    Geodesic roof help
    23 Posts 6 Posters 3.7k Views 6 Watching
      disturbed13
      very nice reply
      i might have to try that
      so far ive been useing one single component, the triangle
      and turning it and copying the snot out of it with a dose of rotate to make it fit the arc of the roof
      you way is far easier
        is a nightmare
        Yes if you want same triangle windows !
          Another approach 😉
          http://forums.polyloop.net/picture.php?albumid=23&pictureid=655
          • TaffGochT Offline
            TaffGoch
            disturbed13,
            The roof sections that are in your model are referred to as "barrel vaults."
            Barrel vault roof sections
            The problem, which you've demonstratively-realized, is that equilateral triangles can not be tiled to fit a 135° "bend" in the barrel-vault curved roof.
            135° barrel-vault intersection
            Even if the intersection was 120°, which would, at "first blush," fit the equilateral triangle edge, can NOT be tiled with equilateral triangles. The reason is that, on a cylinder, tiled equilateral triangle edges follow a helix, not the planar intersection line between two adjacent cylindrical roof sections. In the image below, you can see the spiral helix path traced by the equilateral triangle edges.
            120° barrel-vault intersection
            If you wanted to employ equilateral triangles, making all the windows the same, it can not be done. There's no way to get around the mathematical facts of the intersection of cylindrical barrel-vaulted roofs. (Actually, even if they were NOT cylindrical, you can't get a planar-intersection arc to fit equilateral triangles.)
            Did you want to proceed with triangles that are not equilateral?
            Isosceles triangles might/should work, where windows in each ROW share the same specs.
            -Taff
            "Information is not knowledge." -- Albert Einstein
              disturbed13
              i had a hunch
              i call it a variable pitch roof
              from the edge to the center the pitch is as follows
              1/3 > 1/4 > 1/5 > 1/9
              i would really like to know the math/method that is used to figure out how to do it
              as i have several more roofs to draw
              and other parts of my design might get the triangle treatment
                disturbed13
                the whole point was to use as much of the same shape as possible to keep $ down
                i welcome any guidance you can offer
                  If the roof is a simple barrel-vault with equal length segments in its arc, then for a simple form you only need two main component 'panels' that are 'isosceles triangles' - one with it's point up-slope [designed in profile to let water run off its low-point 'sill'] and the other with its point down-slope [designed to let water run off its low-point apex].
                  These frames are then arranged radially in section, around the cross-section arc's nodes.
                  Purpose made cover flashings weatherproof the roof at the panels' junctions.
                  How the frames are supported or are made self-supporting is a major issue not yet addressed.
                  As well as the two 'standard panels' you'll need to consider how you terminate any verges, and junctions...
                  At each 'verge' you'll need '1/2' frames of the two main-types used in alternating rows, the opposite 'verge' will need a 'half' frame made from a handed version of the first verge's 1/2 frames, all depending how the pattern works across the eaves.
                  At junctions between barrels or barrels and abutments etc things become complicated !
                  Unless you contrive the roof so that where two 'barrels' intersect so that the angles are neatly formed at the diagonals of the panels' junctions you'll doom yourself to have to make many variants of infill part-panels...
                  At least with a geodesic dome you repeat most panels and only get convoluted where it's cut at the ground, doorways are added etc - and geodesic spheres are even simpler, especially if you only omit sets of whole panels to allow access etc...
                    disturbed13
                    well i figured it out
                    http://i107.photobucket.com/albums/m294/hedoe/roof4ftarchmk1_zpsdaeb0a94.jpg
                    • olisheaO Offline
                      olishea
                      Another approach 😉
                      how i made this a long time ago!
                      http://i654.photobucket.com/albums/uu269/olishea/speed2.jpg
                      oli
                        disturbed13
                        and the finished product
                        http://i107.photobucket.com/albums/m294/hedoe/buildmk3with4ftarchedroof_zps25093787.jpg
                        i have 57 solar panels up top as well
                        the passive solar shades are turned at a 30 degree
                        and when compaired to the vertical
                        they provide 61% more shade on the house
                        if anyone wants ill post a thread on how to make the windows in that area
                        • TaffGochT Offline
                          TaffGoch
                          That triangular-windowed roof makes a grand addition to the design.
                          It could, just as easily, have been composed of rectangular windows, with triangular windows at the intersections.
                          Have you compared the appearance of triangular vs. rectangular?
                          -Taff
                          (Make no mistake, I'm a fan of triangulated constructs.)
                          • jeff hammondJ Offline
                            nice
                            good job 👍
                              disturbed13
                              -Taff
                              it would seem like rectangles would make the number of different parts increase
                              which would cause the cost to rise as well
                              i might take a look at it later
                              but for now im happy with the triangles
