    Image Brighter than normal
    renderpluginsextensions
    8 Posts 4 Posters 483 Views 4 Watching
      jmarcinho
      I`m trying to learn v-ray but when I follow this first lesson http://www.vray.com/vray_for_sketchup/manual/render_options_for_vray_for_sketchup.shtml
      But instead of getting a dark gray scene rendering the three chairs file with the default settings I`m getting this very bright image.
      http://img541.imageshack.us/img541/5200/chairss.jpg
      I`m using SU 8 free version.
      What am I missing ? What should I do ?
      • massimoM Offline
        massimo Moderator
        Hi, no need to post three times the same topic. New members have to wait just a bit for a moderator's approval. (for the first three posts)
          jmarcinho
          Sorry, I`ve just realized that.
          • massimoM Offline
            massimo Moderator
            No problem and welcome. ๐Ÿ˜„
            • StinkieS Offline
              Stinkie
              Wild guess: you're using sunlight and haven't turned on the physical camera. Turn it on, adjust the exposure settings.
                jmarcinho
                How do I turn sunlight off ?
                • V Offline
                  valerostudio
                  Sunlight is controlled by GI. Here are some recommendations to help you on your learning path.
                  1. I wouldn't use this file or the tutorials that go along with it. It's from an older version of VRay and if you are using 1.49.01 these tutorials, although helpful, are outdated.
                  2. Go to the Chaos YouTube page and watch all of the videos for VR4SU. These are very informative. The link is in the stickies of these forums.
                  3. Review the VR4SU manual http://www.vray.com/vray_for_sketchup/manual/
                    jmarcinho
                    Thank you very much, very good recommendations, now I feel I`m going to improve my learning process.
