    Something like "follow me" tool is needed
    29 Posts 7 Posters 3.5k Views 7 Watching
    • TIGT Online
      You can also use ' weld' [free script from smustard.com] on preselected connected arcs etc into one 'curve' before using a tool, to avoid separate parts getting made...
        Or Recurve by Diggsey πŸ˜‰
        • mitcorbM Offline
          mitcorb
          A little way back you said in your reply: "next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker," Lines2tubes is an excellent script, but it will make segments of the tubes, and sometimes you want that. TIG's TubeAlongPath, or even PipeAlongPath makes smooth results. Just a thought.
            banan666
            Great, thank You very much Pilou for the amazing tutorials, I will try to make it tomorrow, because today I had problem with my PC, my hard disk was broken so I have to buy new one, then install windows and all the rest stuff.
            Im thinking all the time about this panel.
            http://s1.pokazywarka.pl/i/1711679/685769/bez-nazwy.jpg
            Now I now how to make pipe witch have the same width all the way, but how to change width, and depth at the same time. Like on the picture above, for example.
              With Curviloft maybe? Not even just change width but also the shape of the cross section (if you wish).
              • jeff hammondJ Offline
                  banan666
                  Ive been try to use the OSCoolean tool and Substract from Solid tools but Ive all the time some strange errors. OSCoolean give me "erroe of the intersect with" and some numbers, 21,2 etc. Substract from Solid its the same. When I made one line its ok, but the I want to take another one its not working beacause firt use change the model, and its not SOLID.
                  OSCoolean problem.rar
                    Before a dedicated plugin "Follow me Multiple" who is quasi terminated β˜€
                    here a workflow for one of your image πŸ˜‰
                    You will must use twice the Menu Window / Ruby console πŸ€“
                    Image 1 : Select all the Protrude's faces : Protrude by Jim Foltz
                    and input the text folling inside the Ruby Console for transform each faces on components
                    Must be on only one line (use the Notepad for verify)
                    Press Enter (Thx TIG) - Press the Select All, Right Click and copy past on your Ruby Console
                    m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                    Image 2
                    Give a thickness to the components selection
                    (again the text following must be on one line in the Ruby COnsole)
                    Press Enter (Thx Sdmitch) -Press the Select All, Right Click and copy past on your Ruby Console
                    mod=Sketchup.active_model;sel=mod.selection;sel.grep(Sketchup;;ComponentInstance).each{|c| c.definition.entities.each{|f|(f.pushpull -1;break) if f.class==Sketchup;;Face}}
                    Image 3
                    Make any component volume that you want
                    Select all the "faces components"
                    And Call the Component Dropper by Thomthom
                    Just click your module made has you want πŸ˜‰
                    That all! β˜€
                    Ps You can scale on x,y,z before or / and after the "Components Dropper"
                      And on image 2 you can put a randomly thickness! THX Sdmitch
                      Just use this line against the above
                      You replace "100" by any number you want! (rand*100)
                          mod=Sketchup.active_model;sel=mod.selection;sel.grep(Sketchup;;ComponentInstance).each{|c| c.definition.entities.each{|f|(f.pushpull -(rand*100);break) if f.class==Sketchup;;Face}}
                      THX Sdmitch! β˜€
                      • 2 / 2
