    Something like "follow me" tool is needed
    29 Posts 7 Posters 4.2k Views 7 Watching
      banan666
      I have tried it before, great tool, but it doesnt work for me with OSCoolean. All the time the same problem, I couldnt make Solid form, its all the time (Group 1 in model) in Entity info and I dont know what happening...
      TUBES1.skp
      • cottyC Offline
        cotty
        You just have to close the two ends...
        my SketchUp gallery
          You can also use ' weld' [free script from smustard.com] on preselected connected arcs etc into one 'curve' before using a tool, to avoid separate parts getting made...
            Or Recurve by Diggsey πŸ˜‰
            • mitcorbM Offline
              mitcorb
              A little way back you said in your reply: "next line2tube I got a lot of gapes in the joints. I dont Know how to fix them, so I made second try with other shape maker," Lines2tubes is an excellent script, but it will make segments of the tubes, and sometimes you want that. TIG's TubeAlongPath, or even PipeAlongPath makes smooth results. Just a thought.
                banan666
                Great, thank You very much Pilou for the amazing tutorials, I will try to make it tomorrow, because today I had problem with my PC, my hard disk was broken so I have to buy new one, then install windows and all the rest stuff.
                Im thinking all the time about this panel.
                http://s1.pokazywarka.pl/i/1711679/685769/bez-nazwy.jpg
                Now I now how to make pipe witch have the same width all the way, but how to change width, and depth at the same time. Like on the picture above, for example.
                  With Curviloft maybe? Not even just change width but also the shape of the cross section (if you wish).
                  • jeff hammondJ Offline
                      banan666
                      Ive been try to use the OSCoolean tool and Substract from Solid tools but Ive all the time some strange errors. OSCoolean give me "erroe of the intersect with" and some numbers, 21,2 etc. Substract from Solid its the same. When I made one line its ok, but the I want to take another one its not working beacause firt use change the model, and its not SOLID.
                      OSCoolean problem.rar
                        Before a dedicated plugin "Follow me Multiple" who is quasi terminated β˜€
                        here a workflow for one of your image πŸ˜‰
                        You will must use twice the Menu Window / Ruby console πŸ€“
                        Image 1 : Select all the Protrude's faces : Protrude by Jim Foltz
                        and input the text folling inside the Ruby Console for transform each faces on components
                        Must be on only one line (use the Notepad for verify)
                        Press Enter (Thx TIG) - Press the Select All, Right Click and copy past on your Ruby Console
                        m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e);g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                        Image 2
                        Give a thickness to the components selection
                        (again the text following must be on one line in the Ruby COnsole)
                        Press Enter (Thx Sdmitch) -Press the Select All, Right Click and copy past on your Ruby Console
                        mod=Sketchup.active_model;sel=mod.selection;sel.grep(Sketchup;;ComponentInstance).each{|c| c.definition.entities.each{|f|(f.pushpull -1;break) if f.class==Sketchup;;Face}}
                        Image 3
                        Make any component volume that you want
                        Select all the "faces components"
                        And Call the Component Dropper by Thomthom
                        Just click your module made has you want πŸ˜‰
                        That all! β˜€
                        Ps You can scale on x,y,z before or / and after the "Components Dropper"
                          And on image 2 you can put a randomly thickness! THX Sdmitch
                          Just use this line against the above
                          You replace "100" by any number you want! (rand*100)
                              mod=Sketchup.active_model;sel=mod.selection;sel.grep(Sketchup;;ComponentInstance).each{|c| c.definition.entities.each{|f|(f.pushpull -(rand*100);break) if f.class==Sketchup;;Face}}
                          THX Sdmitch! β˜€
                          • 2 / 2
