    Sketchup is Inacurrate???
    513 Posts 38 Posters 70.1k Views 38 Watching
    • Alan FraserA Offline
      Alan Fraser
      Strange! I just did it again in a fresh file and now I get a circle...but still with the correct entity info. Maybe the FormFonts layer is the magic ingredient. πŸ˜‰
      I am on V. 8.0.16846. I assume you two are as well.
      circle.skp
      3D Figures
        "but still with the correct entity info"? As it says Circle after merged?
        For me it said Arc until I reopened the file, then it said Circle. Your model opens with a "Circle".
        • jeff hammondJ Offline
          another quick point along these lines..
          @thomthom said:
          You'd think it should be able to do that. It nearly does that.
          aside from the ability for an arc to always remain an arc, an offset arc should create a new arc.. for one, it makes too much sense for an offset of an arc to be an arc but it will also further tighten up a consistent behavior throughout sketchup..
          if we draw a surface whose perimeters contain an arc(s) then push/pull the surface, the newly created edges will also be arcs..
          so that should happen as well in an offset.
          • DesertRavenD Offline
            DesertRaven
            I was wondering if the core problem with arches and the resulting shortcoming geometry is in fact what is keeping, or has kept, the developers from creating tools for curved surfaces?
            Like e.g the in ability to provide any mapping for curved surfaces or the native lack of the push pull tool to perform an extrusion on a curved surface?
            @ TIG Out of an architectural standpoint, this is what I expect of how it needs to be.
            The respective pieces of my arch need to be consistent and not perpendicular. Be it round or segmented same thing.
            http://img841.imageshack.us/img841/3737/archexpect.jpg
            simplicity is the ultimate sophistication
              Well, in theory we can create ourselves what SketchUp doesn't provide. Except some fundamental things such that we cannot introduce true curves - we cannot introduce new entity types. We can create abstractions. Like, in order to map curves surfaces and create ring and loop selections I wrote QuadFace Tools - which tries to build a toolkit that will let you create and manage non-planar quads. Similarly I'm developing BezierSurface, which allows you to create and manipulate (and UV map) quad-bezier-patches.
              However, since there is no way to hook into the native tools to make them understand these new abstractions I'm doing, I need to write a complete set of tools for everything.
              Mind you, aside from SketchUp's way of dealing with arcs, I find it's lack of the "quad" concept the most limiting. Everything becomes so much easier of surfaces are built up on units of quads. Mapping and traversing becomes logical and rational in terms of a computer - which doesn't have the insight to understand what the whole mesh really represent, only understanding the geometry on a the most naive level of vertices, edges and faces.
              • gillesG Offline
                gilles
                Just a basic, try to draw 3 tangent circles with native tools and tell me how much time you spend.
                Of course they must intersect.
                  hm... you where perhaps talking about the developers of SketchUp instead of plugin developers?
                    haha olav.. we need a better challenge .. i did that in 10 seconds using only the circle tool.. πŸ€“
                    oops.. gilles posted that example..
                    %(#FFFFFF)[β€’ using only the circle tool ---
                    β€’ draw a 3 sided circle
                    β€’ using each of the 3 vertices as center points, draw circles whose radii span to the midpoints of the triangle..
                      DesertRaven
                      I agree, there is alack of SU to create clean usable geometry. I used your quad tools and also some of TIG's tools to save the day.
                      I had a thought that I would like to convey to you guys, and that is SU has a tape measure tool, a protractor tool, to draw straight construction lines, BUT it does not have a compass tool.
                      Such a compass tool could help to snap on centers of any round geometry or it could help finding accurate intersections.
                      Anyone who works in architecture and has ever measured a house "as is" knows that you have to make diagonal measurements to verify a floor-plans squareness or to measure a floor-plan accurately that is at any given angel.
                      Maybe that would be a do-able plug in? just a circular construction line consisting of a dotted line like the straight construction line with the maximum accuracy that SU can give? With a radius as parameter and that is able to intersect lines and construction lines?
                        DesertRaven
                        Yes the SU developers. You guy's are doing a great job
                        • massimoM Offline
                          massimo Moderator
                          10 sec? πŸ˜„
                            10 sec? πŸ˜„
                            use the circle tool with 3 sides to draw your triangle.. shave off a few more seconds πŸ˜‰
                            • massimoM Offline
                              massimo Moderator
                              Indeed. πŸ˜†
                                DesertRaven
                                10 sec? πŸ˜„
                                If they are the same diameter, it's quite easy, draw a 3 sided polygon, make it a component, then draw a circle with e.g. 24 segments from each corner to the mid of each side of the polygon, voila!
                                • gillesG Offline
                                  gilles
                                  circles are not supposed to be equal and they must intersect.
                                  well show me your files.
                                    oh.. i didn't get the part about unequal circles.. so all the results discussed so far look something like this
                                    3circs.skp
                                    edit-- and we can't do 3 unequal circles in sketchup without using a plugin or a hack i'm not too fond of..
                                    and even then, we'll only get true results in certain cases.. (and i might be saying some of this too soon without thinking it all the way through.. but feel free to prove me wrong πŸ˜‰ )
                                    • gillesG Offline
                                      gilles
                                      in fact , what I was pointing is that you cannot draw accurate or precise with circle or arc tool, like bisector tangent etc... all things I learnt to draw by hand long time ago which is called geometry.
                                        πŸ‘ right gilles.. i was just ribbing you on the last page even though i knew what you were getting..
                                        that ability is sorely missed in SU
                                        a few times i've seen the idea of construction circles being in sketchup which would be great to have as well.
                                          DesertRaven
                                          You can get somewhat close with the arch tool, since it shows a tangent continuation. But of course far from accurate not only because of the segmentation.
                                          So I still wonder if someone could write a compass plug in for Sketchup? To create circular construction lines?
                                          Or is that just a nice fantasy?
                                          • gillesG Offline
                                            gilles
                                            That is the reason I am looking to Rhino, Bonzai and Moi.
                                            At this point I really need to draw accurately.
                                            It has been a long time we were asking for fix in sketchup with poor replies. πŸ‘Ž
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 24 / 26
