    Plugin installation on Lion
    17 Posts 5 Posters 2.3k Views 5 Watching
      You might be mistaken...
      Sketchup.find_support_file("Plugins") will only return a path to an existing file/folder OR 'nil'.
      So either you are NOT following the path OR the folder is 'hidden' OR it's NOT where it ought to be πŸ˜•
      Use the Finder to find 'Plugins' on your system πŸ˜’
        No! You aren't starting in the right place. πŸ˜’
        This is the full path
          matarazzodesign
          That is as far out as I can go. I guess they restricted my access to the HD. I'll have to contact my IT department to see if they can help me get to the right location.
          Thanks for the help.
            driven
            Your /Library/ is hidden by default in Lion.
            it is easy to turn everything on from terminal, but this should open just the Sketchup folder.
            I put it in a code block so you can SELLECT ALL, copy and then paste into Terminal.app [found in the Utilities folder]
            open /Library/Application\ Support/Google\ SketchUp\ 8/SketchUp/
            you mayhave to hit return after pasting, and the folder should open.
            you mayhave to give an admin password, but if you installed SU than you are an administrator.
            otherwise get the IT boys to sort that out as well...
            Once the Sketchup folder opens, drag the Plugins folder to your sidebar and leave it there to easy use.
            hope this helps
              matarazzodesign
              Thanks, I'll give this a shot tomorrow at work.
                matarazzodesign
                Thanks for all of your help guys. It took a bit of tweaking but now I can access and use al the plugins my little heart desires.
                Once again thanks!
                  I'm glad you got it sorted out. πŸ‘
                    driven
                    Glad it's working,
                    Can you spell out your solution for others that may have the same problem in the future...
                    • blruuskaB
                      blruuska
                      matarazzodesign,
                      Could you provide the detailed steps needed to resolve this problem?
                        driven
                        if you can't find your plugins folder
                        copy/paste this into 'Ruby Console' found under SU's 'Window' menu item.
                        system('osascript<<OPEN
                        tell application "Finder"
                        	open ("/Library/Application Support/Google SketchUp 8/SketchUp/plugins/" as POSIX file)
                        end tell
                        OPEN
                        then hit return...
                          matarazzodesign
                          Hi All,
                          Sorry, I completely forgot to post how it all worked.
                          Driven helped me out by supplying the Terminal code to make the HD appear while running Lion.
                          you may have to hit return after pasting, and the folder should open.
                          you may have to give an admin password, but if you installed SU than you are an administrator.
                          After that showed me the HD location. I used Dave R's image to help me find the full path:
                          http://sketchucation.com/forums/download/file.php?id=75080&t=1
                          From there I made an alias of the Plugins folder (right-click, make alias) and moved it to My Documents, so I could access it easily.
                          Hope this helps future users, and thanks again for helping me figure this out!
