    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 113.4k Views 35 Watching
      Changed line 253 to:
      definition.entities.each{|e| block.call(e, s*scale)}
      Working! 😄
        Here's the list of material in a model where I needed to size down the textures:
        Before:
        === TEXTURE MATERIALS BY SIZE ===
        Material4
          Size; 4000x4000 pixels
          Size; 45.78 MB estimated uncompressed RGB
          Size; 61.04 MB estimated uncompressed RGBA
          Path; C;/Users/ktn/AppData/Local/Temp/VfSTextureCache
        Material13
        Material3
          Size; 2255x1782 pixels
          Size; 11.50 MB estimated uncompressed RGB
          Size; 15.33 MB estimated uncompressed RGBA
        Material14
        Material1
          Size; 2048x1536 pixels
          Size; 9.00 MB estimated uncompressed RGB
          Size; 12.00 MB estimated uncompressed RGBA
        black3
          Size; 2814x850 pixels
          Size; 6.84 MB estimated uncompressed RGB
          Size; 9.12 MB estimated uncompressed RGBA
          File; glass.psd
          Path; E;\LIBRARY\DIGITAL LIBRARY\MORQ LIBRARY TEXTURES\Emiliano
        black1
          File; glass.psd
        treverk1
          Size; 1500x1500 pixels
          Size; 6.44 MB estimated uncompressed RGB
          Size; 8.58 MB estimated uncompressed RGBA
        treverk2
        Material15
          Size; 1416x1416 pixels
          Size; 5.74 MB estimated uncompressed RGB
          Size; 7.65 MB estimated uncompressed RGBA
        Material8
          Size; 1417x1408 pixels
          Size; 5.71 MB estimated uncompressed RGB
          Size; 7.61 MB estimated uncompressed RGBA
          File; Material8_extractedTex7662.tif
        Material16
          File; Material16_extractedTex62.tif
        Material5
          Size; 1000x975 pixels
          Size; 2.79 MB estimated uncompressed RGB
          Size; 3.72 MB estimated uncompressed RGBA
        Material30
        Then I ran the script, got some messages:
        black1; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
        black3; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
        I assume PDS files are not supported?
        After:
        black3
          File; glass.psd
        black1
          File; glass.psd
        Material15
        treverk1
          Size; 512x512 pixels
          Size; 768.00 KB estimated uncompressed RGB
          Size; 1.00 MB estimated uncompressed RGBA
          Path; C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480
        Material4
        treverk2
        Material13
        Material16
          Size; 512x508 pixels
          Size; 762.00 KB estimated uncompressed RGB
          Size; 1016.00 KB estimated uncompressed RGBA
        Material8
        Material5
          Size; 512x499 pixels
          Size; 748.50 KB estimated uncompressed RGB
          Size; 998.00 KB estimated uncompressed RGBA
        Material30
        Material3
          Size; 512x404 pixels
          Size; 606.00 KB estimated uncompressed RGB
          Size; 808.00 KB estimated uncompressed RGBA
        Material14
        Material1
          Size; 512x384 pixels
          Size; 576.00 KB estimated uncompressed RGB
          Size; 768.00 KB estimated uncompressed RGBA
        Notice Material15 which is a PNG still is larger than 512px. Why is that? There was no messages about this file.
          Aerilius
          It seems SketchUp's texture writer does not write psd files. In that case, I'll probably force a default extension.
          I have no idea what could cause to skip Material15. Is it reproducible? Can you send me a file with that material and its geometry (and group nesting...).
            It's 8MB (after removing the two PSD textures)
            PM me your email address and I'll send it to you.
              Aerilius
              I think I have fixed it now.
              Also the texture writer can export PSDs (I have no idea why these failed), but it can't convert psd into other formats by setting a different file extension.
                Does the texture resizer change the format?
                  Aerilius
                  Here not.
                  But the underlaying ImageMagick.rb has the option to (temporarily) change lossy formats into lossless bmp. I use that in another plugin, mainly because bmps process much faster.
                  • OxerO
                    Oxer
                    I have installed the last version of the plugin (1.4.3 for Mac OSX) and when i run SU it appears a Console Error:
                    I work on OSX 10.8.2, SU 8 Pro
                      Aerilius
                      I fixed it (1.4.4). Sorry, it was a merging mistake.
