    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 108.6k Views 35 Watching
      Jspro
      yes i was able to load the resizer and tried to use it on my model, it wiped away the textures replace them with white faces , it was set by default at 50%, did this twice and tried to use the limit texture size with same results. is there something that im missing? thanks john
        krokberg
        I thought that I try the plugin to optimize some models that ware sent to me but I ran into a problem. When trying to run "Apply" I get the following error:
        Error #<NameError:uninitialized constant AE::Bounds.>
        I'm using SketchUp 8.0.3117 with Texture Resizer 1.4.0 and ImageMagick 6.8.0.
        Any clues to what the problem might be?
          Aerilius
          Oh, thanks, I didn't notice that when testing. It should be AE::TextureResizer::Bounds.
          I fixed it in version 1.4.1.
            Just tried this - wanted to ensure texture where no larger than a given size.
            I set percentage to 100% as I wanted to keep textures smaller at their original size - then I enabled Limit texture size.
            I got this error:
            Error #<NoMethodError:undefined methodempty?' for nil:NilClass.>`
              Strange that there isn't any backtrace...
                Aerilius
                I found the bug and fixed it. The backtraces became lost because of a rescue Exception.
                  Thanks for that. 😄
                  Though ... I broke it again... 😕
                  Error #<NoMethodError;undefined method `entities' for #<Sketchup;;ComponentInstance;0x773ec0c>.>
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;253;in `initialize'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `call'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `initialize'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `each'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `new'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `process'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;188;in `options_dialog'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `call'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `show_modal'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `options_dialog'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;114;in `run'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;61
                  It appear you're trying to use ComponentInstance.entities which doesn't exist in the API - all though a few plugins add this method to the ruby classes.
                    Changed line 253 to:
                    definition.entities.each{|e| block.call(e, s*scale)}
                    Working! 😄
                      Here's the list of material in a model where I needed to size down the textures:
                      Before:
                      === TEXTURE MATERIALS BY SIZE ===
                      Material4
                        Size; 4000x4000 pixels
                        Size; 45.78 MB estimated uncompressed RGB
                        Size; 61.04 MB estimated uncompressed RGBA
                        Path; C;/Users/ktn/AppData/Local/Temp/VfSTextureCache
                      Material13
                      Material3
                        Size; 2255x1782 pixels
                        Size; 11.50 MB estimated uncompressed RGB
                        Size; 15.33 MB estimated uncompressed RGBA
                      Material14
                      Material1
                        Size; 2048x1536 pixels
                        Size; 9.00 MB estimated uncompressed RGB
                        Size; 12.00 MB estimated uncompressed RGBA
                      black3
                        Size; 2814x850 pixels
                        Size; 6.84 MB estimated uncompressed RGB
                        Size; 9.12 MB estimated uncompressed RGBA
                        File; glass.psd
                        Path; E;\LIBRARY\DIGITAL LIBRARY\MORQ LIBRARY TEXTURES\Emiliano
                      black1
                        File; glass.psd
                      treverk1
                        Size; 1500x1500 pixels
                        Size; 6.44 MB estimated uncompressed RGB
                        Size; 8.58 MB estimated uncompressed RGBA
                      treverk2
                      Material15
                        Size; 1416x1416 pixels
                        Size; 5.74 MB estimated uncompressed RGB
                        Size; 7.65 MB estimated uncompressed RGBA
                      Material8
                        Size; 1417x1408 pixels
                        Size; 5.71 MB estimated uncompressed RGB
                        Size; 7.61 MB estimated uncompressed RGBA
                        File; Material8_extractedTex7662.tif
                      Material16
                        File; Material16_extractedTex62.tif
                      Material5
                        Size; 1000x975 pixels
                        Size; 2.79 MB estimated uncompressed RGB
                        Size; 3.72 MB estimated uncompressed RGBA
                      Material30
                      Then I ran the script, got some messages:
                      black1; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
                      black3; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
                      I assume PDS files are not supported?
                      After:
                      black3
                        File; glass.psd
                      black1
                        File; glass.psd
                      Material15
                      treverk1
                        Size; 512x512 pixels
                        Size; 768.00 KB estimated uncompressed RGB
                        Size; 1.00 MB estimated uncompressed RGBA
                        Path; C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480
                      Material4
                      treverk2
                      Material13
                      Material16
                        Size; 512x508 pixels
                        Size; 762.00 KB estimated uncompressed RGB
                        Size; 1016.00 KB estimated uncompressed RGBA
                      Material8
                      Material5
                        Size; 512x499 pixels
                        Size; 748.50 KB estimated uncompressed RGB
                        Size; 998.00 KB estimated uncompressed RGBA
                      Material30
                      Material3
                        Size; 512x404 pixels
                        Size; 606.00 KB estimated uncompressed RGB
                        Size; 808.00 KB estimated uncompressed RGBA
                      Material14
                      Material1
                        Size; 512x384 pixels
                        Size; 576.00 KB estimated uncompressed RGB
                        Size; 768.00 KB estimated uncompressed RGBA
                      Notice Material15 which is a PNG still is larger than 512px. Why is that? There was no messages about this file.
                        Aerilius
                        It seems SketchUp's texture writer does not write psd files. In that case, I'll probably force a default extension.
                        I have no idea what could cause to skip Material15. Is it reproducible? Can you send me a file with that material and its geometry (and group nesting...).
                          It's 8MB (after removing the two PSD textures)
                          PM me your email address and I'll send it to you.
                            Aerilius
                            I think I have fixed it now.
                            Also the texture writer can export PSDs (I have no idea why these failed), but it can't convert psd into other formats by setting a different file extension.
                              Does the texture resizer change the format?
                                Aerilius
                                Here not.
                                But the underlaying ImageMagick.rb has the option to (temporarily) change lossy formats into lossless bmp. I use that in another plugin, mainly because bmps process much faster.
                                • OxerO Offline
                                  Oxer
                                  I have installed the last version of the plugin (1.4.3 for Mac OSX) and when i run SU it appears a Console Error:
                                  I work on OSX 10.8.2, SU 8 Pro
                                    Aerilius
                                    I fixed it (1.4.4). Sorry, it was a merging mistake.
                                    • OxerO Offline
                                      Oxer
                                      I have installed the 1.4.4 version for Mac OSX and when I call to the plugin the boxes input are empty, I select Percentage, I introduce 50%, after I push Apply button then it appears this Error in Console Ruby:
                                      I have translated the plugin to spanish language but the plugin window's is in English.
                                      Spanish Language for Texture Resizer
                                      Mac OSX 10.8.2, SU Pro 8
                                        Aerilius
                                        I think I have now found the issue. Can you try to download it again?
                                        And many thanks for the translation!!!
                                        [I thought I had posted this reply yesterday, I don't know how it got lost.]
                                        • OxerO Offline
                                          Oxer
                                          I have reinstalled the 1.4.4 version and the plugin runs fine (the translation works ok), but when i push Apply button it appears the icon Processing... and in the Ruby console this message:
                                          I have seen a skp_textureresizer94750 folder in this path /private/var/folders/2y/lg9fyd494rddw7s_xr5zz2yr0000gn/T/skp_textureresizer94750 but only It contains one image.
                                          I hope you can help me, if you need more info, tell me it.
                                          Mac OSX 10.8.2, Sketchup 8 Pro
                                          Happy New Year!! 😄
                                          New Spanish Language file.
                                          TextureResizer_ES.strings.zip
                                            Aerilius
                                            I published the new version 1.4.5
                                            • 4 / 6
