    [Plugin] Texture Resizer (1.5.6) — updated 15.05.2013
    104 Posts 35 Posters 105.6k Views 35 Watching
      Just tried this - wanted to ensure texture where no larger than a given size.
      I set percentage to 100% as I wanted to keep textures smaller at their original size - then I enabled Limit texture size.
      I got this error:
      Error #<NoMethodError:undefined methodempty?' for nil:NilClass.>`
        Strange that there isn't any backtrace...
          Aerilius
          I found the bug and fixed it. The backtraces became lost because of a rescue Exception.
            Thanks for that. 😄
            Though ... I broke it again... 😕
            Error #<NoMethodError;undefined method `entities' for #<Sketchup;;ComponentInstance;0x773ec0c>.>
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;253;in `initialize'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `call'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `initialize'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;258;in `each'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `new'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;211;in `process'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;188;in `options_dialog'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `call'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `show_modal'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;197;in `options_dialog'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;114;in `run'
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_TextureResizer/TextureResizer.rb;61
            It appear you're trying to use ComponentInstance.entities which doesn't exist in the API - all though a few plugins add this method to the ruby classes.
              Changed line 253 to:
              definition.entities.each{|e| block.call(e, s*scale)}
              Working! 😄
                Here's the list of material in a model where I needed to size down the textures:
                Before:
                === TEXTURE MATERIALS BY SIZE ===
                Material4
                  Size; 4000x4000 pixels
                  Size; 45.78 MB estimated uncompressed RGB
                  Size; 61.04 MB estimated uncompressed RGBA
                  Path; C;/Users/ktn/AppData/Local/Temp/VfSTextureCache
                Material13
                Material3
                  Size; 2255x1782 pixels
                  Size; 11.50 MB estimated uncompressed RGB
                  Size; 15.33 MB estimated uncompressed RGBA
                Material14
                Material1
                  Size; 2048x1536 pixels
                  Size; 9.00 MB estimated uncompressed RGB
                  Size; 12.00 MB estimated uncompressed RGBA
                black3
                  Size; 2814x850 pixels
                  Size; 6.84 MB estimated uncompressed RGB
                  Size; 9.12 MB estimated uncompressed RGBA
                  File; glass.psd
                  Path; E;\LIBRARY\DIGITAL LIBRARY\MORQ LIBRARY TEXTURES\Emiliano
                black1
                  File; glass.psd
                treverk1
                  Size; 1500x1500 pixels
                  Size; 6.44 MB estimated uncompressed RGB
                  Size; 8.58 MB estimated uncompressed RGBA
                treverk2
                Material15
                  Size; 1416x1416 pixels
                  Size; 5.74 MB estimated uncompressed RGB
                  Size; 7.65 MB estimated uncompressed RGBA
                Material8
                  Size; 1417x1408 pixels
                  Size; 5.71 MB estimated uncompressed RGB
                  Size; 7.61 MB estimated uncompressed RGBA
                  File; Material8_extractedTex7662.tif
                Material16
                  File; Material16_extractedTex62.tif
                Material5
                  Size; 1000x975 pixels
                  Size; 2.79 MB estimated uncompressed RGB
                  Size; 3.72 MB estimated uncompressed RGBA
                Material30
                Then I ran the script, got some messages:
                black1; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
                black3; could not write file C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480/glass.psd
                I assume PDS files are not supported?
                After:
                black3
                  File; glass.psd
                black1
                  File; glass.psd
                Material15
                treverk1
                  Size; 512x512 pixels
                  Size; 768.00 KB estimated uncompressed RGB
                  Size; 1.00 MB estimated uncompressed RGBA
                  Path; C;/Users/thm.ARC/AppData/Local/Temp/skp_textureresizer61480
                Material4
                treverk2
                Material13
                Material16
                  Size; 512x508 pixels
                  Size; 762.00 KB estimated uncompressed RGB
                  Size; 1016.00 KB estimated uncompressed RGBA
                Material8
                Material5
                  Size; 512x499 pixels
                  Size; 748.50 KB estimated uncompressed RGB
                  Size; 998.00 KB estimated uncompressed RGBA
                Material30
                Material3
                  Size; 512x404 pixels
                  Size; 606.00 KB estimated uncompressed RGB
                  Size; 808.00 KB estimated uncompressed RGBA
                Material14
                Material1
                  Size; 512x384 pixels
                  Size; 576.00 KB estimated uncompressed RGB
                  Size; 768.00 KB estimated uncompressed RGBA
                Notice Material15 which is a PNG still is larger than 512px. Why is that? There was no messages about this file.
                  Aerilius
                  It seems SketchUp's texture writer does not write psd files. In that case, I'll probably force a default extension.
                  I have no idea what could cause to skip Material15. Is it reproducible? Can you send me a file with that material and its geometry (and group nesting...).
                    It's 8MB (after removing the two PSD textures)
                    PM me your email address and I'll send it to you.
                      Aerilius
                      I think I have fixed it now.
                      Also the texture writer can export PSDs (I have no idea why these failed), but it can't convert psd into other formats by setting a different file extension.
                        Does the texture resizer change the format?
                          Aerilius
                          Here not.
                          But the underlaying ImageMagick.rb has the option to (temporarily) change lossy formats into lossless bmp. I use that in another plugin, mainly because bmps process much faster.
                          • OxerO Offline
                            Oxer
                            I have installed the last version of the plugin (1.4.3 for Mac OSX) and when i run SU it appears a Console Error:
                            I work on OSX 10.8.2, SU 8 Pro
                              Aerilius
                              I fixed it (1.4.4). Sorry, it was a merging mistake.
                              • OxerO Offline
                                Oxer
                                I have installed the 1.4.4 version for Mac OSX and when I call to the plugin the boxes input are empty, I select Percentage, I introduce 50%, after I push Apply button then it appears this Error in Console Ruby:
                                I have translated the plugin to spanish language but the plugin window's is in English.
                                Spanish Language for Texture Resizer
                                Mac OSX 10.8.2, SU Pro 8
                                  Aerilius
                                  I think I have now found the issue. Can you try to download it again?
                                  And many thanks for the translation!!!
                                  [I thought I had posted this reply yesterday, I don't know how it got lost.]
                                  • OxerO Offline
                                    Oxer
                                    I have reinstalled the 1.4.4 version and the plugin runs fine (the translation works ok), but when i push Apply button it appears the icon Processing... and in the Ruby console this message:
                                    I have seen a skp_textureresizer94750 folder in this path /private/var/folders/2y/lg9fyd494rddw7s_xr5zz2yr0000gn/T/skp_textureresizer94750 but only It contains one image.
                                    I hope you can help me, if you need more info, tell me it.
                                    Mac OSX 10.8.2, Sketchup 8 Pro
                                    Happy New Year!! 😄
                                    New Spanish Language file.
                                    TextureResizer_ES.strings.zip
                                      Aerilius
                                      I published the new version 1.4.5
                                        Aerilius
                                        Small update (1.4.7):
                                        • added icon
                                        • OxerO Offline
                                          Oxer
                                          I can't see the icon in Mac OSX 10.8.2, the plugin (1.4.7) works fine only the icon problem. Non Ruby console Error.
                                            Aerilius
                                            Menus don't have icons. The plugin doesn't include a (one button) toolbar, but an icon is the pre-condition for any future toolbars 😉
                                            • 4 / 6
