    Follow me tool
    19 Posts 6 Posters 1.2k Views 6 Watching
    • cottyC
      cotty
      If visually correct is the goal, you can use the FAK plugin. If you want to build it afterwards, it will not work this way, as Dave mentioned.
      Here is the FAK version with hidden lines on, so you can see that the shape will be distorted...
      my SketchUp gallery
      • Jean LemireJ
        Jean Lemire
        Hi folks.
        Although the Follow me and keep plugin can solve this problem, you must ask yourself how you would build such a baluster using a C channel in real life.
        The solution is to effectively use an horizontal part between the sloped part and the part at 90° because the plugin will effectively warp the transition part. In real life, not that many people will want to warp such a channel. It is much easier and quicker and also nicer to use an horizontal piece, even if it is a short one.
        Just ideas.
          ShrockFab
          Thanks again all. One oth issue Im contending with is the situation I have pictured. Wow, any thoughts. I dont understand why it wants to do this.
            ShrockFab
            that strange joint in the inside corner
              How did you draw that? Follow Me? Where is the path?
              Here are two examples. One with the path on top of the channel. The other on the bottom. Both worked just fine.
              Think about it in real life. This would be made of two pieces of channel and they would be mitered at an angle that bisects that angle between them. That's what you need to be drawing.
              By the way, your channel is inside out. Correct the face orientation.
                ShrockFab
                Dave I found that my pitch went off at an angle EVER SO SLIGHTLY. Also what is the importance of having faces reversed" inside out". Additionally, Im posting two pics, one far away and one close. Why when far away can I see objects through faces. Is there a way to fix that. Thanks all again. I will need some help along the way at times as I am using Sketchup provisionally now and not a hobbyist. Thanks for any and all help.
                  You're using it "provisionally" or professionally now? They are different things.
                  The reason you see lines through faces when zoomed out but not when zoomed in is that proportionally the lines are closer to having the same distance from the camera as the face. They get to be within a certain range and the tolerance of the graphics to display one instead of the other is less than the difference in distance.
                  There are several reasons for keeping face orientation correct. One common reason has to do with rendering. Many rendering applications will render back faces as nothing even if there's a material applied to the face. By nothing I mean it'll show as black empty space. Also it is just plain sloppy workmanship. You can either correct the faces as you go or go back through the entire model and fix them.
                    ShrockFab
                    Professionally I believe
                      ShrockFab
                      Thanks again guys. I made good progress on this project with your great tips.
                        Excellent! That actually looks like something that could be built.
                        • massimoM
                          massimo Moderator
                          Good work indeed. 👍
                            ShrockFab
                            Thanks Dave. Bid has been submitted and approved. We are building it. I love my job and Sketchup because we can see all the projects details and then watch it come to life. On top of that I get to build some of it when I have time. I'm building a career from Sketchup and this is my life. I'm grateful to the creators and wizards of this program. Have a good one fellas.
