    Questions raised by Nick Sonder's videos
    layout
    30 Posts 9 Posters 6.0k Views 9 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Edson, thanks for kicking this thread off. I see that we have Nick here to advise also TIG to keep us on the 'straight and narrow' 😉
      I'd like to suggest that some kind of a simple house model is agreed / worked on so that we can all try out the various processes and compare notes. It might make life easier all around.
      What do you all think?
      • porch_unpluggedP Offline
        porch_unplugged
        @bmike said:
        thats a nice technique~!
        i use a similar technique for shop drawings / structural work where i need to isolate the framing, and i don't want to 'see into' the structure.
        damn, i thought i was coming up with an original idea, it must have been implanted in my subconscious from watching one of your videos 😎 .
        @bmike said:
        changing the opacity is a nice trick... although i imagine it only works in 'hybrid' or 'raster'.
        I'm not using Layout, importing jpegs into CAD (hense the scale bar) and setting up my sheets that way.
          porch_unplugged
          I think Nick should just upload all his drawings! and we take what we need. 😛
            Mike Lucey
            I doubt Nick would do that and I would not expect such. I also think that a simpler building would work for folks new to the process in LayOut.
              porch_unplugged
              No, of course not. He has been very generous to Google/Trimble in opening up his projects and procedures.
              I think Nick has pretty much demonstrated his working process, and I've read Paul Lee's construction documents publication and I've taken bits from both, and added my own bits to form my own processes and procedures. Like I've said before, I'm not using Layout at the minute, so the processes are a little different for me.
              In gearing up my sketchup use recently, I've found it a little difficult to organise my drawings and drawing titles (probably as much to do with the outdated system we use in our office as with a new software/file use). Basically in CAD I would do a single 2D drawing per CAD file which was properly filed. But with different scenes and exports, I'm having to form new ways of filing, drawing numbering & issue sheets etc. So I was thinking of doing a few posts on how I've dealt with it. Fierce boring stuff altogether, but something I think is very important, certainly in my line of work where a strong record of drawings, specifications etc. issued, needs to be kept.
              So, when I get a bit of time, I'll do something out.
                Mike Lucey
                Brian, you have put your finger on a problem area when it comes to LayOut. Even Nick might admit that the way drawings have to be filed is a little haphazard at best.
                I look forward to you reading about your process and won't find it boring in the slightest. I also imagine the folks at Trimble SketchUp will be taking note. If LayOut is being put forward as a serious Con Doc production tool this area, filing, will have to be standardized I feel.
                  sonder
                  With regards to files, I organize mine the same way I did with acad. I have a main SU folder that has the base SU files and a folder named LAYOUT. I keep all drawing types as separate files in Layou, such as, site plans, floor plans, sections, etc. works very easy in keeping things organized.
                  • bmikeB Offline
                    bmike
                    i've come up with this method:
                    sketchup file is named 'clientname-clientname(optional).skp
                    so 'tfg-bridge.skp'
                    as i develop the model, i do a 'save a copy... and add the date, or occassionally some descriptive text.
                    i'll often also have models that strip down to details, so things would be 'clientname-clientname-joinery.skp'
                    so 'tfg-bridge.skp' and tag-bridge-joinery.skp' and tfg-bridge-steel.skp'.
                    i follow the same 'save a copy as...' date formatting as above.
                    this way, i try to keep the file without dates as my working file, and the other files used as backups or places to get back to specific changes, etc.
                    keeping the most recent file name basic and the same means i can find it easily, and my layout drawing is always referencing the same file(s).
                    i do the same with my layout files, but generally just have 1 working file, and save as versions with dates.
                    i occassionally break up larger projects into 2-3 layout files, to save rendering time.
                      sonder
                      Mike, I also keep dated "versions". The way I keep track is "Project Name"_1. When a change occurs it goes to "Project Name"_2. This way the most recent version is easily accessed and referenced easily. Most projects usually go to version 4 or 5, although I had one that went to 22! That was a little painful, but this method made it work easily.
