experience, I tossed together a simple toolbar for this tool. I've tested under su8 on win7 though I can't see much reason it would fail on other setups.
                                I used a magnet icon 24x24 which seems to work well when snapped next to other toolbars but it looks off kilter if the toolbar is floating.
                                I have a decent amount of programming experience but zero w/ ruby and this is the first Sketchup ruby work I've done so please don't crush me if this toolbar doesn't work to expectations.
                                Other than the toolbar code added in, the plugin is exactly the same as the most recent version of the plugin listed by the author. I stole the code from Frank Wiesner and Tig's mirror.rb script and modified it for this tool and supplied an icon that I grabbed off the internet.
                                The attached .zip contains the modified .rb script and the .png icon file. Both go loose in the Sketchup plugins folder. Please feel free to modify the icon and use your own. Name it spp.png and you won't even have to change the .rb. Also please feel free to modify the code...
                                Hope this helps somebody...
                                a4_spp_tb_0.1.zip
                                  aldokali78
                                  thanx .... really smart
                                    Ralphxyz
                                    Which version is the latest?
                                    The top one would be logical but the bottom one has version that is much higher than the second one.
                                    I am going to guess at the bottom one.
                                    But a big Thanks,
                                    Ralph
                                      right! πŸ˜‰
                                      • sfto1S
                                        sfto1
                                        This is a cool plugin. Can someone advise if there is a version where native SU inferencing works with this tool?
                                        I downloaded the one from the original post from a4chitect and the inferencing does not work.
                                        • xiombargX
                                          xiombarg
                                          To make this plugin useful there needs to be a way to choose the axes inference lines before doing the operation. As it is, it seems useful on simpler shapes where there is only one inference line per vertex, but otherwise it usually doesn't get the result I would hope for.
                                          • T
                                            TheMurderArt
                                            nice plugin... you should try to put a restriction for the points of intersection
                                            • 4 / 5