                      • OxerO
                        Oxer
                        I have installed the 1.4.4 version for Mac OSX and when I call to the plugin the boxes input are empty, I select Percentage, I introduce 50%, after I push Apply button then it appears this Error in Console Ruby:
                        I have translated the plugin to spanish language but the plugin window's is in English.
                        Spanish Language for Texture Resizer
                        Mac OSX 10.8.2, SU Pro 8
                          Aerilius
                          I think I have now found the issue. Can you try to download it again?
                          And many thanks for the translation!!!
                          [I thought I had posted this reply yesterday, I don't know how it got lost.]
                          • OxerO
                            Oxer
                            I have reinstalled the 1.4.4 version and the plugin runs fine (the translation works ok), but when i push Apply button it appears the icon Processing... and in the Ruby console this message:
                            I have seen a skp_textureresizer94750 folder in this path /private/var/folders/2y/lg9fyd494rddw7s_xr5zz2yr0000gn/T/skp_textureresizer94750 but only It contains one image.
                            I hope you can help me, if you need more info, tell me it.
                            Mac OSX 10.8.2, Sketchup 8 Pro
                            Happy New Year!! 😄
                            New Spanish Language file.
                            TextureResizer_ES.strings.zip
                              Aerilius
                              I published the new version 1.4.5
                                Aerilius
                                Small update (1.4.7):
                                • added icon
                                • OxerO
                                  Oxer
                                  I can't see the icon in Mac OSX 10.8.2, the plugin (1.4.7) works fine only the icon problem. Non Ruby console Error.
                                    Aerilius
                                    Menus don't have icons. The plugin doesn't include a (one button) toolbar, but an icon is the pre-condition for any future toolbars 😉
                                    • OxerO
                                      Oxer
                                      I have added one line to the TextureResizer. rb and now i can see the icon plugin. This is the line:
                                      "UI::Toolbar.new(@@translate["Resize Textures").add_item(cmd_resize)]"
                                      This line go after this line: " UI.menu("Plugins").add_item(cmd_resize)"
                                      Thanks for the icons!!
                                      PS: The plugin works fine, when you push the icon, it appears the plugin's window. 👍
                                      • P
                                        paolo
                                        I should be missing something cause I have got make Unique Texture++ and Texture Resizer, the last one is not doing anything.
                                        I have been using Goldilocks v2.0 to help me notice what textures to are too big on view.
                                        Could some one tell me whats wrong with Texture Resizer? there is any other plugin? how can I choose better texture size?
                                        Thx
                                        • T
                                          taro824
                                          Thank you for the Great plug-in but I'm having a problems.
                                          I got the message from the Ruby console
                                          Error #<NoMethodError:undefined method putsv' for #<File:0x1ed5eecc>.> C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:643:in run_shell_command'
                                          C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:641:in open' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:641:in run_shell_command'
                                          C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/ImageMagick.rb:465:in execute' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:290:in initialize'
                                          C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:196:in new' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:196:in process'
                                          C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:164:in options_dialog' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in call'
                                          C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in show_modal' C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:177:in options_dialog'
                                          C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:128:in `run'
                                          C:/PROGRA~1/Google/GOOGLE~3/Plugins/ae_TextureResizer/TextureResizer.rb:101
                                          quietly_force_sync_mats_cb just called
                                          Did I missed something when I installed the plugin ?
                                            There is a simple typo in the code - probably 'v' was pressed instead of 'ctrl+v' to paste.
                                            The original author Andreas needs to correct it...
                                            In the meanwhile you can correct it yourself in your copy...
                                            Open the file 'ImageMagick.rb' in the 'ae_TextureResizer' subfolder in your Plugins folder, using Notepad.exe and look for the text saying:
                                            f.putsv%[cd "#{@cache_dir}"]
                                            around line #643.
                                            Change it to read:
                                            f.puts %[cd "#{@cache_dir}"]
                                            I.E. replace the 'v' at the end of the 'puts' with a <space>.
                                            Save the file.
                                            Restart SketchUp and retest, it should now work... 😄
                                            • 4 / 6