                      On the deliverables which are typically .jpeg and .pdf files, I have separate folders for those. In the JPEG folder and PDF folders are sub folders that are named by date such as "130107" (2013, January 7th). Using this format is really nice as explorer keeps them in order and back up is a breeze.
                      • pbacotP Offline
                        Of interest, though, is how the SU and LO files relate, are broken down for a typical project, and named, keeping the linkage simple. Nick wrote about that a little before. One problem is keeping names short enough because sometimes a search field or listing will not show the full names.
                        I keep a "Temporary Folder" too. This is for test runs and misc. workflow files and keeps my project folders clear. It hasn't been cleared out for a long time, but I only put something in there that is a copy or expendable.
                          porch_unplugged
                          Good suggestions there.
                          I've posted another thread with my procedures. Quite similar to Nicks by the looks of it.
                            porch_unplugged
                            Nick, if you're out there... I was just watching your videos again, and something stuck in my mind. You seem to be spending a lot of time doing out your linework for export to Layout, any reason why you don't use 'Section cut face'? thought it would have been ideal for your work process.
                              I discussed my SectionCutFace with Nick at Basecamp... What he does manually from a grouped section-cut set of edges has a few advantages: he is used to doing it his way [and had only recently 'found' plugins and has yet to 'experiment'], and he can also treat the cut window-frames etc differently from walls, as the dimensioning is to the 'hole'...
                                sonder
                                Tig is correct. I am a pretty much a stock SU user. I don't use many plugins at all that are related to modeling. One of my hopes this year is to experiment a little more. It doesnn't take me all that long to generate the line work for a plan with my current process. At most 10 minutes per floor with a larger home, but that does add up. I certainly would love to have the linework generated perfectly with a simple click.
                                  porch_unplugged
                                  Section Cut face is a great tool (many thanks TIG 👍 ). It doesn't always get it 100% right, but it usually takes just a few clicks to fix and then you're done.
                                    mwm5053
                                    Well seems no one wanted to take Mayor Mike up on his suggestion so I'll lay myself out here. The model was done using Housebuilder plugin, section cut face and Vali Architect instant roof plugin (free). In using the HB plugin it puts the layered skin on Layer0_skin so I put all the wall studs on a separate layer called stud walls to control visibility. I haven't textured this model or put moldings in it yet. I use a different model of the same house with textures and vegetation for rendering purpose.
                                    House 1b.skp
                                    2011 iMac
                                    SU 2015 Pro, 2017 Make
                                    V2 Twilight
                                    macOS Sierra 10.12.5
                                      sketchy
                                      The Sonders videos were quite an inspiration to me. I have been modeling in SketchUp and printing plans in AutoCad. I have tried LO a few times and found it too slow and unstable however I am looking forward to trying out his workflow. He seems to have created a workaround for these problems with LO. I'm happy because I sort of despise AutoCad.
                                      Anyway my question about his workflow is how he uses SU and scenes. He mentions that he doesn't like to have too many scenes per model so he will use one file as the master file and then reference this master model in other SU files but only change the scenes. Any editing of the model is done exclusively in the master file and the others are just a way to alter presentation and views of the master. Note that I am not talking about doing this in LO but in SU.
                                      This is something I didn't realize that SU could do and I'm sure it's a simple procedure but couldn't find info for how to do it. Could someone walk me through it?
                                      thanks so much.
                                        sonder
                                        Hi Sketchy:
                                        You simply open a new SU file. Under File/Import, you select the file established as your base file. It then inserts the file as a component into the new file. After you edit the base file, right click or select the inserted component and select "reload". It will then update the file based upon the last save.
                                          sketchy
                                          Thanks for the quick reply, I thought it would be something along those lines. So I imagine you lock it as a component and then just change styles, scenes, and sections to display as you like.
                                          Thanks again for your contributions and willingness to share your well thought out workflow.
                                            mwm5053
                                            @ Sonder I've been following this but you lost me when you said "File/Import " ,only options I see are Image file, texture or match photo
                                            2011 iMac
                                            V2 Twilight
