    Sketchup is Inacurrate???
    513 Posts 38 Posters 193.9k Views 38 Watching
      [EDIT] unless there's a way to make su continue to see the arc as an arc even after joining two together? i.e.- once an arc - always an arc until the user explicitly says it's no longer an arc or deforms it in such a way that it breaks the arc like properties ?? β˜€
      [/EDit]
      You'd think it should be able to do that. It nearly does that.
      If you draw a Circle - Entity Info says Circle, 24 segments.
      Draw a line between two vertices of that circle and you get two arcs with 12 segmetns each.
      Erase the edge between them and SketchUp merges the two arcs into a single Arc with 24 segments. Now here's the little extra head scratcher - save, close and reopen the file. Select the curve and notice that Entity Info once again says Circle. o_O
      Same thing happens when I do what you describe. Take a 90 degree Arc and copy and paste it together into an circle. All though, immediately they appear as four arcs. But if I draw temp edges at the arc ends and erase them SketchUp will merge the arcs together. Again I get an 24 segment arc, which when the model is reopened, becomes a Circle.
      I even tried with Vertex Tools to run Heal Vertices on the four arcs forming the apparent circle and that also yielded the same result.
      So SketchUp nearly does what you describe - but the healing function needs to be teased.
      While the nature of SketchUp isn't to present true arcs in the viewport it sure is room for improvements
      • jeff hammondJ
        haha.. nice find.. o_O indeed!
        • Alan FraserA
          Alan Fraser
          I'm not seeing that. I still get an arc of 24 segments...exactly as when closed.
          However, if I get to the stage of creating an arc of 24 segments and then copy either the face or the edge (or both) I get a new circle of 24 segments that is recognised as such. Seemingly the simple act of copying recreates a circle entity.
          3D Figures
            Can you post the file? I'm curious to whether I can find the difference between our attempts. Ruby might help me.
            • jeff hammondJ
              yeah.. strange.. i'm getting the same results outlined by tt
              • Alan FraserA
                Alan Fraser
                Strange! I just did it again in a fresh file and now I get a circle...but still with the correct entity info. Maybe the FormFonts layer is the magic ingredient. πŸ˜‰
                I am on V. 8.0.16846. I assume you two are as well.
                circle.skp
                3D Figures
                  "but still with the correct entity info"? As it says Circle after merged?
                  For me it said Arc until I reopened the file, then it said Circle. Your model opens with a "Circle".
                  • jeff hammondJ
                    another quick point along these lines..
                    aside from the ability for an arc to always remain an arc, an offset arc should create a new arc.. for one, it makes too much sense for an offset of an arc to be an arc but it will also further tighten up a consistent behavior throughout sketchup..
                    if we draw a surface whose perimeters contain an arc(s) then push/pull the surface, the newly created edges will also be arcs..
                    so that should happen as well in an offset.
                    • DesertRavenD
                      DesertRaven
                      I was wondering if the core problem with arches and the resulting shortcoming geometry is in fact what is keeping, or has kept, the developers from creating tools for curved surfaces?
                      Like e.g the in ability to provide any mapping for curved surfaces or the native lack of the push pull tool to perform an extrusion on a curved surface?
                      @ TIG Out of an architectural standpoint, this is what I expect of how it needs to be.
                      The respective pieces of my arch need to be consistent and not perpendicular. Be it round or segmented same thing.
                      http://img841.imageshack.us/img841/3737/archexpect.jpg
                      simplicity is the ultimate sophistication
                        Well, in theory we can create ourselves what SketchUp doesn't provide. Except some fundamental things such that we cannot introduce true curves - we cannot introduce new entity types. We can create abstractions. Like, in order to map curves surfaces and create ring and loop selections I wrote QuadFace Tools - which tries to build a toolkit that will let you create and manage non-planar quads. Similarly I'm developing BezierSurface, which allows you to create and manipulate (and UV map) quad-bezier-patches.
                        However, since there is no way to hook into the native tools to make them understand these new abstractions I'm doing, I need to write a complete set of tools for everything.
                        Mind you, aside from SketchUp's way of dealing with arcs, I find it's lack of the "quad" concept the most limiting. Everything becomes so much easier of surfaces are built up on units of quads. Mapping and traversing becomes logical and rational in terms of a computer - which doesn't have the insight to understand what the whole mesh really represent, only understanding the geometry on a the most naive level of vertices, edges and faces.
                        • gillesG
                          gilles
                          Just a basic, try to draw 3 tangent circles with native tools and tell me how much time you spend.
                          Of course they must intersect.
                            hm... you where perhaps talking about the developers of SketchUp instead of plugin developers?
                            • jeff hammondJ
                              haha olav.. we need a better challenge .. i did that in 10 seconds using only the circle tool.. πŸ€“
                              oops.. gilles posted that example..
                              %(#FFFFFF)[β€’ using only the circle tool ---
                              β€’ draw a 3 sided circle
                              β€’ using each of the 3 vertices as center points, draw circles whose radii span to the midpoints of the triangle..
                              • DesertRavenD
                                DesertRaven
                                I agree, there is alack of SU to create clean usable geometry. I used your quad tools and also some of TIG's tools to save the day.
                                I had a thought that I would like to convey to you guys, and that is SU has a tape measure tool, a protractor tool, to draw straight construction lines, BUT it does not have a compass tool.
                                Such a compass tool could help to snap on centers of any round geometry or it could help finding accurate intersections.
                                Anyone who works in architecture and has ever measured a house "as is" knows that you have to make diagonal measurements to verify a floor-plans squareness or to measure a floor-plan accurately that is at any given angel.
                                Maybe that would be a do-able plug in? just a circular construction line consisting of a dotted line like the straight construction line with the maximum accuracy that SU can give? With a radius as parameter and that is able to intersect lines and construction lines?
                                • DesertRavenD
                                  DesertRaven
                                  Yes the SU developers. You guy's are doing a great job
                                  • massimoM
                                    massimo Moderator
                                    10 sec? πŸ˜„
                                    • jeff hammondJ
                                      10 sec? πŸ˜„
                                      use the circle tool with 3 sides to draw your triangle.. shave off a few more seconds πŸ˜‰
                                      • massimoM
                                        massimo Moderator
                                        Indeed. πŸ˜†
                                        • DesertRavenD
                                          DesertRaven
                                          10 sec? πŸ˜„
                                          If they are the same diameter, it's quite easy, draw a 3 sided polygon, make it a component, then draw a circle with e.g. 24 segments from each corner to the mid of each side of the polygon, voila!
                                          • gillesG
                                            gilles
                                            circles are not supposed to be equal and they must intersect.
                                            well show me your files.
                                            • 11
                                            • 12
                                            • 13
                                            • 25
                                            • 26
                                            • 11 / 26
