    Drawing 2D Floorplan walls from lines
    24 Posts 9 Posters 8.5k Views 9 Watching
      πŸ˜•
      Why not just use the Offset tool on several preselected edges ?
      Or use Move+Ctrl to Copy [Γ  la offset] on one preselected line with a given distance from the original, using inferences 'to set the plane' if necessary.
      Also the Tapemeasure tool offsets Guidelines if you drag off from a point on an edge, you can readily 'determine the plane' of this if needed. Then use these Guidelines to draw new line-work...
      There are many many ways to do this kind of thing πŸ˜’
      You really need to read/view some of the hundreds of Help docs and Videos, AND, more importantly, 'play around' with SketchUp, so that you thereby learn and better understand its real capabilities... [which I deduce far outweigh your current usage/understanding of it ?]
      Learn by doing - where 'doing' == 'playing around' !
      • P
        pier70
        actually I'm using move+ctrl to copy and tapemeasure, I think I'm usin' one of your plugin 2d tools if I'm not wronging, I'm searching to understand if the question is about my way to use SU that I demand to do like a cad that it is not, or if there are some fast way to do the floor plan by SU that I don't understand, in other way that isn't cad way, I'm following ...
        thank u Tig
        • GaieusG
          @pier70 said:
          What I'm saying is that if i have an image the best way do do an accurate 2D is not directly in SU but I must to use a cad. or i must to try to use SU like a cad, but one time I tryed but I remenber it was not too quick like a cad...
          You can in fact draw pretty accurate floor plans if you also have the measurements. In that case, I would not keep tracing images myself - but in the OP there were no dimensions added to the image.
          • P
            pier70
            Gai, I'm secure that SU could do an accurate 2d but what I'm looking for is if it could do a quick 2d accurate like it do the 3d that is very fast and intuitive. I'm doing also a 3d building that I hope to use for building drawing, I seen Nick Sonder video that are a must for example (mine is not so accurate...)excuse me for my bad english...
            • GaieusG
              I don't see why it could not actually. It's probably just a matter of getting used to the tools in 2D. True that I do not have much experience with any CAD application as I started straight in SU and for what I would use it "professionally", does not need those kinds of details.
              • pbacotP
                SU layout tools without plugins are very basic but they can do the job. One who is used to CAD has many quick layout tools. You just need to get used to how SU works and it can be accurate and pretty fast. For me it would still take longer than in my CAD application, but that's partly because I do not practice it in SU. I usually do the first layout in CAD.
                SU has inferences and automatic creation of faces that can make it faster than CAD sometimes--and help accuracy.
                  sonder
                  I draw all my floor plans in sketchup, but I would never set them up based upon the centerline of the wall. All contractors build based upon dimensions set to the face of stud or masonry. If you establish the wall based on the centerline you will always have to adjust your line to compensate for half the wall thickness, unless you don't care about framing layout.
                  • GaieusG
                    We were not really talking about real construction drawings here but 3D models based on imported images.
                    I'd certainly do my models differently if I am "designing" that building or if there are proper dimensions given in the image for instance. The above example was only a "quick and dirty" method for a model. It will not be accurate to dimensions but at least all the walls will be of equal thickness and parallel to the other side of the wall (oh my, how poor models I have seen!)
                      2D Tools by TIG πŸ˜‰
                      (in keep in mind that a arcs and circles are made with segments)
                        sonder
                        He mentioned these would be for a builder though. I typically start with something similar. I draw basically rectangular "bubble" diagrams, but sized to construction standards. Once I have a basic layout that works, I use the offset tool to create the walls, then trim accordingly. This goes very fast.
                        • gascatG
                          gascat
                          Thanks for your input guys.
                          What I am doing is "Artist Impressions" in 2D (nothing 3D for these floorplans)and no exact dimensions are being used.
                          I just wanted to speed up the way I draw 3D rectangles and nothing more really.
                          If I had the time and inclination to learn Ruby I would (and I am hoping in the future I might) write myself a plugin similar to Dieder's Line to Wall tool that converts a line (or bunch of lines) to a rectangle with no height as it's only 2D that I require for this project.
                          i appreciate your helpful comments and I admire you guys who write plugins for the SU community. πŸ˜„
                          cheers...Wayne
                          • massimoM
                            massimo Moderator
                            Have you already tried this one? You'll find it under the "draw" menu. It's customizable via TAB key. You can end the tool by pressing the enter key or by double click to complete a closed path.
                            • gascatG
                              gascat
                              Thanks heaps Massimo....that works quite well.
                              cheers...Wayne
                              • massimoM
                                massimo Moderator
                                You're welcome Wayne. πŸ˜„
                                • Mike LuceyM
                                  Mike Lucey
                                  ... maybe I am missing something here but if CAD drawings are available, would it not make sense to use PDF2CAD and bring them into SU, then clean up? Of course the PDF would have to be vector! Also I imagine the builder would be in a postion to obtain .dwg which would make more sense!
                                  http://visual-integrity.com/products/pdf2cad/
                                  • P
                                    pier70
                                    No Mike, if u have alredy a dwg there is not problem but if u have a jpeg or a pdf, from an image, when u redraw, the line that u are drawing are not accurate, u must correct a lot
                                    and if u have some quote u can re draw the floor plan but I think SU is slow in this if I compare it to a cad.
